Old 08-04-2003, 03:54 PM   #1
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
12 Legacy GT 13 Armada
Question Throttle Response Hesitation Question
Ive done some searching on this and couldn't find an answer.
I am wondering what will fix the throttle response problem I am having. Basically I hit the go pedal and can count almost 2 seconds between the time I hit the throttle until the engine actually revs.
I can here the throttle body open and take a big gulp but then nothing for about a second and a half to two seconds, then the revs shoot up like normal.
The ECU has been reset, and the front O2 sensor has been replaced within the last year.
Whats up with that?
This is in my Legacy with the 2.5 by the way.
Brad
MY99 2.5GT is offline   Reply With Quote
Old 08-04-2003, 04:19 PM   #2
gtwagon941
Member#: 16874
2008 2008 Audi RS 4
2014 Audi S Q5
I had a similar type of problem a year ago. I had a front crank seal leak that had leaked onto the timing belts and that was causing the problems. I hope thisn't is the case for you, but if it is be sure to replace the water pump while you're at it, cause it doesn't cost that much and if it were to go out you would have to pay the same labor costs all over again.
gtwagon941 is offline   Reply With Quote
Old 08-05-2003, 01:15 AM   #3
mike270
Member#: 12863
2002 2.5RS
is it an auto? If so it might be something with the tranny.
If its a manual I got no clue. Free bump for more help though.
Good Luck
mike270 is offline   Reply With Quote
Old 08-05-2003, 01:42 AM   #4
kasio
Member#: 6489
01' GM6
Here are some of my suggestions-
-the ground wires mod
-install a ProECM chip
-get a good aftermarket exhaust system
-most imporntly* have a big tune up
I know that right after I've done the 30kmiles tune up, my subbie's been running better than ever!!
kasio is offline   Reply With Quote
Old 08-05-2003, 01:56 AM   #5
gtwagon941
Member#: 16874
2008 2008 Audi RS 4
2014 Audi S Q5
Default "big" tune-up
What exactly is a big tune-up?
Old 08-05-2003, 02:36 AM   #6
Ken
Member#: 34
2005 WRX STi
World Rally Blue
New fuel filter could help too??
Ken is offline   Reply With Quote
Old 08-05-2003, 02:36 AM   #7
scotty305
Member#: 8877
2000 Impreza 2.5RS
(sept '01-jan '04)
Tighten up the slack in your throttle cable, this will make the pedal feel more directly connected to the engine. Helped me a lot for rev-matching, especially on downshifts.
Make sure your intake filter is clean? No exhaust leaks? Spark plugs & fuel filter pretty fresh (once a year is a good idea)?
That's all I can think of for now.
-s-
scotty305 is offline   Reply With Quote
Old 08-05-2003, 08:27 AM   #8
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
Intake filter definitely needs to be cleaned.
I have a good exhaust system and NGKs with new wires and a new coil as of last year.
I'll try replacing the fuel filter also.
2007 throttle response or hesitation?? BBBsti LTD Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 11-17-2006 03:48 PM
Throttle response question j-wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-02-2005 10:49 PM
Question - Throttle Response Between Shifts SlideWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 10-15-2001 10:00 PM
Throttle response Dave99 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 06-01-2001 09:01 PM
Crisper throttle response? OBSS Normally Aspirated Powertrain 10 04-04-2001 11:21 AM
