Old 08-03-2003, 04:46 PM   #1
GMTarkin
Member#: 9237
2008 Saab Turbo X
400+ lbft
Default ABC low boost in closed loop mode???
Why is my boost so low in closed loop? even with the ABC turned out as far as possible, its still a little under factory boost levels?? why is it so low?
do i have to make maps for closed loop or something?
thanks
GMTarkin is offline   Reply With Quote
Old 08-03-2003, 06:56 PM   #2
JayC
Member#: 32144
2003 Impreza WRX
Sonic Yellow
Did you read the manual?
You need to switch the Utec to closed loop (Which I assume you have done), and start off with 200 in the boost map and adjust from there. If you use a closed loop setup with an open loop map, you'll have pretty low boost as I think the numbers are considerably smaller.
Jay
JayC is offline   Reply With Quote
Old 08-03-2003, 10:36 PM   #3
Mildmanneredman
Member#: 29962
Thumbs up
Turn back the ABC to about 2-3 turns as well.
Mildmanneredman is offline   Reply With Quote
03 WRX bad cold start idle in closed loop / rich open loop fuelling toflaherty Open Source Reflashes 2 04-17-2010 09:06 AM
Low emission requires closed-loop or no? kgb Engine Management & Tuning 5 09-28-2005 12:33 AM
compression numbers? knock in closed loop? deluxsti Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 08-14-2005 05:38 PM
Does S-AFC work in Closed Loop? SPeeDSiN Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 16 07-26-2002 11:36 AM
AFC work in closed loop? Nat Technical Forum Archive 3 05-07-2000 10:19 PM
