Welcome to the North American Subaru Impreza Owners Club Wednesday March 4, 2015
Old 08-04-2003, 12:10 AM   #1
the spacecowboy
Member#: 765
Default car acting up...need help....
i was gone for 32 days.....come back and now i am having the worst luck with my car
this is what the major problem is....
when i go to accelerate, the car starts spitting/sputtering
idles find and if you give it alittle gas, goes good...but if you give it too much, it does its own thing....
its a 2000 2.5 RS with a asr turbo....it also has the split second voltage..
anyone please help....
space
the spacecowboy is offline   Reply With Quote
Old 08-04-2003, 02:20 AM   #2
Aphex
Member#: 146
'05 Genesis Sedan
either reset the ECU, or the gas is crappy.
does gas go bad in 32 days? anybody?....... anybody?
Aphex is offline   Reply With Quote
Old 08-04-2003, 03:19 AM   #3
Darshu
Member#: 1676
98RS w/ EJ257/Dom
2014 Tesla Model S P85
Running too rich? Bad ground? I was getting some serious hesitation on boost before I doubled up on the stock grounds. Once did the grounding mod thing it made a huge difference. I was skeptical about it, but for 15 bucks in 4ga stranded copper wire from home depot it was so worth it.
Darshu is offline   Reply With Quote
Old 08-04-2003, 09:46 AM   #4
the spacecowboy
Member#: 765
ground?!?!?!....doesnt hurt to try...
my first guess is that the split voltage componet may be bad....just a wild guess....
i dont think the gas is bad....i had my mother drive it and she filled it up with high test....but she says it wasnt acting up or anything
i'll reset the ECU, clean the air filter and go from there....i'll try everyones suggestion....also, keep the ideas coming....
space
Old 08-04-2003, 11:30 AM   #5
DoctorNick
Member#: 7022
heh, DC ITCA are
my rides
How many miles do you have on the car? mabye your fuel filter is clogged? I would have thought the voltage clamp, but if it was broken you wouldn't do real well in boost. How are your egts? Mabye your running too rich and bogging the heck out of the car? Hows the car at idle? What about when you rev it when parked? Any jerkyness?
-Neal
DoctorNick is offline   Reply With Quote
Old 08-04-2003, 01:12 PM   #6
Chav
Member#: 3269
2001 2.5RS Sedan STM
RSTi
Do you have CEL? If you had one before for cat inefficency, I'd get them pulled at autozone to see if you have a map or any other sensor code as well.
Also just look over your vacuum hoses.
-Chav
P.S. I'm guessing your using a RRFPR?
Chav is offline   Reply With Quote
Old 08-05-2003, 10:46 AM   #7
foolio
Member#: 9351
2006 trailblazer SS
black
After you reset the ecu you should be fine. My car was acting up a few weeks ago. I pulled the codes.. (P0420 and a MAP code). I ended up replacing the front and rear O2 sensors and all has been fine ever since. I figure I should probably do it anyways so it doesnt catch up with me later on. However I had the same problem in the winter and I just reset the ecu and it ran fine for the longest.
J
foolio is offline   Reply With Quote
Old 08-05-2003, 06:16 PM   #8
Thumper
Member#: 9214
I think Foolio might be right. Could be bad O2 sensor.
Thumper is offline   Reply With Quote
Replaced Radiator but car acting up Help Please Catracho Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 24 07-30-2009 12:10 PM
Car Acting up...:/ URABUSgrl13 Newbies & FAQs 20 01-17-2009 12:09 AM
Help!!! Car acting up!!!! xXTOUGEIZZYXx Southern California Impreza Club Forum -- SCIC 27 10-17-2007 03:21 PM
Bah, banged up my car a bit - need help! GTWagon_Phreak Legacy Forum 52 07-22-2006 02:02 PM
Cars acting up edel33 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 05-05-2005 05:21 AM
