Notices
Old 08-03-2003, 01:02 AM   #1
Tap
Member#: 21893
2002 WRX w/STi swap
Default Reflash to remove lean map
Can any of the various reflashes available totally remove the lean map and only leave the rich map?? I love using the UTEC but once I get a good set up with no knocks the ECU will eventually switch to a leaner map. Then I get det. which I have to tune out. If I get to many det events the map goes rich again and I am back where I started. If I put maps in more of the switch positions of the UTEC that would be a start. But right now the UTEC is filled with the different octane maps and the "wife" map.
I am running a TurboXS stage 4 with FMIC and perrin fuel rails.
Tap is offline   Reply With Quote
Old 08-03-2003, 01:54 PM   #2
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
Does this happen to all UTEC equiped cars? I don't have a wideband a/f gauge with me all the time, but I havn't been having large detonation problems after I get a good tune a week later either.
PaulRex is offline   Reply With Quote
Old 08-03-2003, 03:11 PM   #3
Tap
Member#: 21893
2002 WRX w/STi swap
The ECU itself is what does it. It manipulates two different maps basically for good vs. bad gas. If the ECU record X number of knock events in Y time period it changes to the richer map (what X and Y is I haven't figured out). What I experience is the ecu adding fuel which I take slowly out via the UTEC then the ECU sees the engine running well and starts taking out fuel itself then bam, knock again. Why don't I leave it rich you say?? When I start hitting 98-100 IDC I have no choice but to lean it out some. I can feel the car hesitate when I start maxing out the IDC, feels like the UTEC taking out timing for a knock but no flashing CEL. Do a data log and 98-100 IDC. If I could reflash the ECU to stop it from manipulating or switching between two maps I think I could get a more consistant tune.
Old 08-03-2003, 05:06 PM   #4
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
You need to first make sure the ECU is in the lean map, then tune your UTEC. That way, the ECU shouldn't switch over to the rich map unless something is wrong (ie bad gas). Tuning while the ECU is on the rich map doesn't make sense because of the very issue you're describing. Why would you want to pay for a reflash and then the UTEC on top of that? A reflash could take care of everything for you, or spend the same amount of money on a link+ or something and leave the piggy back world.
-- Ed
Equilibrium Tuning is offline   Reply With Quote
Old 08-03-2003, 05:58 PM   #5
Tap
Member#: 21893
2002 WRX w/STi swap
I want the UTEC for the ability to tune for different gas, funtions and conditions. A reflash will not do that for me. I just don't want to continually fight the ECU for control of the fuel. If I get knock events I want to take it out not have the ECU try and correct. Tuning in either the rich or lean map doesn't make a difference to me I just don't want to make two maps for each setup I want to run (not to mention there are a limited number of positions on the UTEC).
Old 08-03-2003, 08:48 PM   #6
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
the point is that if you tune the UTEC while the ecu is runing the lean map, and tune properly with no knock, then there is no reason for the ecu to ever switch to the rich map, making things consistent. A reflash WILL hangle different conditions. The different fuel is an issue for now though.
-- Ed
Old 08-03-2003, 10:31 PM   #7
Tap
Member#: 21893
2002 WRX w/STi swap
It shouldn't switch over to the rich map with a good tune but lord knows I get a good tune on the lean map, it runs well for a couple of days then CEL flashes between a hard shift and back to the rich map I go.
Old 08-03-2003, 10:39 PM   #8
Equilibrium Tuning
Member#: 26933
2006 STI
CGM
Do you really have to make changes to your map every couple of days?? That's insane. I still say make sure that you're running the lean map and only tune with that. I guess the real question for you is how to get the ECU to switch to the lean map quickly so you can do your tuning. Upon reset, which map does the ECU run?
-- Ed
Old 08-05-2003, 07:39 AM   #9
Davenow
Member#: 23676
I have a UTEC and I am not experiencing this. Neither have 3 of my buddies with them.
When did your problem start? Where are you located? Do you happen to know what allocation# your car was? (just for my own tracking purposes
Old 08-05-2003, 07:49 AM   #10
x99percent
Member#: 27108
2004 STi
2004 A4
You have gotta be knocking an *awful* lot for the ECU to switch to the high-det (rich) fuel map.
The stock ECU switches to the high-det fuel map when the Ignition Advance Multiplier is at 4 or less. Have you verified that this is what is happening with DeltaDash? If not, then you really don't know...
The car should be tuned to run knock-free on the low-det (lean) fuel map. Even the infamous "shift-knock" can be eliminated with the UTEC.
x99percent is offline   Reply With Quote
battery removed....xpt map deleted? crxmex Engine Management & Tuning 2 12-02-2007 04:31 PM
removing utec do i need to get the stock ecu reflashed to stock phobos sti UTEC 12 09-07-2007 12:02 AM
removing utec map selector? stevepius Interior & Exterior Modification 1 08-01-2005 12:12 PM
CEL due to running lean due to cat back or removed silencer?? wrx_snobordr Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 12-03-2004 11:22 PM
need to remove front bumper to remove a fender? idealrides General Community 0 11-13-2003 03:38 AM
