Old 08-04-2003, 11:38 AM   #1
GMTarkin
Member#: 9237
2008 Saab Turbo X
400+ lbft
Default Connect utec via Cat5 cable?
I was just wondering if it was possible to connect the utec via a cat5 cable and a cat5-to-serial adapter, they make them... is it possible, does anyone know?
Im getting a laptop for school soon, and want to be able to tune my utec with it, but i dont want my choice to be limited by if the laptop has a serial port or not... and most of the ones ive looked at lately, do not...
i know here at work our computers have serial ports, and we use a Cat5 to serial port adapter on them for the ERALink software... hmm... can someone shed some light on this?
GMTarkin is offline   Reply With Quote
Old 08-04-2003, 12:55 PM   #2
Mildmanneredman
Member#: 29962
I'm not sure about cat5 but I do know people use usb if they don't have a serial port.
Mildmanneredman is offline   Reply With Quote
Old 08-04-2003, 01:17 PM   #3
GMTarkin
Member#: 9237
2008 Saab Turbo X
400+ lbft
USB huh?? does someone make a usb to serial adapter? USB operates off of the com ports, right?
thats the only problem i see with the cat5, it operates off of tcp/ip, and not the com ports, if im not mistaken
Old 08-04-2003, 01:46 PM   #4
MikeWRX-NJ
Member#: 33410
08 wrx
dgm
using cat5->serial won't work. To communicate, the network card wants an IP address, something the utec doesn't have.
No serial ports.... I hate new computers. I would call turbo-Xs and see what they recommend.
MikeWRX-NJ is offline   Reply With Quote
Old 08-04-2003, 03:36 PM   #5
SysRq
Member#: 31347
() support your
/\ sysadmins
Technically, you can use a CAT-5 cable to make your own serial cable using proper DB9 connectors on both ends... That's what you seem to be doing at work. But if your laptop has no serial port in the first place, how's this going to help?
Get a serial-to-USB adapter.
SysRq is offline   Reply With Quote
Old 08-04-2003, 10:34 PM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
I got my USB<--->serial cable at Radio Shack w/driver disc for $34.xx. Works great with my UTEC.
Old 08-04-2003, 10:40 PM   #7
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
I use a USB-serial adapter for my Delta Dash, works fine. This is the way to go if you don't have serial ports.
Old 08-04-2003, 10:50 PM   #8
GMTarkin
Member#: 9237
2008 Saab Turbo X
400+ lbft
Awesome, thanks for the info guys, glad to know this is a valid solution! THANKS!! =)
Connecting UTEC to my PC w/o ECU kramps UTEC 10 02-25-2008 11:56 AM
IT question - Cat6 vs Cat5e cabling? banman Off-Topic 12 02-24-2005 08:39 PM
Cheap Cat5 cable? Charge Off-Topic 8 09-16-2003 11:24 PM
How to connect utec to new laptop without serial port? RyeDaddy Engine Management & Tuning 0 09-04-2003 12:12 AM
Is there a "trick" to making cat5 cable? jamz Off-Topic 29 10-02-2002 07:50 AM
