Old 08-05-2003, 12:46 PM   #1
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
Default MAP signal
im installing a SAFC and im planning on using the MAP instead of TPS. looking at the ECU printouts i have, i dont see anything to do with MAP or anything like that. so where do i wire it up to intercept the MAP signal?
scoobyimprza is offline   Reply With Quote
Old 08-05-2003, 12:55 PM   #2
ImportInvasion
Member#: 9016
1995 Impreza L-turbo
JDM EJ20 conversion
none of the 93 Impreza's I have seen have a MAP sensor. They use MAF and TPS to judge engine load.
ImportInvasion is offline   Reply With Quote
Old 08-05-2003, 01:07 PM   #3
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
can i wire a MAP sensor? do u know what im trying to do? should i just wire the MAF and TPS?
Old 08-05-2003, 01:10 PM   #4
Imprezd
Member#: 3357
you will need a seperate map sensor to do this since the car doesn't have a map sensor.
iMprezD~
Imprezd is offline   Reply With Quote
Old 08-05-2003, 01:11 PM   #5
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
so i should just suck it up and wire the MAF and TPS? btw, which wire should i use for a ground off the ECU?
Old 08-05-2003, 01:13 PM   #6
Imprezd
Member#: 3357
if you can wait i would wire it up to the Map sensor since.. i think i know what road you are going down and the car doesn't have any compensation for boost.
Old 08-05-2003, 01:22 PM   #7
ImportInvasion
Member#: 9016
JDM EJ20 conversion
like Imprezd said, if you are planning on turboing, then a MAP sensor would be better. You can just buy a GM one i would think and use that with the SAFC.
As far as the ground wire, i couldnt tell you without seeing a diagram. You could just run a wire to the chassy or engine for a ground.
Old 08-05-2003, 01:28 PM   #8
scoobyimprza
Member#: 24956
1997 Impreza WRX
Steel Blue Mica
noah, didnt you install a SAFC on your car? when i install the MAP sensor, do i just tap into the manifold and run lines to the sensor?
Old 08-05-2003, 01:40 PM   #9
ImportInvasion
Member#: 9016
JDM EJ20 conversion
No, i installed a Link Plus on my car. I would just use a vaccum T connector off one of the vaccum lines that come off the intake manifold and connect that to the MAP sensor.
Devils Own MAP sensor signal problem ElSpa Water/Methanol Injection, Nitrous & Intercooler Cooling 10 03-13-2009 08:01 PM
UTEC clamping MAP signal to ECU? testes1010 UTEC 16 05-21-2008 12:16 AM
Link Plus and MAP signal (MY00 2.5RS) erice1984 Engine Management & Tuning 3 03-05-2005 03:27 PM
UTEC shows NO TPS signal NO MAP, and no air or coolant temps. jared nelson Engine Management & Tuning 4 12-20-2004 05:47 PM
MAF or MAP signal for Emanage?? GTR STI Engine Management & Tuning 4 02-18-2004 01:31 AM
