Old 08-02-2003, 07:05 PM   #1
WRX 555 STi
Member#: 8042
MY00 WRS - '04 WRX
2002 Dragon slayer :)
Default Dual fans for Link+ users...
For those of you who haven't noticed, the Link only controls your driver side fan. Today I connected both fans to run on the same wires. Here's what you do:
1. There is a wiring loom where the plug for the driver side fan comes out of. You need to cut the protective plastic covering and expose the wires.
2. Cut the plug about 2" off that loom. You will end up with the plug in your hand with two wires about 2" long.
3. Cut the plug of the pass. side fan following above steps. Make sure to leave enough wire to splice and connect.
4. Take some 16 or 14 gauge wire, and attach the pass. side fan plug at one end. Solder and use electric tape on exposed wire.
5. Now, at the other end of the wire you just installed the pass. side fan plug, splice the end about 2" (exposing 2" of wire).
6. Attach the driver side plug wires to the top 1" of the other and of the wire with the pass. side plug. Solder and use electrical tape on exposed wires.
7. Now you should have a wire (actually 2, one for ground, one for trigger) that has both fan plug at each end, and 1" of exposed wires on the driver side plug.
8. Now splice the wires that come up from the wiring loom (under the radiator). Attach both wires, solder and tape them. Make sure you have used the same color wire for ground and trigger. If not, your fans will not work.
Here's a rough drawing of all of the above.
This is just as a reference if someone wants to do the mod. It would be searchable too.
~Anthony.
WRX 555 STi is offline   Reply With Quote
Old 08-02-2003, 07:18 PM   #2
Chav
Member#: 3269
2001 2.5RS Sedan STM
RSTi
The second fan is supposed to be on when the A/C is on. The problem is the low power drives of the link plus are only designed to run one relay. So hooking up two relays to one drive may damage the driver. The best thing to do is to put a relay to switch on both of the fan's or the aux fan and a/c. Remember the relays are given a ground to switch on.
-Chav
Chav is offline   Reply With Quote
Old 08-02-2003, 07:37 PM   #3
WRX 555 STi
Member#: 8042
MY00 WRS - '04 WRX
Hmmmm, it's one relay. One relay runs both fans.
~Anthony.
Old 08-02-2003, 10:24 PM   #4
Chav
Member#: 3269
RSTi
oops i see, nice work
-Chav
Old 08-22-2004, 10:51 PM   #5
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
Hydra+HMist+PPG+35R=DEATH
i wanted to bump this to ask another q about it
couldnt i just connect both fans to the output on the link for fan one?
alex
Old 08-22-2004, 11:38 PM   #6
kaos200
Member#: 2692
alex
you would want the fans relayed, so Id stick to the setup shown above
kaos200 is offline   Reply With Quote
Old 08-23-2004, 12:11 AM   #7
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
theyre relayed they have to be
that 18 gauge wire isnt big enough to carry the current for those fans and i beleive there are fan relays in the fuse box under the hood
so couldnt i just connect the 2 left and right fan wires at the ecu harness together to minimize a hack job like the one above
alex
Old 08-23-2004, 01:14 AM   #8
kaos200
Member#: 2692
alex
right, if you did that you would be cutting out the relay
Old 08-23-2004, 01:30 AM   #9
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
how
there are 2 relays correct ? im not bein smart im just askin stuff
the pinout for the stock ecu said fan one & fan two , the link install said install fan one onto fan output on link
if i combined both wires, since the ecu isnt a relay, wouldnt i then have both relays turn on at once?
Old 08-23-2004, 01:58 AM   #10
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
just try it and see
Ben
Old 08-23-2004, 10:49 AM   #11
ForesterPerformance
Member#: 5424
BRP STi Version 3
Type RA V-Ltd RHD
I did something like this... only easier...
On two of the Link+ RS-Ts down here, i just ran a jumper wire in the underhood fusebox from the relays. Now when the one fan comes on, both come on. There was no hacking necessary on the wire harness. The relay-on power is low amp so it is no big deal.
ForesterPerformance is offline   Reply With Quote
Old 08-23-2004, 12:11 PM   #12
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
there's an even easier way, jump it at the PNP ECU harness
Old 08-23-2004, 12:11 PM   #13
sideways slut
Member#: 21085
2.5 rs-t
how
this is what i did about a month ago, no problems yet.
sideways slut is offline   Reply With Quote
Old 08-23-2004, 01:12 PM   #14
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
alright cool ill give it a shot
thanks sideways/jeremy
Old 08-23-2004, 06:29 PM   #15
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
hmm
i wonder y the purge control and radiator fan wires are the same......
maybe when the ac is on it opens the purge control solenoid which....doesnt make sense to me unless to get a little bit more power.?
Old 08-24-2004, 01:31 PM   #16
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
hmm
it's something about the way they wired the Link+, it's not teh Purge COntrol solenoid
Old 08-24-2004, 02:14 PM   #17
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
i mean i was looking at the pinout diagram for my subaru, not for the link
i just dont get it i possibly think that the power is just to supply the relay and the - is the other side of the coil that is supplied
anyone know
alex
Old 08-24-2004, 02:40 PM   #18
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
anyone know
alex
that's a typo in the service manual IIRC
Old 08-24-2004, 03:59 PM   #19
White 2.5rs
Member#: 39936
99RS TWE&SCAT EJ257
well ***...
what is the proper wire for solenoid power and radiator control?
In need of: Blitz Dual SBC boost controller user manual. Millencolin! Private 'Wanted' Classifieds 1 01-12-2006 02:20 PM
Link users (cold start answers?) Soon2Bgreat Engine Management & Tuning 15 05-07-2003 03:27 PM
LINK users... curvie Engine Management & Tuning 10 10-21-2002 05:24 PM
Any link users? mrtrex Tri-State Area Forum 1 08-12-2002 11:15 AM
Link users-What are good cruise egt's? paulw Engine Management & Tuning 3 07-29-2002 05:07 PM
