Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 08-02-2003, 03:01 PM   #1
Solomon
Member#: 36587
2000 Legacy GT (BE)
Default Baja Specs
Kinda hard to read when pasted.
http://techinfo.subaru.com/html/whatsNew.jsp
Specifications
These specifications are subject to change without notice.
!Dimensions
in (mm)
!Engine
Model BAJA, BAJA-Sport BAJA-Turbo
Overall length 199.3 (4,910)
Overall width 70.1 (1,780)
Overall height 62.1 (1,760) 62.6 (1,775)
Wheelbase 104.3 (2,650)
Tread Front 57.7 (1,465)
Rear 57.7 (1,465)
Ground clearance 8.4 (213)
Item Non-turbo Turbo
Engine model EJ251 EJ255
Engine type Horizontally opposed, liquid cooled 4 cylinder, 4 stroke gasoline engine
Displacement cc (cu-in) 2,457 (150)
Bore Stroke in (mm) 3.92 3.11 (99.5 79.0)
Compression ratio 10.0 : 1 8.2 : 1
Firing order 1 - 3 - 2 - 4
12-3
Specifications
. CONTINUED .
!Electrical system
!Capacities
Battery type and capacity MT 55D23L
AT 75D23L
Alternator 12V-90A
Spark plugs Non-turbo RC10YC4 (Champion)
BKR6E-11 (NGK)
BKR5E-11 (NGK)
Turbo ILFR6B (NGK)
Fuel tank 16.9 US gal (64 liters, 14.1 Imp gal)
Engine oil 4.2 US qt (4.0 liters, 3.5 Imp qt)
Transmission oil (MT) 3.7 US qt (3.5 liters, 3.1 Imp qt)
Transmission fluid (AT) 9.8 US qt (9.3 liters, 8.2 Imp qt)
AT differential gear oil 1.3 US qt (1.2 liters, 1.1 Imp qt)
Rear differential gear oil 0.8 US qt (0.8 liters, 0.7 Imp qt)
Power steering gear fluid 0.7 US qt (0.7 liters, 0.6 Imp qt)
Engine coolant Non-turbo MT 7.2 US qt (6.8 liters, 6.0 Imp qt)
AT 7.1 US qt (6.7 liters, 5.9 Imp qt)
Turbo MT 8.1 US qt (7.7 liters, 6.8 Imp qt)
AT 8.0 US qt (7.6 liters, 6.7 Imp qt)
12-4
Specifications
!Tires
!Wheel alignment
Type Steel belted radial, Tubeless
Tire size P225/60R16 97H
Wheel size 16 x 61/2JJ
Pressure Front 33 psi (230 kPa, 2.3 kg/cm2)
Rear 33 psi (230 kPa, 2.3 kg/cm2)
Temporary spare tire Size T145/80R16
Pressure 60 psi (420 kPa, 4.2 kg/cm2)
Toe Front 0 in (0 mm)
Rear 0 in (0 mm)
Camber Front 0a40.
Rear .0a05.
Solomon is offline   Reply With Quote
SPEC B axle part numbers GraphicWRX Private 'Wanted' Classifieds 8 06-03-2010 12:27 AM
06 Baja 4 wheel alignment specs - help!! sheilan Baja Forum 4 04-25-2008 10:17 AM
FYI: We've got one set of our Sport Spec Springs for the Baja available iON Performance Inc Baja Forum 15 11-23-2005 03:19 PM
Baja wheel specs? 02_Forester Baja Forum 28 06-29-2005 02:24 PM
FS: 2004 Subaru Baja Turbo 2.5L Motor - STI Spec! latinskllz Private 'For Sale' Classifieds 5 04-14-2005 12:03 PM
