Old 08-04-2003, 11:10 PM   #1
25psi
Member#: 3086
2001 2.5 RS
Default Torque for spak plugs?
Is there any? And if so what would it be, please.
Thanks
Eugene
25psi is offline   Reply With Quote
Old 08-05-2003, 12:02 AM   #2
Albert
Member#: 3288
1998 Impreza 2.5RS
Rally Blue Pearl
13-17 ft/ lbs
Albert is offline   Reply With Quote
Old 08-05-2003, 03:30 PM   #3
AJ711
Member#: 6178
98 GM67 + 03 SG6
2 whls > 4 whls
And I believe you can cut that down by 1/3 if you're using anti-sieze.
AJ711 is offline   Reply With Quote
02 WRX Wiring colors for Test Plug & Flash plug ai42 Open Source Reflashes 3 08-28-2009 05:30 PM
What are torque specs for two plugs on rear differential? mongolloid Transmission (AT/MT) & Driveline 4 07-07-2009 03:32 AM
Looking for recirc plug for BOV Knightmare69 Tri-State Area Private Classifieds 6 01-24-2008 02:33 PM
What is Torque for lugnuts for Stock '02 Wheels ??? george3 Tire & Wheel 20 01-23-2008 05:16 PM
Torque setting for sump plug SubaH6 Service & Maintenance 0 08-17-2003 08:32 PM
