Old 08-03-2003, 12:00 PM   #1
go go go
Member#: 2784
Default engine swap: won't rev: why?
Hi,
I did the engine conversion by myself.
99 JDM STi motor on 94
did wiring by myself too.
The motor started up but won't rev more than 3000rpm
3000rpm is just around when the vacuum turns to boost.
It sounds like speed/rev limiter but don't know why it does that.
Runs fine upto 3000rpm
ECU is Apex PowerFC. I set the rpm at 7800
MAF is Nissan 300ZX
idle is fine.
TPS seems to be working (giving correct voltage)
I have Blitz boost controller on it.
I have stock 94 guage cluster (tach doesn't work because of that. Using Apex monitor to check the Rev)
Using stock 94 wiring harness for the most of the part
any idea why it's not reving?
i appreciate any info.
thanks
go go go is offline   Reply With Quote
Old 08-03-2003, 01:14 PM   #2
motorswapsleeper
Member#: 38946
199? 6 diff ones
bag o' skittles
I didn't know the 300zx maf was compatible...
motorswapsleeper is offline   Reply With Quote
Old 08-03-2003, 03:28 PM   #3
go go go
Member#: 2784
300ZX maf is only compatible because i use Apex-i PowerFC stand alone ECU.
Apex ECU has map for 300ZX maf sensor.
Old 08-03-2003, 04:12 PM   #4
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
how hard was wiring I got a 94 also I heard jdm engines didn't use obdII till 2000 is this true with you?
scobaru is offline   Reply With Quote
Old 08-03-2003, 11:49 PM   #5
go go go
Member#: 2784
wiring is tough. finished the swap in half a day but taking 3 months to do the wiring..
My Nissan friend said it could be the speedo sensor, anybody know about this issue?
My car is 94, which uses cable speed sensor...
My motor and ECU is 99 and the speedo sensor for 99 is electric.
If I put the electric sensor, would I be able to solve the rev problem?
Old 08-04-2003, 12:38 PM   #6
Boeleni
Top Scoob 003
Member#: 1812
1999 Impreza Try-R
Satin Black
Sounds like the car is in limp mode. But you are not using the stock ecu right?
I think the answer lies in the settings you have in the Power FC. I had a similar problem when I was setting up the speed limit cut with the Apex'i RSM.
Also double check the MAF wiring and condition of the MAF. A blown MAF will not allow the car to go on boost.
On pre 2002 cars you can disconnect the speed sensor and it will not go into limp mode. The Idle Air Control valve won't work properly though.
Boeleni is offline   Reply With Quote
Old 08-05-2003, 11:55 AM   #7
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
fwiw the 300z maf is the same as a 1.8 subaru maf
i don't think it has to do with the speed sensor/ dash, should be seperate ..
how much can you monitor with the power fc? is there software for it. can you see the voltage comming out of the maf change when you rev the engine?
scobaru: no jdm engines are OBD-2 compliant even the newest ones
Old 08-05-2003, 01:51 PM   #8
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
well let's say I have both side of the wire harnesses like u would in a front clip would that take out a lot of the work when doing the swap?
Old 08-05-2003, 03:20 PM   #9
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
I have a Ver. 4 STi speed sensor if you need it. Just email or pm me whenever you find out.
garface is offline   Reply With Quote
Engine Swap: What shop to use in SoCal? SubaruPreza Southern California Impreza Club Forum -- SCIC 94 02-19-2005 09:03 PM
Engine Swap: Who's Done it MoeRS Normally Aspirated with bolt-on Forced Induction Powertrain 16 03-16-2003 06:14 AM
engine swap: ECU + TCU question Cajual Transmission (AT/MT) & Driveline 0 12-07-2002 05:02 AM
Engine swap: Where? cardin555 Canada Region Forum 30 10-19-2002 05:38 PM
Engine swap: Western Canada Titanium Samurai Vancouver Impreza Club Forum -- VIC 11 10-15-2002 12:28 AM
