Old 08-10-2003, 02:44 AM   #1
Benjamin Tang
Member#: 4496
2009 Forester
red
Default concerns about the coolant reservoir
... the metal one high up on the passenger front of the engine bay next to the power steering reservoir, not the plastic overflow tank.
i was at the shop today and a mechanic there was working on a dead wrx. turbo was cooked or something (missed the first half of the conversation). he had the turbo out of the car and all the coolant lines and fittings dismantled. in one of the banjo bolts the holes were stuffed with what looked almost like tea leaves. what it actually was is tiny paint chips from the inside of the filler neck of the coolant reservoir that had made their way from the reservoir to the turbo. the reservoir was completely drained and there was more paint chips at the bottom as well cluttered around the outlet.
does ne1 have prior knowledge of this? is this common or just a freak occurence?
Benjamin Tang is offline   Reply With Quote
Old 08-10-2003, 02:56 AM   #2
silverscooby
Member#: 15060
Paint from where? I have never heard of this before but I'm surious where in the world you would get paint in your coolant.
silverscooby is offline   Reply With Quote
Old 08-10-2003, 03:14 AM   #3
tdxflex
Member#: 13634
It happened to me also when I flushed out my coolant earlier this summer. I was cleaning the area around the filler neck and it started peeling off. I cleaned it up as best as I could, but on every flush/refill I never had them come out, only when I wiped the filler neck with a paper towel the first time.
tdxflex is offline   Reply With Quote
Old 08-10-2003, 05:09 AM   #4
eightballrj
Member#: 18520
2005 L GT Limited
I know that my coolant Definately had this in it too. I looked at it and thought something was wrong but then decided that it was what subaru would have called NORMAL. But, heck I dont know.
RJ
eightballrj is offline   Reply With Quote
Old 08-10-2003, 05:11 AM   #5
fimotorsports
Member#: 31773
03 Evo8 9.2 @ 156
I have had the same problems, if you noticed Subaru used the black painted coolant resevoir and switched to the non painted ones on the later 02-03 + model years. Hmm I wonder why
fimotorsports is offline   Reply With Quote
Old 08-10-2003, 09:44 AM   #6
Benjamin Tang
Member#: 4496
2009 Forester
red
so this isn't an uncommon problem? has ne1 else heard of any turbo failures resulting from this?
should i be hitting the salvage yards for a later-model coolant reservoir?
Old 08-10-2003, 10:24 AM   #7
Austin
Member#: 7089
2016 STi
I had paint in mine the first time I removed the cap...
Flush the coolant and remove the supply and return coolant banjos on the turbo to clean them out.
Austin is offline   Reply With Quote
Old 08-10-2003, 10:51 AM   #8
Slvrblt
Member#: 4811
2014 Focus ST
NESIC track Ho #35
theoretically wouldn't the turbo be under warranty if something like that caused it to fail?
I don't remember seeing any paint chips in mine...
speed safely
Brian
Slvrblt is offline   Reply With Quote
Old 08-10-2003, 12:16 PM   #9
Benjamin Tang
Member#: 4496
2009 Forester
red
no warranty. the car was heavily modified. i think it was running a vf30 or a vf34.
Old 08-16-2003, 03:31 PM   #10
TimStevens
Member#: 4817
2012 STI, '02 WRX
'91 MR2, '05 Speed Triple
I just changed my coolant, here's what I saw:
I didn't know to wipe all the paint off, but I'll definitely take off the cap and wipe that down next chance I get...
TimStevens is offline   Reply With Quote
Old 08-16-2003, 03:49 PM   #11
Benjamin Tang
Member#: 4496
2009 Forester
red
Old 08-16-2003, 03:51 PM   #12
TimStevens
Member#: 4817
2012 STI, '02 WRX
So how concerned should I be? I really, really hate my garage and don't want to take it back there.
This is an '02 WRX, BTW.
-tim
Old 08-16-2003, 04:01 PM   #13
cavymeister
Member#: 24463
2003 Chevy S10
91 Hunduh Civic BASE
Pull it off, soak it in toluene and repaint the outside. You'd be moeny when you're done.
cavymeister is offline   Reply With Quote
Old 08-16-2003, 05:05 PM   #14
Benjamin Tang
Member#: 4496
2009 Forester
red
one of the subaru tuner shops locally suggested pulling the reservoir out, flush it, then unbolt the top cover and have it stripped and anodized?
Old 08-24-2003, 12:56 PM   #15
TimStevens
Member#: 4817
2012 STI, '02 WRX
Exclamation
Ok, went to take the cover out and couldn't get the hoses off (got the clamps removed, but the hoses wouldn't budge), so I cleaned off what paint I could by unbolting it and went to put it back together and, clumsy me, dropped one of the bolts into the engine bay and I'll be damned if I can find it...
Anyone know what type of bolt that is, or where I can find the part number? I can't find it in the SSM, and looking through SubaruParts.com this is the best view I can find of that area of the engine:
As you can see it says check "Fig.036" which doesn't help me any.
Old 08-24-2003, 01:29 PM   #16
Austin
Member#: 7089
2016 STi
Was it one of the two bolts securing the coolant tank to the intanke manifold?
Most of the bolts in that area are stubby flanged M8x1.25... but unless you can be more accurate which bolt you lost, that's just a guess.
If it is, just steal one of the bolts from the injector covers (green brackets of death)... you don't need all of them anyway.
Old 08-24-2003, 03:27 PM   #17
TimStevens
Member#: 4817
2012 STI, '02 WRX
Oh, sorry, it's the bolts on the coolant cover, around the radiator cap. The bolts in the pics above. I think there are 5 or 6 of them all-total?
Old 08-24-2003, 04:29 PM   #18
MAD REX
Member#: 18163
2002 2.5 WRX
MBP
Yeah mine looked like that too
MAD REX is offline   Reply With Quote
Old 08-24-2003, 04:34 PM   #19
CpnNeeda
Member#: 20060
02 WRX
Midnight Black Pearl
Default bolts
They are 6mm bolts. Take one of them out and go to Lowes. The have them over in the drawers with the rest of the bolts. I had to replace one when I put in the FMIC. Check it out. If I am not mistaken, they are 6mm.
CpnNeeda is offline   Reply With Quote
Old 08-24-2003, 04:41 PM   #20
firedog25
Member#: 12570
2002 White WRX
'91 Turbo Miata
Originally posted by Benjamin Tang
WORD. Now I have to check mine when I get home!
firedog25 is offline   Reply With Quote
Old 08-24-2003, 05:34 PM   #21
TimStevens
Member#: 4817
2012 STI, '02 WRX
Default Re: bolts
Thanks! I'll stop by tomorrow.
Old 08-24-2003, 07:16 PM   #22
thng
Member#: 8062
This is real news to me. I'm going to have to check this out on mine. However, I don't know what the long term effects are of temp and coolant on a hard anodized surface. I've seen some brake hats that were hard anodized that had some really funky surface finishes after they were repeatedly hit with water from a local car wash. I couldn't tell if it would've flaked later on.
If you do hard anodize, do a search on what the mil-spec requirements are for hard anodize black because there lots of different degrees of hardness and they might have a mil-spec specifically for corrosion protection. The thicker the better but if you go too thick you won't get the bolts back in.
The cover bolts I think are 6 x 1mm but I don't know how long they are (25 or 30mm).
Now I know subaru really rushed production of this model just to get to market. It's no wonder they're all willing to deny warranty to everyone but the granny's that buy this car.
thng is offline   Reply With Quote
Old 08-24-2003, 07:59 PM   #23
TimStevens
Member#: 4817
2012 STI, '02 WRX
Is there any trick to getting the hoses off? I had zero luck... they seemed stuck fast.
Old 08-24-2003, 08:17 PM   #24
Austin
Member#: 7089
2016 STi
Use a heat gun to warm them up. Then use a flat tip screwdriver as a pry bar between the end of the hose and whatever flat surface the hose nipple is mounted in.
Old 08-24-2003, 08:20 PM   #25
Bolster
Member#: 22290
2002 WRB WRX Wagon
So should I yank the top off of my reservoir and strip all the paint off of it?
Bolster is offline   Reply With Quote
Is it safe to move the coolant reservoir? Where All4bSpinnin Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 13 03-21-2008 11:00 PM
Concerned with my Coolant Reservoir any possibly the Headgasket? JeffrWRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 12-04-2006 12:24 AM
Regarding the concern about the new gauge position (pictures) South Coast Subaru Forester Forum 1 06-24-2003 09:31 AM
My concern about the new HKS Downpipe mattjk Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 23 08-18-2002 11:07 PM
