Old 08-05-2003, 12:11 AM   #1
03WRX83
Member#: 30246
0394 WRX/Supra
WRB/White
Default AccessECUstage1 question.. cobb help..
I have a stage 1 accessecu reflash.. I am only making 14~14.5psi with it, and i have the cobb restrictor in that they have supplied me with.
My current mods are, intake silencer removed and txs uppipe.
I'm suposed to be making 15psi with this stage 1, and ive heard other people have too?
Can i do the 3/16mod with this setup, or add a mbc(which i used to have on the car)???
03WRX83 is offline   Reply With Quote
Old 08-05-2003, 09:18 AM   #2
03WRX83
Member#: 30246
0394 WRX/Supra
WRB/White
bump
Old 08-05-2003, 09:50 AM   #3
KGreb
Member#: 13463
2012 Chevy Volt
From Cobb's AECU FAQ -- target for stage 1 is 14.7 psi +/- 0.5 psi peak. I'd say you're making your target and shouldn't mess with it.
KGreb is offline   Reply With Quote
Old 08-05-2003, 09:56 AM   #4
03WRX83
Member#: 30246
0394 WRX/Supra
WRB/White
ok thanks
Old 08-05-2003, 01:34 PM   #5
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
The FBC will also alter target boost pressure based on ambiant temp and possibly barometric pressure. Being that it is summer, it may go up a little when it cools down. In any case, I think you are fine.
-Jon
Old 08-06-2003, 07:05 PM   #6
Rexxxx
Member#: 26320
2002 WRX Wagon
WR Blue
Definitely,
The heat / humidity has been keeping my boost lower too(.09mpa stock boost gague). Cold dry nights generally hit .1mpa . All winter it would hit .1, always.
I have JDM up-pipe but stock restrictor. The supplied one caused spikes and wavering.
Rexxxx is offline   Reply With Quote
Old 08-07-2003, 07:43 PM   #7
brizey
Member#: 36505
2004 Forester XT PSM
2007 Acura RDX w/Tech CBP
I just put my stage 1 in last night (stock restrictor). I could barely hit 0.09 today, but it was well over 100 degrees. Makes it hard to evaluate. I may get up early tomorrow and go for a drive while it is still in the 70's. I hit 0.095 last night and it was about 90 degrees.
brizey is offline   Reply With Quote
Old 08-07-2003, 09:11 PM   #8
DAVE98RS
Member#: 525
<<98 2.5RS(RIP)>>
02, Cobb stg 2.5, FMIC
I think it needs to be cooler and dryer. When I first got my stage 1 (93 octane) it was late spring and not hot and humid like now. My boost is a little lower now than before but I attribute that to the weather. Although I still get 1.0 now I was getting 1.1-1.2 back then. I'm NOT using the tube/restrictor that Cobb sent me. I have a Stage 1 (mapped for the Injen CAI), Vishnu uppipe, Blitz nur rear sec.
DAVE98RS is offline   Reply With Quote
Old 08-07-2003, 09:53 PM   #9
brizey
Member#: 36505
I just went out for a drive. I hit about .098 in fifth gear, which is the highest I have ever seen the boost get on my car. It is still pretty hot out, maybe in the upper nineties (Dallas sux this time of year).
Old 08-07-2003, 10:51 PM   #10
pc109
Member#: 23746
what boost are you getting in 1st? Is it lower than the rest of the gears?
pc109 is offline   Reply With Quote
Old 08-09-2003, 09:35 AM   #11
brizey
Member#: 36505
pc109:
I find it hard to read the gauge in first gear. I am still getting used to the sound of the reflashed ECU, so I have to concentrate on the tach to shift. I will try to get a reading today, but it is still warm here in the big D (storm on the way this morning, though).
I think the peak is maybe only a little higher in first. It definitely pulls harder in the upper rpm range (6000-7000), and in first that probably means a higher peak. (In second and third, the peak is higher and it hold the peak longer.)
Old 08-09-2003, 11:28 PM   #12
FreeBSD_WRX
Member#: 30154
Midnight Black Pearl
I'm also running the AccessECU Stage1 for 91 octane, though I always make a point of putting the highest octane in I can find; usually 93. I went for the 91 oct. map for a slight margin of safety.
Anyway, I was just curious whether anyone else has decided to run with colder plugs. I know that Cobb doesn't sell them or mention anything about colder plugs being necessary, but was just curious. Just want to avoid detonation at all costs.
Thanks!
FreeBSD_WRX is offline   Reply With Quote
need cobb help from someone with a cobb accessport bullmonkey118 Mid West Subaru Owners Club Forum -- MWSOC 1 08-14-2009 05:46 PM
cobb AP question please help dye.sti Newbies & FAQs 3 06-07-2008 08:41 PM
Cobb Accessport question, please help! turbo tecnica Engine Management & Tuning 5 09-01-2005 10:30 PM
('93-'01) please help!! 98 GC8 bumper conversion question, please help!! nateconnella Impreza Forum 10 05-13-2003 05:50 PM
('93-'01) please help!! 98 GC8 bumper conversion question, please help!! nateconnella Impreza Forum 1 05-05-2003 10:11 PM
