Old 08-02-2003, 02:40 AM   #1
STIRS
Member#: 16731
2002 Impreza WRX
WR Blue
Default Anyone have problems from using the rear diff to lift the car?
I am worried about lifting my car up by the rear diff before I put it on jackstands, Ive read that it can tear the rubber bushings that hold the diff in place, but many people seem to lift the car this way. Has anyone had any problems yet, like a torn bushing or anything else?
-Thanks
STIRS is offline   Reply With Quote
Old 08-02-2003, 08:24 AM   #2
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
I've been lifting the car at the rear diff ever since I got the car. I checked out the rear diff bushings last month, and they look fine to me.
tmat3 is offline   Reply With Quote
Old 08-02-2003, 11:55 AM   #3
blubaru
Member#: 13001
Rear diff is factory recommended lift point. Front point is the crossmember in front of oilpan. From the manual.
blubaru is offline   Reply With Quote
Old 08-04-2003, 12:24 PM   #4
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Its the same as the people who think its okay to lift the transmission by its oil pan. Many people do it because they havent had a problem. Then when something brakes they are surprised.
The KEY word here is LIFTING the car, not resting, by the differential. Its okay to LIFT the car using the differential but you should not let the car sit in this fashion for any amount of time.
Ive taken a couple differentials out, the bushings are way too soft to support so much weight. Heck, Im so worried now that I dont lift my cars by the differential anymore. No reason to stress the rubber out.
http://forums.nasioc.com/forums/show...hreadid=387397
Need to adjust my E-brake, can I jack from the rear diff? Fireguy615 Brakes, Steering & Suspension 27 02-24-2011 10:17 PM
Lifting back of car by the rear diff. rich728 Service & Maintenance 2 11-04-2004 12:20 AM
Does anyone have pictures of an OEM rear lip installed on their car? 02R6 Interior & Exterior Modification 7 09-17-2003 03:51 PM
Anyone have a pic of their rear diff protector? Ghostrider#2 Motorsports 3 06-17-2002 09:23 PM
Anyone have problems w/ not being able to get into gear when the car is cold? GTBGUY Normally Aspirated Powertrain 27 12-21-2000 10:43 AM
