Welcome to the North American Subaru Impreza Owners Club Saturday August 29, 2015
Old 04-14-2001, 07:52 PM   #1
calworld
Member#: 5711
2004 STI
Post Can I put another turbo to make WRX a twin turbo
Can I put another turbo/supercharger to make WRX a twin turbo?
Will it be faster?
calworld is offline   Reply With Quote
Old 04-14-2001, 09:11 PM   #2
Me
Member#: 4618
Post
U dont want to do that. For one, it would cost an arm and a leg, and 2 you can just upgrade that engine with a bigger turbo and some extra goodies and be just as fast.
Me is offline   Reply With Quote
Old 04-14-2001, 09:46 PM   #3
BADWRX
Member#: 3792
2002 6MT almost GDB
Post
Generally, we do not like to TT a 4 cilynder. TT's are usually done on inline 6's in Japan. There are not to many V6's over there except the TT Z32 Fairlaidy. 4's do not build the kind of exhaust manifold pressure to spin up 2 turbo's in a efficient fashion. You could do it, but it would Like the last man said, go with an upraded turbo (Ball bearing type), a bigger intercooler, bigger injecters, and a custom ECU that is mapped to your engine. You will be ripping mad $hit up.
SACTO
BADWRX is offline   Reply With Quote
Old 04-14-2001, 09:59 PM   #4
bsquare
Member#: 1911
2000 Impreza 2.5RS
Silverthorn Metallic
Post
The Legacy B4RSK has a twin turbo EJ20. Being the not so proud owner of a 3rd Gen RX7, I can assure you that you want to avoid having 2 turbos if at all possible. Spend your money on a larger, ball bearing turbo if you need more boost and less lag.
bsquare is offline   Reply With Quote
Old 04-15-2001, 01:18 PM   #5
GTBGUY
Member#: 2003
'99 BGP Legacy GT
'98 QS Legacy L (auto)
Post
Another Bi-turbo + S/C vehicle was the Koenig Tuned Ferrari Testarossa... that thing is damn fast!
GTBGUY is offline   Reply With Quote
Old 04-15-2001, 03:50 PM   #6
WillReckXhop
Member#: 4866
Post
i dont see why you would want to do that it would cost so much money also there will be more moving parts which means there is a more likely hood of something breaking or malfunction. if you were to upgrade your turbo why not just go with a bigger ball bearing turbo. many people with tt's switch to singles because they can get rid of turbo lag with a programmable ecu and boost controlers and still keep high end power. seems like a waste of money and time.
peace
WillReckXhop is offline   Reply With Quote
Old 04-15-2001, 05:10 PM   #7
NickSTi
Member#: 626
2001 Impreza 2.5 RS
Black Diamond Pearl
Wink
i will chime in to answer your question:
yes you can. with enough money you can do anything.
hope this helps.
NickSTi is offline   Reply With Quote
Old 04-15-2001, 05:13 PM   #8
NickSTi
Member#: 626
2001 Impreza 2.5 RS
Black Diamond Pearl
Post
oh sactownwrx, i can name many 4 banger TT setups.
btw isnt the pikes peak TRD toyota tacoma truck a twin turbo 2.0L 4 banger badd a$$ assault vehicle?
Old 04-15-2001, 05:54 PM   #9
Adrian128
Member#: 3346
Post
There's a MY00 WRX here in Australia with a custom twin turbo set up and Motec M8 Pro ECU with 410hp at the wheels. So to answer your question.. yes it can be done.. and if it's done properly.. yes it will be fast.
Adrian128 is offline   Reply With Quote
Old 04-15-2001, 07:47 PM   #10
BADWRX
Member#: 3792
2002 6MT almost GDB
Post
Well, I was just speaking from my experience in Japan. I know that the B4RSK is a tt, and a Bad Ass one at that. I would like you to know, however, that there are very very very very few pick ups in Japan, and I have no clue about the Tacoma. Sorry.
Old 04-16-2001, 12:10 AM   #11
stiggy-pug
Member#: 4779
Post
what about a supercharger running in conjuntion w/ the turbo?-Lancia did this on their S4 Delta rallycar...talk about engineering!...wonder if any "fast road" street cars have ever had this done?...hmmm,i guess the quickest & easiest way to destroy stock engine internals would be nitrous?
stiggy-pug is offline   Reply With Quote
Old 04-20-2005, 06:21 PM   #12
Trunk_Monkey
Member#: 71032
2003 WRX
World Rally Blue
SACTO
+ A rediculously low spool turbo and you are in heaven.
Trunk_Monkey is offline   Reply With Quote
Old 04-20-2005, 06:31 PM   #13
5spdfrk
Member#: 46407
blew
This thread is over 4 years old!!!!!! Why did you bump it?
5spdfrk is offline   Reply With Quote
Old 04-20-2005, 06:34 PM   #14
Capt Crunch
Member#: 10852
Then : JDM Ver 7 STi
Now : E46 M3 / MKVI GTI
lol, I was gonna say, no specialist is gonna ask a question that dumb.
Capt Crunch is offline   Reply With Quote
Old 04-20-2005, 06:38 PM   #15
5spdfrk
Member#: 46407
blew
I was going to say that no one with a four digit member number is going to ask a question like that.
Old 04-20-2005, 06:45 PM   #16
Starkiller
Member#: 82741
2007 350Z Silver
I always wondered about adding a SuperCharger. A roots charger mounted where the alternator is and swap the A/C with the alternator(if the 2 can swap). Theres an extra pulley mounted to a solenoid that when the turbo reaches a set boost, the solenoid kicks in and releases tension on the SC so the boost from the 2 forced induction systems don't boost spike/destroy motor.
I would never do it myself, but its just an idea.
Starkiller is offline   Reply With Quote
Old 04-20-2005, 07:52 PM   #17
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
if twin turboing an EJ20 I would go with two GT12 ball bearing turbos being I can get them for free/cheap...made for 500-1000cc bikes...so I'm figuring two of them on a EJ20 wouldn't be lagy and would have a good powerband because they are designed to rev up so high...showing peak power and torque on 600 cc bikes at about 5500-12000 rpm ( in about 400 rpm incrememtns) depending on the tune...
Old 04-21-2005, 10:16 AM   #18
andmoon
Member#: 37278
03 wrx
I agree with running two turbos in parallel but what about in series? My limited memory thinks I read that tt in series produce some wild boost.
andmoon is offline   Reply With Quote
Old 04-21-2005, 10:25 AM   #19
Miggidy
Member#: 71343
2000 Impreza WRX GC8
Isn't the whole idea smaller turbo for low RPM and bigger for high rpm in a TT setup?
Miggidy is offline   Reply With Quote
Old 04-21-2005, 11:15 AM   #20
REXLR8
Member#: 70937
2006 VW GTi
RED
buy the blitz twin turbo kit if you want TT. makes good power
REXLR8 is offline   Reply With Quote
Old 04-21-2005, 11:41 AM   #21
Boonie
Member#: 70575
2005 WRX
Yes you can, but you will be wasting 3 things: money, time, and reliability.
Boonie is offline   Reply With Quote
Old 04-21-2005, 11:46 AM   #22
spencerxi
Member#: 72098
2002 Subaru wrx
is'nt that the whole reasone we do this to our cars?
spencerxi is offline   Reply With Quote
Old 04-21-2005, 12:12 PM   #23
Boonie
Member#: 70575
2005 WRX
Good Point, TT away, let us know how it comes out!
What TV show or movie can you put on that just makes you feel happy? rogue Off-Topic 56 05-20-2010 11:46 PM
Subaru to axe Impreza WRX add twin-turbo diesel?!(UK) mattejb News & Rumors 28 10-04-2009 09:12 PM
autostitch, puts pics together to make panoramas (56K drift into a concrete pipe) Protege Menace Off-Topic 13 06-27-2005 09:58 PM
