Welcome to the North American Subaru Impreza Owners Club Monday March 2, 2015
Old 08-04-2003, 04:15 PM   #1
Nutter
Member#: 7185
2009 MINI Cooper S
British Racing Green
Default Best AutoX street tire ?
Best dry grip AutoX Street tire ?
Please try to keep opinions to actual experiance where possible.
Tire size of: 225/45x17
Cost not a factor.
Tire MUST be street tire legal.
Nutter is offline   Reply With Quote
Old 08-04-2003, 04:19 PM   #2
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
street tire with no less then a 140 treadware.
BFG KD if you can afford them and the Falken Azenis Sport in a close 2nd.
The BFG KD's are $193 on TireRack in a 225/45-17
Patrick L is offline   Reply With Quote
Old 08-04-2003, 06:14 PM   #3
Dolphin Overton
Member#: 1925
Falken Azenis are another option. They are sticky enough to make your wheel bearing very unhappy.
http://www.vulcantire.com/azenis_t.htm
$106 a piece in 225/45 17
Dolphin Overton is offline   Reply With Quote
Old 08-04-2003, 06:42 PM   #4
Paris
Member#: 39945
2002 Subaru WRX
I would recommend the Azenis Sports also. I just put 225/45 -17 Azenis on my car last week and auto-x them this past Sunday. BIG improvement. They got slick a little slick on the last run of the day....but overall they were outstanding.
Paris
Paris is offline   Reply With Quote
Old 08-04-2003, 07:26 PM   #5
rex n effect
Member#: 15289
02 wrx pollen silv
& '11 TDi dadwagon
STi tires
BFG KD
Azenis
Kumho MX
I once owned an STX class full of drivers on Azenis while I had the kumho MX (it was raining)
rex n effect is offline   Reply With Quote
Old 08-04-2003, 07:41 PM   #6
Yungimoto
Member#: 14940
Most people seem to go with Azenis or shaved MXs.
Yungimoto is offline   Reply With Quote
Old 08-04-2003, 09:51 PM   #7
sirfrankwilliams
Member#: 6817
2008 E91
I can't believe no one's mentioned Azenis 215/45/16. IMHO these are pretty decent affordable tire for D Stock. The smaller size lessens to outer diamter, which lowers the gearing. It makes the turbo lag less of a pain. However, I'm still a about a second off drivers with Kuhmo race rubber. Although the Azenis are a good chunk less.
sirfrankwilliams is offline   Reply With Quote
Old 08-04-2003, 10:39 PM   #8
MNbiker
Member#: 18148
'08 WRX
Dark Gray
Default Re: Best AutoX street tire ?
Cost not a factor.
John,
If you're going to stick with 225/45-17, the Azenis would be my #1 choice. The BFG KD's MAY stick a little better, but the stiff sidewalls on the Azenis definitely feel more precise.
Now if cost is really no factor, then the ultimate choice would be 245/40-17 BFG KD's. However, you'll need plenty of negative camber and rolled fenders to use these bad boys.
BTW - I wouldn't recommend the 215/45-16's on the big lots you get to play on. 225/45-17 seemed to provide just about ideal gearing at Miller Park last weekend.
-Steve
MNbiker is offline   Reply With Quote
Old 08-04-2003, 11:42 PM   #9
Patrick L
Member#: 634
2000 Impreza 2.5RS
Becasue ITS racecar
Default Re: Re: Best AutoX street tire ?
Originally posted by MNbiker
John,
-Steve
With the camber at -2.5 front and -1.5 rear the 245/40-17 KD's should fit just fine. You might have to take off the rubber strip on the rear fender lips but that's it. I checked the specs on the KD.
Old 08-05-2003, 12:25 AM   #10
Nutter
Member#: 7185
2009 MINI Cooper S
Wink thanks
Great feedback, thanks guys !
I was more interested in the overall grip and feel of the tire. The choice is, as noted above, between the Azenis, Khumo MX and the BFG KD's. I did not want to cloud the question but to add to this I want to keep my RS 16x7" rims so the size Im looking at is 215/45x16 Azenis or 225/50x16 BFG KD's/Khumo MX's. Now if I was buying wheels as well then I would try to fit the 245/40x17 BFG KD's but at a high cost !
For close to the price of the KD's (225/50x15 $780 shipped) I could get 225/45x17 Azenis mounted on common clone rims. But I like to be a little different so Im leaning towards the KD's.
Old 08-05-2003, 02:12 AM   #11
SpinAll4
Member#: 4666
2002 WRX sedan
WRBlue under the dirt
Howdy,
I have been running the MX(225/50/16) all summer and have loved em. But, for fun, i am gonna run a new set of Azenis' (215/45/16) for my next event. I am hoping the Falkens in this size are gonna be the ticket for this next course.
Cant wait to reveal these tires as my latest secret weapon.
RB
SpinAll4 is offline   Reply With Quote
Old 08-05-2003, 02:22 AM   #12
suby_dude
Member#: 17397
many '02 Rex,'13 FRS
WRB, White
AZENIS...
i never been so impressed w/ a 'street' rated tire.
Best Regards,
SD
http://www.subydude.com
JOIN MY WEEKLY NEWSLETTER by emailing newsletter-subscribe@subydude.com
AZENIS IN ACTIONS...
suby_dude is offline   Reply With Quote
Old 08-05-2003, 02:33 AM   #13
Orion
Got the F out
Member#: 4797
01 01 RS, 00 RS
2008 WRB FSXT 5mt
I've raced on Azenis for 2 years and due to their consistent inconsitency I'm leaving them behind. Of course I'll be making the jump over to ESP so it will be R Compound for me from now on.
I will say that the Advan A046 (Evo) and the new Potenza 070 (STi) will add a new dimension to the STS/STX mix once they become more readily available. Unfortunately they aren't cheap like the Azenis or MX. Pretty soon I think we'll see the trend of cheater tires, questionable UTQG 140 rating and high $$$, destroying the classes. Right now the 3 options (KD, Az., MX) are VERY close depending on surface and temperature. That will change soon...
Orion is offline   Reply With Quote
Old 08-05-2003, 02:40 AM   #14
whtlegacy
Member#: 38400
2004 WRX Wagon
DRZ400SM
If cost is no issue, I would suggest Toyo RA-1's. They are a DOT legal R compound tire and they are ridiculously sticky. I am using them right now and the only downside is that they wear incredibly quickly.
whtlegacy is offline   Reply With Quote
Old 08-05-2003, 08:01 AM   #15
WRX_Mundi
Member#: 33270
2004 STi
WR Blue
They have a treadwear rating of 40 (reference one recently viewed as well as Toyo's web site, so would not count as a street tire by anyone's rules. The Azenis and RE070's at least are realistic street tires for a daily driver.
WRX_Mundi is offline   Reply With Quote
Old 08-05-2003, 09:55 AM   #16
Luke@tirerack
Tire Rack Moderator
Member#: 1215
ext. 4362
#1 ---- KD's
#2 ----MX's
'nuff said
Old 08-05-2003, 10:26 AM   #17
wrx2.0 555
Member#: 21383
2010 Trek
EX-5
Originally posted by Luke@tirerack
#1 ---- KD's
#2 ----MX's
'nuff said
With all due respect,,,that statement is from a vendor that doesnt sell Falkens..
wrx2.0 555 is offline   Reply With Quote
Old 08-05-2003, 03:13 PM   #18
[W]Dark[R]BuDDha[X]
Member#: 25233
2003 Wrx
Slow POS
Originally posted by suby_dude
AZENIS...
Best Regards,
SD
what size are you wheels? and what suspension setup did you use, from what i'm seeing you have major stiffness... BOING for TRACTION
[W]Dark[R]BuDDha[X] is offline   Reply With Quote
Old 08-05-2003, 08:55 PM   #19
TubeDriver
Member#: 14987
Gods Speed #57
Lemons/Chump #77
I would go with Azenis too but if people are going to throw in the MXs than I would add the S03s. The S03s stand up really well to repeated AutoXing, have a progressive breakaway, quite, very responsive, really stiff sidewall (you can actually autoX with about 35 psi and have no problem with rollover) and if not the last word in sticky dry street tires (although they are excellent) they make up for that because they are the best wet street tire I have ever used. You can also get 15k+ miles out of a set assuming frequent rotation. Never used or ridden in a car with KDs but they are reported to be excellent.
TubeDriver is offline   Reply With Quote
Old 08-06-2003, 12:36 AM   #20
suby_dude
Member#: 17397
WRB, White
i'm on tanabe sustec pros
the setup is plenty stiff... those are 17" x 7.5" w/ 225/45/17 azenis.
sd
Old 08-06-2003, 01:40 AM   #21
[W]Dark[R]BuDDha[X]
Member#: 25233
2003 Wrx
Slow POS
i'm expecting my Jic FLT-A2 this week or so... i'm wondering what struts and sways are u using?
Old 08-06-2003, 01:48 AM   #22
suby_dude
Member#: 17397
WRB, White
whiteline sway
tanabe coil overs set to stiffest.
the problem w/ that setup in the pix was the rear tires didn't have enough tire pressure... specially in that particular run.. so the rears were gripping too much... as you can see... the last run finally got the tire pressure up and the car to turn...
Old 08-06-2003, 02:55 AM   #23
[W]Dark[R]BuDDha[X]
Member#: 25233
2003 Wrx
Slow POS
it looks like ur passenger rear wheel is off the ground
Old 08-06-2003, 11:50 AM   #24
kdawg
Member#: 16606
2002 Honda S2000
I autocross on KDs in the San Francisco Region. They more sticky than the stock WRX suspension can handle. I have a rear sway bar and at a certain lateral accel, the stock suspension gets really out of whack and I lose grip. BUT the tires are not the weak link. With a nice suspension, these tires will equal a win. This is my first year autocrossing and I am about 1-2 seconds off the leaders who have coilovers and azenis and atleast 50 HP more. Oh, and I really don't feel a loss of grip when they get hot.
kdawg is offline   Reply With Quote
Old 08-06-2003, 12:01 PM   #25
kdawg
Member#: 16606
2002 Honda S2000
Wheels from subydude
And I have to stop autocrossing on no sleep. Kills reaction time.
wtb: 225/45/17 autox street tires in great shape Nick's 92x NESIC Private Classifieds 5 06-28-2007 11:43 AM
AutoX/Street Tire recommendation ... makofoto Motorsports 18 03-09-2005 01:02 AM
Best Summer Street Tire for the money? Will not take to Track! HerculesPeanut Tire & Wheel 27 11-20-2004 01:57 AM
Best autoX/street pads? Steven Saunders Brakes, Steering & Suspension 14 07-30-2002 08:03 PM
Good 16" AutoX/Street tire size for Wagon guinsu Brakes, Steering & Suspension 1 06-10-2002 06:00 PM
