Old 08-05-2003, 01:38 PM   #1
firedust
Member#: 38795
2003 WRX
Sonic Yellow
Default Flat tire question...
The manual says an Auto WRX shouold be switched to FWD when using a spare. It doesnt specify if it matters w hether the doughnut is on the front or rear of the car...
also, when my dad picked up my car for me, the dealer told him the same but i have a 5MT, nothing in the manual about this...does any one know?
if i cant get answers obviously ill call a dealership..
thanks
VJ
firedust is offline   Reply With Quote
Old 08-05-2003, 02:34 PM   #2
KC
Member#: 442
13 Crosstrek XV
00 S2000
Only the Automatic can be towed following the instructions in the book.
A 5 speed Subaru MUST be flat-bedded.
If a dealer was saying that a 5sp can be towed with 2 wheels on the ground... run away from them as fast as you can.... run Forrest! Run!
--kC
KC is offline   Reply With Quote
Old 08-05-2003, 02:35 PM   #3
Austin
Member#: 7089
2016 STi
The donut should be on the front of an auto wrx, and you should pull the fwd fuse.
A 5MT wrx can not be shifted out of AWD - you'll always have a viscous center diff and a viscous rear diff. You should still put the donut on the front, but it's best to simply not drive on the spare tire.
Austin is offline   Reply With Quote
Old 08-05-2003, 02:42 PM   #4
KC
Member#: 442
13 Crosstrek XV
00 S2000
OOps I forgot that part.
Yes, while it would be better to have flat tires always in the front, on the side of the highway, the scissor jack supplied cannot get both wheels into the air because of the long travel of the WRX struts, thus negating the opportuntity to switch wheels in a timely manner.
An aftermarket suspension will probably be stiff enough that the scissor jack in the location under the sill will get both the front and rear tires far enough off the ground that they can both be changed... and THEN you can swap the wheels using the donut in the front. But on the stock suspension, it's not a viable solution.
The donut can go on any wheel, just get that flat fixed asap.
The donut is the SAME circumfrence as a stock tire and would not cause any issues. Just follow what it says on the donut and the manual not to exceed certain speeds while it's on.
--KC
Newb flat tire question Knotsure Newbies & FAQs 10 02-15-2009 11:08 PM
Question about flat tires and Subies AWD setup scramjett Transmission (AT/MT) & Driveline 2 01-25-2009 05:17 PM
FLAT TIRE! very noobish question bnr34rb26dett Newbies & FAQs 72 09-23-2008 05:17 PM
Flat tire! : ( Tire n00b. Zippy1529 Tire & Wheel 7 11-29-2004 05:15 PM
Flat tire, replace all tires? whitet777 Newbies & FAQs 13 06-25-2002 09:04 AM
