Old 08-04-2003, 10:05 PM   #1
Macabre
Member#: 3841
2004 WRX Wagon
UTEC+VF22+WI
Thumbs up Latest and greatest Autometer gauge bezel (with pics)
Just got mine today and had to run out and install it. It's not the highest quality plastic molding I've seen, lots of flashing I had to clean up. The color also does not match the stock piece, but it looks fine (it's matte black). The gauges are angled towards the driver and on my '04 the bezel doesn't block anything except the "140" on the speedo. The only thing I didn't like was that there's no nub for attaching the rubber flap that covers the hole behind the wheel, but that's nitpicking. I'm very pleased! Vendors are welcome to use these pics if they like but please host them on your own server.
Color comparison
Macabre is offline   Reply With Quote
Old 08-05-2003, 07:32 AM   #2
alster
Member#: 37480
Looks good enough for me. I'm going to get VDO gauges too, because I'm such a cheap bastard!
alster is offline   Reply With Quote
Old 08-05-2003, 08:52 AM   #3
korpse
Member Sales Rating: (5)
Member#: 15386
what size gauges does it hold?
korpse is offline   Reply With Quote
Old 08-05-2003, 10:16 AM   #4
Macabre
Member#: 3841
2004 WRX Wagon
UTEC+VF22+WI
Pictured is 2&1/16th. 52mm should fit fine too.
Old 08-05-2003, 04:12 PM   #5
awoland
Member#: 36455
04 WRX
Platinum Silver
Do they rattle, or make annoying noises??
Thanks,
A.
awoland is offline   Reply With Quote
Old 08-05-2003, 04:39 PM   #6
djerickd
Member Sales Rating: (41)
Member#: 3782
02 WRX WFC#040
Clean on 19's
Where did you get this one from? I'm glad to see it actually fits!
djerickd is offline   Reply With Quote
Old 08-05-2003, 05:17 PM   #7
Macabre
Member#: 3841
2004 WRX Wagon
UTEC+VF22+WI
No rattles or anything that I've noticed. I got it from subarustore.com - don't want to turn this into a vendor review but I would happily do business with them again.
Old 08-05-2003, 05:28 PM   #8
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
I just wanted to make sure I buy from a place that has the updated version.
Old 08-06-2003, 01:03 AM   #9
alster
Member#: 37480
I take that back, I'm going with Omori gauges because I'm a picky bastard!
Old 08-06-2003, 10:01 AM   #10
awoland
Member#: 36455
04 WRX
Platinum Silver
Why not Autometer??
A.
Old 08-06-2003, 02:18 PM   #11
pleue
Member Sales Rating: (13)
Member#: 35469
2002 wrx wagon
mbp
Macabre: any chance of posting a night shot of the setup? I'm curious to see how everything lights up. Thanks.
pleue is offline   Reply With Quote
Old 08-06-2003, 02:38 PM   #12
Macabre
Member#: 3841
2004 WRX Wagon
UTEC+VF22+WI
Sure, but it will be a few days. The gauges aren't actually wired yet, won't have enough daylight to do that until this weekend. I just popped them in to check fitment.
Old 08-06-2003, 09:27 PM   #13
alster
Member#: 37480
Originally posted by awoland
Why not Autometer??
A.
The only gauges that match closest with the dash dials are Omori gauges. Plus they light up like the stock dials. Pricey, but you get what you pay for.
Old 08-08-2003, 01:59 PM   #14
boxer02
Member#: 18037
Platinum Silver
so will the stock turbo gauge fit in their?
boxer02 is offline   Reply With Quote
Old 08-08-2003, 07:49 PM   #15
awoland
Member#: 36455
04 WRX
Platinum Silver
I ordered one
According to the description... It is for 2 1/16" gauges. The factory boost gauge is much smaller than that.
A.
Old 08-10-2003, 04:49 PM   #16
makanouchi
Member#: 18341
Default how did you mount the gauge
Did you use the bracket that came with the gauges? I could not figure out how to secure the gauges to the bezel.
makanouchi is offline   Reply With Quote
Old 08-10-2003, 05:56 PM   #17
djerickd
Member#: 3782
02 WRX WFC#040
Clean on 19's
I just installed mine, looks good! I'm impressed! My greddy gauges slid right in
Old 08-10-2003, 06:00 PM   #18
Macabre
Member#: 3841
2004 WRX Wagon
UTEC+VF22+WI
Default Re: how did you mount the gauge
My boost gauge came with a bracket that bolted onto the back, I used that. The EGT was the type with the "Spin-Lok" mounting clamp and that did not fit so I just slid the gauge in. It's staying in place fine so far.
Old 08-11-2003, 07:03 PM   #19
progresr
Member#: 6772
03 WRB WRX
Cobb Stage 2
Does the finish of the bezel look good enough to just install without working on it first?
progresr is offline   Reply With Quote
Old 08-11-2003, 09:05 PM   #20
awoland
Member#: 36455
04 WRX
Platinum Silver
I just got mine..
Looks great!
Does anyone know how the factory boost gauge works? I haven't looked yet.
Is it electrical, or does it tie into the vaccum lines, like it should? Is its "hook-in" point good enough to use it with my autometer gauge?
Thanks,
A.
Old 08-11-2003, 09:08 PM   #21
Macabre
Member#: 3841
2004 WRX Wagon
UTEC+VF22+WI
The factory gauge T's into the bypass valve hose. It routes through the firewall via a blank grommet that is behind and below the intercooler. The electronics for it hook into a connector behind the radio. The instructions for installing the OEM gauge are available here, just do a search (probably find it easier on scoobymods.com)
Old 08-22-2003, 07:38 PM   #22
salaki
Member Sales Rating: (16)
Member#: 10572
92X N62B44, ST 1050
CGK, LAX, & DFW
Any problems w/ the boost gauge fitting behind?
Sometime the fitting is too long that you have to kinda "force it" to fit.
Thanks...
salaki is offline   Reply With Quote
Old 08-23-2003, 03:35 AM   #23
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
I wouldn't 'force' anything with this bezel, you most likely will break it.
The factory boost gauge is smaller than the openings in the bezel.
The 52mm or 2 1/16 gages fit just fine.
It may be possible to wrap the stock boost gauge(45mm, IIRC) to make it fit better. I would try a wide rubber band, or a piece of bicycle inner-tube to shim the stock gauge.
Old 08-23-2003, 12:35 PM   #24
awoland
Member#: 36455
04 WRX
Platinum Silver
I put an Autometer Boost Gauge in, and the bolts in the back were too long... I am going to cut them off with my dremel. I haven't put the A/F meter in yet, but that is next.
I LOVE it. It is a much better location for the boost gauge than the factory location!!!
A.
Old 08-31-2003, 12:55 AM   #25
Takashi
Member Sales Rating: (1)
Member#: 2536
2012 STi Hatch
well, i'm sold...
i have some sport comp gauges by autometer that i'm having put in pretty soon... anyone know how the cheapest place to get the bezel?
thanks, greg
Takashi is offline   Reply With Quote
Autometer Cluster Gauge Bezel with EGT and Boost Mayhem_Sti Interior/Dressup/Audio & Security 9 05-05-2009 10:57 PM
Autometer cluster bezel with oil pressure and air/fuel ratio gauges gingertooth Interior/Dressup/Audio & Security 31 01-28-2008 08:23 PM
Autometer Cluster Gauge Bezel with EGT and Boost t3rror SCIC Private Classifieds 4 08-08-2007 02:00 PM
SOCAL: Autometer Cluster Gauge Bezel with EGT and Boost t3rror Interior/Dressup/Audio & Security 1 08-08-2007 12:44 PM
IL: Autometer gauge bezel w/ Autometer Boost and EGT Shaitiger Private 'For Sale' Classifieds 5 03-26-2004 11:17 AM
