Old 08-04-2003, 08:47 PM   #1
davesill
Member#: 10818
2002 WRX Wagon
WR Blue Pearl
Default Oil analysis: high lead
My first analysis, which was done by Blackstone:
Oil Use Interval: 7,183 mi
Make-Up Oil Added: 0 qts
Fuel Type: Unleaded premium gasoline (93 octane)
Equipment Type: 2.0L Turbo
Comments: Lead (bearings) read fairly high in the initial sample from your Subaru.
Mi on Unit: 34,433
Element: Mine (Avg. for engine type w/4k mi)
Al: 5 (5)
Cr: 1 (1)
Fe: 21 (10)
Cu: 6 (6)
Pb: 33 (3)
Sb: 1 (0)
Mb: 60 (50)
Ni: 0 (0)
Mn: 0 (1)
Ag: 0 (0)
Ti: 0 (0)
K: 1 (2)
B: 104 (102)
Si: 8 (9)
Na: 9 (26)
Ca: 3049 (2290)
Mg: 18 (292)
P: 765 (783)
Zn: 785 (913)
Ba: 0 (0)
Sus Visc. @ 210F: 57.8 (should be 55-62)
Flashpoint: 395F [>365]
Fuel %: <0.5 [<2.0]
Antifreeze: 0.0 [0]
Water: 0.0 [<0.05]
Insolubles: 0.5 [<0.6]
So, obviously, lead is high, but other bearing metals are OK. Iron and calcium are high. Sodium and magnesium are low.
Is lead really used in the bearings of modern engines like the WRX's?
Where could the lead be coming from? I've never used any additives. How common is lead-contaminated gas?
What do low magnesium and sodium mean?
Any observations, interpretations, or advice would be appreciated.
My normal change interval is 5k miles.
davesill is offline   Reply With Quote
Old 08-05-2003, 03:35 AM   #2
drees
Member#: 25905
2003 Silver Wagon
Tuned with Enginuity
Yeah, lead looks pretty high for a Subaru.
You have any engine mods? What is your driving style? What oil/filter were you running?
Lead in Subarus usually occur when you experience detonation which will put extreme load on your rod/crank bearings.
You iron readings also look high for a Subaru engine.
http://www.blackstone-labs.com/gasol...port_expl.html
# Sodium: Antifreeze inhibitors, additive in some gasoline engine oils.
# Magnesium: Detergent/dispersant additive.
Looks like you simply ran too long with this oil. I'd bet you're running a dino oil or drive extremely hard as most people with normal driving in a Subaru and a synthetic oil will run up to 7k miles just fine. I guess you didn't have the TBN checked? I bet it was low as well.
I would run your next interval short, maybe 2500-3500 miles and have the oil analyzed again to make sure that the engine is healthy.
drees is offline   Reply With Quote
Old 08-05-2003, 08:47 AM   #3
davesill
Member#: 10818
2002 WRX Wagon
WR Blue Pearl
Sorry, I should have included this. I have a foam air filter and ScoobySport muffler. No internal mods. My driving style is probably typical WRX: fast and aggressive. Oil is Mobil 1 5W30. Filter is Subaru.
So the main bearings in WRXs are lead-based? I find that hard to believe.
No, since I'm not going for extended drain I didn't think it was worth the $10.
I'll definitely get a recheck with the next change, but I think I'll aim for my usual 5k, which is pretty conservative for Mobil 1, considering it's under Subaru's recommendation for dino oil.
Thanks for responding.
Old 08-05-2003, 12:14 PM   #4
Stanley
Member#: 7374
2007 Grandpamobile
BlingBlingBlue
I personally think that having the same recommended drain intervals for a NA engine and a turbo engine are complete crap. It is also important to point out that "typical WRX" driving style almost certainly puts you in the severe service cycle, which is a 3,750 mile oil change, on dino.
Thank you for posting this, I find it quite interesting. I change my Mobil 1 every 3 or 4 months (usually 3800-4500 miles) but have often wondered if I could safely extend my drain interval. Like you, I use OEM oil filters.
Stanley is offline   Reply With Quote
Old 08-05-2003, 12:20 PM   #5
drees
Member#: 25905
2003 Silver Wagon
It's your option to run 5k, but with those lead and iron levels I would be a bit worried about the overall health of the engine.
If you take a look at squeeze's results after 7k on oil, his lead/iron numbers are low.
http://forums.nasioc.com/forums/show...hreadid=389986
My results after 5k miles have even lower numbers:
http://forums.nasioc.com/forums/show...t=oil+analysis
-Dave
Old 08-05-2003, 01:18 PM   #6
davesill
Member#: 10818
2002 WRX Wagon
WR Blue Pearl
I'm concerned, too...at least enough to post here about it.
Say I retest after 3k or 5k miles and Pb/Fe are still elevated. What then? If I tell the dealer, will he care? If the WRX engine contains no lead bearings--and I haven't seen any confirmation that it does--what does that say about the health of the engine?
Old 08-05-2003, 01:56 PM   #7
drees
Member#: 25905
2003 Silver Wagon
Well, you're just under the 3yr/36k mile warranty period. Maybe you can show these results to the dealer and say, "look, I think my engine may problems, but I'm not quite sure yet, will you cover my engine if the next oil analysis still shows high levels of wear?" You may be able to use it as proof of engine damage before the warranty period had run out.
Not sure if they'll go for it or not, but at least you can use it as an excuse to pick up the extended warranty.
Hopefully this is just a contaminated sample or a fluke.
Anyone else have ideas?
edit: I see you posted on bobistheoilguy those guys should have some good insight.
Old 08-05-2003, 05:27 PM   #8
Karl
Member#: 13110
Is this your first sampling?
I would at least get another sample before jumping to conclusion.
On my Miata, the first oil sample I took showed high lead too, but the next one got back to normal (on about 4k miles interval).
Blackstone lab attributed it to "temporary particle streak through the bearings".
Karl is offline   Reply With Quote
Old 08-06-2003, 02:16 PM   #9
bluesubie
Member#: 767
04 FXT
Just got my first UOA back from Blackstone.
'03 WRX Wagon
M1 10W30 SS - 5,427 miles on oil, 13375 miles on engine.
Lead = 3
Iron = 12
I'll post the full report later.
I seem to recall a thread on Bob's about a Taurus owner getting new head gaskets (before a major problem occurred), due to results from a UOA.
-Dennis
Old 04-07-2004, 10:16 PM   #10
BryanH
Member#: 993
So I sent my oil off for a second sample and now I am more than a little worried about the results:
ALUMINUM 5 4
CHROMIUM 1 1
IRON 13 9
COPPER 5 6
LEAD 92 26
TIN 3 0
MOLYBDENUM 72 53
NICKEL 0 0
MANGANESE 0 1
SILVER 0 0
TITANIUM 0 0
POTASSIUM 2 1
BORON 143 133
SILICON 7 6
SODIUM 5 3
CALCIUM 2634 2736
MAGNESIUM 15 27
Specifically the lead.
I sent an email to Blackstone and haven't heard anything yet...
PHOSPHORUS 762 754
ZINC 837 859
BARIUM 0 0
BryanH is offline   Reply With Quote
Old 04-07-2004, 10:28 PM   #11
drees
Member#: 25905
2003 Silver Wagon
Bryan,
The numbers in the left column are yours? What oil, how long did you run it for, what's your driving style and what mods do you have? I'm guessing M1? Also do you have the viscosity, fuel % and insolubles %?
Your elevated lead/tin definitely point to bearing wear.
-Dave
Old 04-07-2004, 10:30 PM   #12
BryanH
Member#: 993
the first column is 17500 miles and the second is 14000 miles.
mobil 1 5w30
driving style is commute in traffic with occasional backroad fun.
No mods...not even a k&N.
EDITED>>>>
Old 04-07-2004, 10:33 PM   #13
BryanH
Member#: 993
insolubles were 0.4
water 0.0
antifreeze 0.0
fuel <0.5
flashpoint 375
viscosity 60.0
Old 04-07-2004, 10:34 PM   #14
drees
Member#: 25905
2003 Silver Wagon
Well, the good news is that the wear #s are going down, best to check again after another 3-4k. What were you using previously and for how long? Everything else looks pretty normal, just the lead and tin are elevated.
Old 04-07-2004, 10:37 PM   #15
BryanH
Member#: 993
always 3-4K and always mobil 1 5w30.
Crap those are backwards...the first column is 17500 and the second is 14000.
Old 04-07-2004, 10:42 PM   #16
esteve
Member#: 28716
2006 STI
I wonder if that foam air filter has anything to do with it. It's possible that it could be letting too much dirt and abrasives into your motor causing wear in the bearings.
I've seen one of those Greddy foam filters literally crumble apart before.
esteve is online now   Reply With Quote
Old 04-07-2004, 10:47 PM   #17
BryanH
Member#: 993
what foam air filter?
Old 04-07-2004, 10:52 PM   #18
drees
Member#: 25905
2003 Silver Wagon
The original poster (davesill) didn't appear to have an issue with his air filter, his silicon numbers were low. BryanH is running stock filter, and silicon is low, too. Elevated silicon is #1 indicator of dirt in oil, although elevated silicon can be gasket sealer leaching in on a new or recently repaired engine.
I've seen a couple of WRX engines with abnormally high lead. Most of them produce very low wear numbers.
Haven't figured out why some of them do, though. BryanH appears to be doing everything right, using M1, extremely short intervals, no mods... but bearing wear usually points to detonation or fuel contamination.
Might want to post on BITOG for more advice.
BTW, here's a link to my most recent analysis: 7600mi M1 5w30 WRX
Old 04-07-2004, 11:59 PM   #19
esteve
Member#: 28716
2006 STI
I was referring to davesill, but I think drees cleared it up.
Old 04-08-2004, 12:18 AM   #20
BryanH
Member#: 993
yeah...whoops...
Old 04-08-2004, 12:20 AM   #21
BryanH
Member#: 993
Will old plugs cause detonation? I still have the original plugs at 20000 miles....
teh gas is consistenly exxon or amoco 94/93 octane so I don't think that is it. I wonder about the winter additives around here? Va. I think they did away with MTBE.
Old 04-08-2004, 12:20 AM   #22
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Sorry, but it's true .
Brian
Old 04-08-2004, 01:16 AM   #23
drees
Member#: 25905
2003 Silver Wagon
Given that your engine is 100% stock, I'd have a really hard time blaming detonation. I'd have to chauk it up to variances in the engines, but seeing close to 100ppm of lead where a lot of others are seeing almost none is very strange.
Do you wait until the engine is fully warmed up before driving hard?
Old 04-08-2004, 07:52 AM   #24
BryanH
Member#: 993
I always keep it under 4000 rpms until the engine is warm.
Old 04-08-2004, 12:40 PM   #25
Stanley
Member#: 7374
2007 Grandpamobile
BlingBlingBlue
Out of curiosity, how do you determine when the engine is warm? Are you going by the stock temperature guage or an aftermarket oil temperature guage?
It is important to know that the stock guage is non-linear and only measure coolant temperature.
Used Oil Analysis: 2004 WRX Stage 1 Mobil 1 High Mileage 10W-30 USCTrojan4JC Service & Maintenance 47 04-02-2012 09:22 PM
Oil analysis at 35K: slightly high lead, otherwise OK. Butt Dyno Service & Maintenance 11 01-16-2006 05:56 PM
Oil Analysis: Amsoil ASL 5w30, 2003 Subaru WRX 2.0T, 7,382 mi, 34,294 mi total drees Service & Maintenance 13 08-10-2004 11:32 PM
Oil Analysis: 7600mi on M1 5w30 - WRX drees Service & Maintenance 3 03-02-2004 12:39 AM
Oil Analysis: 7,247mi on Mobil1 5w30 (WRX) drees Service & Maintenance 18 10-23-2003 01:12 AM
