Welcome to the North American Subaru Impreza Owners Club Sunday August 28, 2016
Old 08-02-2003, 04:02 AM   #1
Vishnu Performance
Vendor
Member#: 14494
WRX Porsche 996
blue & black
Default Revised Stage 2 Reflash now available
Hi guys,
During the past week, we've got hog-wild with Stage 2 re-mapping. Tried a few different mapping approaches that seems to work quite well. Four of the four last in-house Stage 2 WRXs, running the new baseline file, dyno'd at a repeatible 255-260 wheel hp on our dyno. Yes, this surprised even us
We just released this Stage 2 basline today. Customers running earlier Stage 2 baselines (either 91 or 93 octane) may want to send their ECU in to us for free updating. We believe this to be a worthwhile upgrade to earlier Stage 2 baselines.
Give us a ring if you want to arrange an update. Sorry, there are no core ECUs available for the swap. You will have to send your ECU in to us for the updated reflash.
Best Regards,
Shiv
Vishnu Performance is offline   Reply With Quote
Old 08-02-2003, 10:02 AM   #2
quickscooby
Member#: 39415
STI [email protected]
479/492 @ 30psi GT30R .82
I've had the stg2 reflash for a couple months now. So this is a new update? Cause i've been playing with delta dash but if you have a better update i'll do it. So you say it's free? If so if i overnight it can you overnight it back?
With this update what is the boost characteristics? Does it say hit and hold 18 until 6,000 and then drop to 16?
quickscooby is offline   Reply With Quote
Old 08-02-2003, 11:10 AM   #3
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Shiv, why is [email protected] a black hole? I've sent numerous messages to it in the last 3 months, none of which have been responded to.
jblaine is offline   Reply With Quote
Old 08-02-2003, 04:07 PM   #4
Vishnu Performance
Vendor
Member#: 14494
WRX Porsche 996
blue & black
The update is completely free. The only thing that costs you is shipping both ways. Just let us know how you want it shipped. I'll post up boost and a/f ratio logs on Monday or Tuesday. Off the top of my head, boost pressure is approx 18psi up to ~5500rpm. After that, it begins to taper down gradually to approx 15psi by 6500RPM and then sharply down to 12psi by 72000RPM. Peak power is made at approx 6700rpm, IIRC. A/F ratios are in the 10.2-10.7:1 range throughout the entire run. I've made some changes in the knock correction tables to allow for easlier Delta Dash assessment and tuning as well. I think you'll find it much easier to tweak, FWIW.
jblaine- Sorry if no one has responded to you. Sometimes we do get overwhelmed with email. There's no excuse for it. I recommend giving us a call if you can.
Best Regards,
Shiv
Old 08-02-2003, 05:17 PM   #5
wrx320
Member#: 28631
2002 WRB wrx wagon
AVO stg I,II Shiv ECUtek
Join the club. I emailed asking everything under the sun about my tuneup (hate it). Also am very interested in their intercooler, hoses and splitter to the tune of $1200+, do you think I would get an answer to some SIMPLE questions? nah.... (right now in the back of my mind, I am hoping accessECU can overwrite ECUtek) Plus Cobb is alot closer to home.
wrx320 is offline   Reply With Quote
Old 08-02-2003, 07:06 PM   #6
cooter
Member#: 23258
2005 STi
Off topic, but not really....maybe.
Have you guys had a chance to tune any FP18G's? If so, do you think you have a pretty good baseline map for that turbo dropped into a typical Stage 2 setup? (Up-pipe, turboback, IC hoses, STi injectors, fuel pump, and the turbo of course....switchability between a 93octane map and a race gas map would be an added plus )
--coot
cooter is offline   Reply With Quote
Old 08-02-2003, 07:46 PM   #7
Vishnu Performance
Vendor
Member#: 14494
WRX Porsche 996
blue & black
--coot
We don't have much dyno time with 18G turbos so I can't comfortably provide a standard Stage 2 map that will work with that turbo without custom tuning (as was the case with wrx320 and his AVO turbo which actually failed during the dyno tune). If you want a plug-n-play solution devoid of any additional fiddling, I'd suggest going with a pre-set kit.
wrx320-- If you have any questions about your kit, please call us.
Best Regards,
Shiv
Old 08-02-2003, 08:08 PM   #8
cooter
Member#: 23258
2005 STi
Well, I currently have a Stage 1 ECUtek using the Vishnu non-signature series TBE. I also have DeltaDash. Do you think you could get something close enough to where I could utilize DeltaDash to provide the necessary 'additional fiddling'?
If only there were an ECUtek capable tuner with an awd dyno within a day's drive........and of course Shiv's willingness to travel and have a 'dyno day' there
Old 08-03-2003, 10:25 PM   #9
quickscooby
Member#: 39415
Shiv please check your email.
Old 08-08-2003, 06:35 PM   #10
cooter
Member#: 23258
2005 STi
Bump for Shiv, since he seems to be around more on the weekends.
Old 08-08-2003, 10:14 PM   #11
wyowrx
Member#: 34157
00 Toyota MR-S
Kudos to shiv and vishnu for upgrading for free!
wyowrx is offline   Reply With Quote
Reflash now available for '07 LGT and FXT Dyno Flash Tri-State Area Vendor Classifieds 0 11-21-2007 06:02 PM
cobb stage 2 reflash questions... wrX-RTD Engine Management & Tuning 12 10-07-2003 11:34 PM
Selling my Cobb stage 2 reflashed ECU stephan Private 'For Sale' Classifieds 3 09-18-2003 09:50 AM
Is it ok to get cobb stage 2 reflash with stealthback? 03mbpREX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 05-01-2003 07:04 PM
Revised WRX LINK is now available AMR MOD Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 02-26-2002 03:22 PM
