Old 08-03-2003, 06:07 PM   #1
Zoso
Member#: 37962
2006 CGM STI
2000 Outback & 05 BMW M3
Default What brand/size speakers do you have in your rear doors?
What brand/size speakers do you have in your rear doors and also what modifications were necessary?
Zoso is offline   Reply With Quote
Old 08-03-2003, 07:32 PM   #2
strohausii
Member#: 26770
'02 WRX
midnight black
5-1/4" co-axial Cerwin-vegas (w/ angled tweets)
..the doors hate them, i love em till #24 on stock hu.
i put spacers on em, but were a temp fix type of thing. I'm gonna have to go back and prolly make an mdf cut out like i did for my front speakers (6 -1/4"components).
Rob
strohausii is offline   Reply With Quote
Old 08-03-2003, 07:52 PM   #3
Cardiff Giant
Member#: 40325
2013 Nissan Rogue
http://www.crutchfield.com/cgi-bin/S...=0&cc=01&avf=N
These 4" Pioneers. They were inexpensive (I got these, the 6.5" version for the fronts, a JVC MP3 headunit, and all the wiring for 310 shipped). They sound good to me but since they're smaller and mounted low, the highs tend to get muffled a bit. I'm not a very demanding car audio person anymore so YMMV. Installing them was pretty easy actually. I ripped out the factory rear speakers and fashioned adapters out of the plastic ring that surrounded them. Very easy actually(well easier than the fronts atleast )
Cardiff Giant is offline   Reply With Quote
Old 08-03-2003, 07:56 PM   #4
dsmperformance
Member#: 15059
2004 WRX STi
1991 TSi
Diamond Audio M351i 5.25" coax. Had to enlarge the opening in the door for a proper fit.
dsmperformance is offline   Reply With Quote
Old 08-04-2003, 01:43 AM   #5
surfer.tech
Member#: 39842
2003 WRX wannabe
4 inch infinity kappa
surfer.tech is offline   Reply With Quote
Old 08-04-2003, 09:08 AM   #6
robmarch
Member#: 18713
06 CRV
04 STi
4" infinity reference coaxials, rear mounted on a 0.25" MDF mounting ring, with that assembly normally mounted into the rear door. The tweeter on this speaker sticks out too far and likes to hit the door, otherwise.
No cutting of door, etc.
I'd recommend speakers with flush tweeters, and actually would have preferred to go with 5 1/4" speakers back there, knowing what I know now. The ultimate setup back there would be 5 1/4" components, since there's already a nice little spot on the inside of the door panel that would be a perfect cutting template for adding a tweeter.
robmarch is offline   Reply With Quote
Old 08-04-2003, 09:44 AM   #7
strohausii
Member#: 26770
'02 WRX
midnight black
...anyone hear of someone installing on back deck?
Old 08-04-2003, 10:43 AM   #8
robmarch
Member#: 18713
06 CRV
04 STi
it's an option...you can search for it if you like.
i'm not sure why that makes you furious?
Old 08-04-2003, 01:25 PM   #9
strohausii
Member#: 26770
'02 WRX
midnight black
lol, oh, yeah the face? That my frustration on how painful its gonna be to install some components up there. It looks like it would have been there if not for the middle seat belt (the holes are there, but modified into the hole with sheet metal for the belt housing.)
edit:: thanks JPIQ, thats very helpful, also guys sorry to thread jack, but having the stereo ear level is optimal for the higher frequencys for soundstaging
Old 08-04-2003, 05:05 PM   #10
JPIQ
Member#: 30277
2002 WRX Japan Specs
Platinum Silver Sedan
I use to have 5.25'' Discuss MB's in the rear doors.
The Installation was very easy, however the sound was not clear, compared to the front 6.5" speakers.
Now, I replaced them with 6.5'' speakers in the rear panel.
The sound is clear and louder than the front cause they are mounted higher. The installation was NOT EASY.
Was it worth it?
Just try to sit in any sedan with the speakers mounted in the
rear panel.
Also, try to do a search on REAR PANEL or REAR DECK.
JPIQ is offline   Reply With Quote
Old 08-14-2003, 03:28 PM   #11
Doughboy
Member#: 27398
2002 Impreza
i mounted diamond audio components in the rear: mid-bass drivers are in the doors and the tweets are mounted on the rear deck.
i didn't like it. it completely threw off the soundstage -- since the sound was louder and brighter in the back versus the front, it felt like the music came from the back. i've since disabled the rear tweeters and am now running only the mid-bass drivers. a set of coaxials will replace the diamond audio setup in the rear.
db
Doughboy is offline   Reply With Quote
Old 08-14-2003, 09:02 PM   #12
IA Performance
Member#: 25194
2008 Forester XT 5mt
Dark Gray
I'm running MB Quart discuss 113s (5.25") in the rear doors. The offer nice fill adn don't over power my front stage, but then again not much will. I have 6.5,4, tweet on each side up front.
4" works well with factory adapter. Most 5.25" can fit using an adapter and not having to cut metal.
6.5" need cutting galore, but can be worth it. I use my car as a rolling template so I can't afford to alter the sheet metal.
IA Performance is offline   Reply With Quote
Old 08-15-2003, 08:25 PM   #13
SCOOBYSHAG
Member#: 358
2005 Xterra
Grey
none..prefer true stereo
SCOOBYSHAG is offline   Reply With Quote
Old 08-16-2003, 12:21 AM   #14
ldivinag
Member#: 13533
04 sti
black???
good boy SS...
unless you carry passengers ALL THE TIME in the rear seats, you are just ruining your sound stage.
when was the last time you went to a concert and then turned around to face the rear when the band started playing?
oh, dont even say, "rear fill"...
rear fill, rear schmilll....
set up a good 2 channel setup up front and you are set.
when multichannel HARDWARE finally makes it for a mobile setup, then we'll talk again.
but right now, 2 channel is king...
ldivinag is offline   Reply With Quote
Old 08-16-2003, 04:44 PM   #15
Doughboy
Member#: 27398
2002 Impreza
Originally posted by East Coast Scooby
I'm running MB Quart discuss 113s (5.25") in the rear doors . . . . I use my car as a rolling template so I can't afford to alter the sheet metal.
Do the MBQ D113's go into the rear doors without ANY alterations to the door or door panels? I'm looking for a decent set of rear fill speakers that do not require cutting the doors or sanding down the door panels.
db
Old 08-16-2003, 10:31 PM   #16
Legacy
Member#: 10188
2007 Forester XT
Nothing at the moment. Initially I ran a pair of Infinity Kappa 6 1/2's in the rear doors . After a month I decided that they really didn't add much to the DEI 3065's comps up front so I removed them . Haven't missed them a moment's since. As mentioned above , unless you have people in the back on a constant basis there's no good reason to bother.
Legacy is offline   Reply With Quote
Old 08-17-2003, 12:00 AM   #17
Eaglesfan2422
Member#: 26445
Are you just seeing what fits in with no modification, or little modification? I've installed all of these, just a simple 1/2" mdf spacer. Could probably use 1/4" but I never have anything that thin laying around. DEI Directed 3055 5 1/4", Focal Polykevlar 136k 5 1/8", CDT HD 4".
Eaglesfan2422 is offline   Reply With Quote
Old 08-17-2003, 10:57 PM   #18
1st Scooby
Member#: 36395
2007 STI Ltd 159/800
"Urban Grey Metallic"
I have 5 1/4 JL Audio XR-525CXI coaxials w/ angled tweeters in my rear doors. They fit with no problem.
Jim
1st Scooby is offline   Reply With Quote
Old 08-17-2003, 11:55 PM   #19
SCOOBYSHAG
Member#: 358
2005 Xterra
Grey
Originally posted by ldivinag
good boy SS...
Right on man. Yeah having an audiophile for a roommate has taught me a lot of things about proper staging and stereo setup.
Currently I am running Boston Z6's in the front doors and a single Boston Pro 12 in the rear.
Old 08-18-2003, 09:18 AM   #20
robmarch
Member#: 18713
06 CRV
04 STi
you guys know you can install speakers back there and just fade them off when you don't have passengers....right?
ps...if you're in a car, your sound stage is already ruined...sorry to break it to you.
I love when people try to use this fallacy as justification for no rear fill. when was the last time you went to a concert and didn't have walls beside or behind you that the sound reflected off of, creating a rear fill situation?
Old 08-18-2003, 09:59 AM   #21
strohausii
Member#: 26770
'02 WRX
midnight black
hehehe, i'm spoiled, i like the sound of being in the sound (i'm center). I guess it breaks down to people whom want a "concert" i'm in the audience feeling, or being part of the music and having it all around you (not 5.1, but would be nice).
Old 08-18-2003, 08:02 PM   #22
SCOOBYSHAG
Member#: 358
2005 Xterra
Grey
Um you DO have walls beside you and behind you, its called the car..why do I need rear fill when the sound is reflecting off of these walls?
But to answer your question seriously the last time was last week at the Motorhead/Dio/Iron Maiden show at Smirnoff Music Centre in Dallas. It is a semi-outdoor environment. I was about 15 feet from the stage. The closest wall behind me was about 400 yards behind me and the closest walls to my left and right were about 50 yards away. I was really close to the speakers so couldnt hear any "reflecting" off of said walls. Wow, really close to the speakers......kind of like in a car. Hmmmmm...
Old 08-19-2003, 12:18 AM   #23
strohausii
Member#: 26770
'02 WRX
midnight black
...did Maiden do the tale of the mairner?
Old 08-19-2003, 12:46 AM   #24
SCOOBYSHAG
Member#: 358
2005 Xterra
Grey
they played a bunch of hits..started off with number of the beast with a huge "666" lit up in the background..I dont remember if they played Tale of the Mariner or not..I was a little tipsy
Old 08-19-2003, 10:35 AM   #25
robmarch
Member#: 18713
06 CRV
04 STi
That's pretty much the worst seat in the house, musically, unfortunately. it's fun to be close to the stage, though. And, at those volumes, even walls that seem far away have a big impact. Even outdoor football stadiums deal with reflections, etc.
Keep arguing how great of a soundstage a car is, though
What size tires do you have on your BBS wheels? Jay04WRX Tire & Wheel 8 05-27-2010 02:09 PM
What Auto "must haves" do you have in your car? DrDRum Off-Topic 71 05-21-2008 05:46 PM
What speaker setup do you have in your Subie?? Newera09 Car Audio, Video & Security 33 02-27-2007 09:44 PM
What speakers do you have in the front? WRXVII Car Audio, Video & Security 20 08-07-2003 08:32 PM
Poll: What Brand of speakers are you running in your impreza? Bob J. Car Audio, Video & Security 40 02-08-2001 01:50 AM
