08-02-2003, 09:02 PM | #1 |
Member#: 23359
NESIC
Vehicle:2002 BMW M Coupe Steel Gray |
Autometer guage problems
I've just finished installing a set of autometer phantom guages in my 2000 RS and have some problems. Anyone have any ideas?
#1. The boost/vaccuum guage is off. It never gets to 0 vaccuum, it goes up to about -5 in/mercury. Even when the car is off, it shows vaccuum. #2. The EGT guage works fine, but after the car is running for a few minutes, the guage fogs up on the inside. Its in the center guage pod, so I thought the HVAC vents right behind it might be the problem, but the guages right next to it are fine. If the car is turned off and let sit for a while, the guage clears up.
08-02-2003, 09:07 PM | #2 |
Trust no one
Moderator Member#: 11170
Vehicle:02 RAV4 MT 15 WRX/11 CRZ |
If the gauge shows vacuum with the engine not running it is likely defective. Does it still do this if it is completely disconnected?
08-02-2003, 09:55 PM | #3 |
Member#: 22218
South East
Guess everyone was right to say buy the Japanese products.
Full_Clip still doesn't like Defi guages. |
08-03-2003, 01:34 AM | #4 |
Member#: 18823
Vehicle:2011 with 4 wheels monochrome? |
it should not read in the negatives if the car is just sitting there. Another reason your glass fogs up is the fact that the gauge itself has been dropped and now you have condensation from the AC unit. There's air in your gauge.
Keefe |
08-03-2003, 01:29 PM | #5 |
Member#: 23359
NESIC
ok, so the boost guage is defective. Is there any way to reseal the EGT?
08-03-2003, 02:48 PM | #6 | |
Member#: 13634
NESIC
Vehicle:2002 WRX WRB |
You can try to take the light out and mess with the internals of it to get the needle to rest back at 0, I tried doing this with one of my friend's autometer boost gauge and it appeared to work fine. Then to test it I took out my GReddy electronic boost gauge to put on his car and test it out. The peaks matched up pretty close, just wasn't as responsive. |
08-03-2003, 03:51 PM | #7 | |
Member#: 23359
NESIC
problems with autometer gauge | tobylazur | Electrical & Lighting | 5 | 01-08-2010 03:47 PM |
FS: autometer gauge pod, autometer oil pressure gauge, maddad EGT gauge | schiarelli | Interior/Dressup/Audio & Security | 2 | 10-29-2009 11:26 AM |
Autometer boost Gauge problem!!!! | onebadwrx | Electrical & Lighting | 1 | 10-21-2009 04:28 PM |
WTT: Autometer Gauge #3301 for Autometer Gauge #3303. | coldturbo | Private 'Wanted' Classifieds | 0 | 10-03-2009 05:02 AM |
Autometer oil temp gauge problem :( | gregor2001 | Interior & Exterior Modification | 0 | 04-14-2007 11:53 PM |
