Old 08-05-2003, 01:53 PM   #1
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
Default target a/f ratio and boost
is there a chart of some kind that showes desired a/f in relation to boost
or is this a lean-till-it pings sort of thing
Old 08-05-2003, 11:22 PM   #2
bobsterswrx
Member#: 31555
Most of the tuners I talk to set A/F based on octane used. You can run higher ratios with C16 vs pump gas. For 91 we are at appox 10.5-10.7:1 and at 95 oct we are closer to11:1. I noticed as we increased boost we did not need to increase fuel much once we had a good map for the fuel we were using. I'm not an expert but 2+2 usually = 4 and that's what I observed.
Bob
bobsterswrx is offline   Reply With Quote
Old 08-07-2003, 09:59 AM   #3
NavyBlueSubaru
Member#: 22127
2013 BMW 335i Sedan
Estoril Blue
Using 93 octane i like to run around 12.5:1 afr at full boost, i.e. 18psi. This is water injection, of course heh I think turboxs aims for 10.5 - 10.7 :1 as their afr for most of their stages.
Jeff
NavyBlueSubaru is offline   Reply With Quote
Old 08-07-2003, 10:12 AM   #4
RiftsWRX
Member#: 6124
2000 NFR AP1 S2000
'07 Honda FIT sport (5MT)
Jeff
LOL! was going to say... until I saw the water injection comment hehe
11.3-11.5 is "doable" on 93, just takes vigilant tuning... for a race type map that's ok... but day to day your stock internals won't like the 1600+egt's for very long.
Jorge (RiftsWRX)
www.ProjectWRX.com
RiftsWRX is offline   Reply With Quote
Old 08-07-2003, 12:29 PM   #5
Austin
Member#: 7089
05 Legacy GT Sedan
07 4Runner Limited
Jared - I tune for 10.8 - 11.0 up to about 5800rpm, then work down to ~10.5 @ 7200rpm.
Austin is offline   Reply With Quote
Old 08-07-2003, 09:19 PM   #6
skywalker
Member#: 1990
I have been doing pretty well running 11.5:1 on California 91 octane gas.
Though if you are speaking theoretically the optimal level is 14.5:1 for most power. Of course we all know that this doesn't happen in real life. There are a lot of factors and lots of those factors come down to the reliablility of the engine itself. I have noticed some Subaru engines just don't like to run 11.5:1 at all, just the way it is. But some can go up to 12.5:1 like my RS with a Turbo Kit, loved it right there, and I was making lots of power.
The EGT's would reach about 1600 max, but that was fine for what I was doing. That is another thing to watch out for, if you want your EGT lower add more fuel. Of course doing this you lose power. Bigger bang causes more power but more heat.
skywalker is offline   Reply With Quote
Old 08-07-2003, 11:35 PM   #7
MAD REX
Member#: 18163
2002 2.5 WRX
MBP
What about afr's when off boost?
I have a 18g that doesn't start making positive boost til 3k rpm's or somewhere around there.
I've been watching the Utec dashboard and when I'm at WOT from 1500 rpm's to 3000 the afr is about 13.1:1 to 13.3:1
Is that too high to low or ok? I'm trying to get it to spool faster.
MAD REX is offline   Reply With Quote
Old 08-08-2003, 02:46 PM   #8
skywalker
Member#: 1990
The only way to really know if it is too high or not is to measure your EGT's also and to check the spark plugs to see how they look. From my initial guess though you are probably running a little leaner then you should.
Does the car ping at all? What O2 sensor are you reading off of, the front or rear? That makes a difference also.
Just some things to think about.
Learning Gear Ratio and Final Drive Ratio madwrxing Transmission (AT/MT) & Driveline 0 04-16-2006 10:02 PM
Oil Pressure, A/F Ratio, and Boost gauge install kicking1012003 Interior & Exterior Modification 4 08-01-2005 09:35 AM
Utec dyno plots and target A/F ratios and some tuning advice. nmyeti Engine Management & Tuning 39 10-15-2002 02:29 AM
Gear ratios and differential ratio for 95 legacy and 95 imprezza ciper Transmission (AT/MT) & Driveline 0 06-14-2002 06:58 PM
Theory: Compression Ratio vs. Boost Pressure 8Complex Normally Aspirated Powertrain 12 11-29-2000 05:30 PM
Message Board Statistics All times are GMT -4. The time now is 03:16 PM.
