Old 08-05-2003, 12:46 PM   #1
larsch13
Member#: 1537
1995 Impreza
red
Default 2000 2.5 oil pressure
Please help me. What is the typical oil pressure of a 2.5 phase II engine. I am seeing over 80psi when my engine is warm is this correct? thanks
larsch13 is offline   Reply With Quote
Old 08-05-2003, 04:33 PM   #2
25psi
Member#: 3086
2001 2.5 RS
At crusing at about 70 yes.
Eugene
25psi is offline   Reply With Quote
Old 08-06-2003, 11:30 AM   #3
goobie
Member#: 8273
2006 WRX Wagon
larsch13,
What brand/grade of oil are you running? I have been running Mobil 1 Synthetic 5W30 and I see about 80+ on "cold" oil then as the oil comes up to temp (about 150-180 deg F) I see about 60psi at cruise at about 3500 RPM...
My guage is an autometer mechanical gauge which recieves it's oil feed from the secondary oil gallery (near the throttle body).
Is my oil pressure unusually low? I guess the guage could be off a bit (bought it used).
Can others please post oil pressure readings at similar conditions that I mentioned above?
Thanks,
Chad
goobie is offline   Reply With Quote
Old 08-06-2003, 01:03 PM   #4
25psi
Member#: 3086
2001 2.5 RS
10w30 Mobil1 Full Syntetic. Using place whrere stock sender use to be. Autometer electric gauge.
Close to 100 at cold days. Bout 75-80 after engine fully warms up and crusing at 3500-4000.
Bout 15-25 at idle.
MY01 2.5RS
Eugene
Old 08-06-2003, 06:37 PM   #5
svxr8dr
Member#: 1702
2001 2.5 RS-T
Blueridge Pearl
my 2001 RS runs pretty much idetical to what 25psi posted. I'm using Autometer phantom gauges.
svxr8dr is offline   Reply With Quote
Old 08-06-2003, 11:09 PM   #6
larsch13
Member#: 1537
1995 Impreza
red
Default oil pressure
Thanks everyone, my oil pressure gauge only goes to 80psi, and it is constantly pegged at startup, after warmup anything over
3k rpm pegs the gauge.
Old 08-07-2003, 07:25 AM   #7
25psi
Member#: 3086
2001 2.5 RS
New gauge time
25psi
Old 08-07-2003, 09:33 PM   #8
goobie
Member#: 8273
2006 WRX Wagon
I wonder if the decrepancy in my oil pressure and yours is a function of me using a lighter grade (5W30) of oil or my gauge could be off about 10 PSI. But I too see about 15-25 PSI at idle.
Hmm....
Anyone else care to comment on their oil pressure and grade/brand of oil at various operating conditions?
Thanks,
Chad
1996 2.2 Intake on 2000 2.5 Odyknuck Subaru Conversions 1 01-22-2009 09:32 PM
engine swap 2004 2.5 sohc to 2000 2.5 sohc rickinne General Community 4 06-08-2006 05:29 PM
2000 Impreza L harness same as 2000 2.5 RS? BenBortner Subaru Conversions 7 03-04-2005 01:56 AM
2.5 oil pressure locations wcbjr Normally Aspirated with bolt-on Forced Induction Powertrain 6 06-04-2002 03:15 PM
Does the WRX use the same oil filter as the 2000 2.5 RS? SuperFreq Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 10-19-2001 01:58 PM
