Old 08-02-2003, 08:09 AM   #1
arcsound
Member#: 10603
2014 CrossTrek XV
Khaki
Default Correct Compressor Oil Question
I'm replacing the compressor on my '96 Legacy OB and purchased new compressor oil at the local parts store. They sold me "PAG 45" oil. After getting the original compressor, a ZEXEL model, out of the car, I noticed it read, "Use ZXL PG200 Oil", on the compressor label. I'm thinking this is probably "PAG 200". Can anyone confirm this notion?
Thanks!
arcsound is offline   Reply With Quote
Old 08-03-2003, 11:08 AM   #2
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
I do believe you need the PAG 200 oil for a '96 Zexel system... it could be confimed for certain through your dealership though .
Brian
Old 08-06-2003, 12:08 AM   #3
arcsound
Member#: 10603
2014 CrossTrek XV
Khaki
Well, I brought the PAG 45 back, (only then noticed the label read "low viscosity") and found that the supplier (Interdyamics, or stte...), also makes a medium vicosity (PAG 100) and a high viscosity (PAG 150) version. Exchanged it for the "150", figuring that 150 is close enough to 200 not to damage the compressor, assuming that the compressor is looking for PAG 200. I'll wait a few days, though, before using it, lest my common sense approach is not valid, and someone with knowledge regarding this subject responds to the contrary. Thanks!
A/C Compressor Oil - Unable to find correct type "Zexel Type R" ?? caterpill Service & Maintenance 3 09-23-2007 03:33 AM
FL: 02 WRX ac compressor, oil separator plate, universal grounding kit subygirl Engine/Power/Exhaust 12 06-26-2007 08:46 PM
AC Compressor Oil maxiav Service & Maintenance 4 08-01-2006 09:53 PM
Knock Correction and Oil?? mpggomd Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-31-2006 06:02 PM
Correct Purolator Oil Filter for WRX WRXreation Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 08-26-2001 12:14 PM
