Old 06-15-2001, 03:03 PM   #1
Shik
Member#: 132
2006 GT Ltd 5spd sdn
2015 WRX 6spd CWP
Question EJ22T Up-Pipe Compatibility?
Just curious if any of you guys have tried or know if the factory cat-less up-pipe from the 91-94 Legacy Turbo's are a direct bolt-in replacement for the factory WRX up-pipe with cat? The flanges look identical, but I don't know about the length, bend, etc. The older WRX headers and the Legacy Turbo headers were just about identical IIRC.
Subaruparts.com has them listed for $187.03 I think. If they fit, just have the O2 bung put in by a muffler shop and your set. Not trying to sell Shiv or BPM short, just curious if they would work. Might be especially helpful for those who know where a few Legacy Turbo's are sitting in salvage yards as well.
-Matt
Edit: Part number is 44104 AA010 and comes with heat shields I believe.
[ June 15, 2001: Message edited by: Shik ]
Shik is offline   Reply With Quote
Old 06-15-2001, 05:06 PM   #2
GDA
Member#: 4324
02 GDA
Platinum
Post
that would be interesting to know, if someone only had a picture of one to spare.
EJ20WRX
GDA is offline   Reply With Quote
Old 06-15-2001, 07:11 PM   #3
Imprezer
Dynamic Uno
Member#: 1
2011 Impreza WRX STi
Post
for $187 you get a stock skinny uppipe without a EGT bung. Add $20 and you have a stock skinny uppipe with an ugly weld for an EGT. But, for ~100 more you can have a race quality uppipe from Vishnu, for example. Why bother with a stock pipe?
Imprezer is offline   Reply With Quote
Old 06-18-2001, 06:59 PM   #4
Shik
Member#: 132
2015 WRX 6spd CWP
Ugg.
Why bother?...Why not?
If you truly know that the aftermarket up-pipes, like Vishnu's for example, give an extrodinary increase in performance over a stock EJ20/EJ22T factory catless up-pipe(no speculation based on looks or reputation), then I would say, yes, don't waste your money and time with a factory up-pipe.
But who is to say that the factory cat-less up-pipes don't provide a substantial increase themselves and that by going to an aftermarket up-pipe would have minimal gains, if any, over a OEM cat-less up-pipe?!?The fact is, I don't know. Hell, I don't even know that it would fit. But it would be nice to know if it would fit, and regardless of how it looks or will look after you get the oh-so-ugly bung welded in, I will go out on a limb and say that a factory cat-less up-pipe would outperform the OEM up-pipe that's on my WRX right now.
And not for nothing, but, although there has been mixed opinions, it has been said time and time again from many different tuners that, despite their looks, the factory header system(two manifolds, cross-over pipe, up-pipe) on the WRX's do not pose a much of a performance hinderance. Sure the WRC car doesn't use stock headers, but they are also trying to get 300+ hp and 400+ lbs/tq sucking through a 32mm restrictor, they need all the help they can get. That being said, I'm sure the factory cat-less up-pipe would work just fine for me, going by it's track record from years past. I don't always need the biggest and best of everything(not implying anything, just speaking for me personally).
-Matt
FS : EJ22T Heads, Turbo, Intake, Exhaust, Up-pipe. xmoshx Engine/Power/Exhaust 10 03-10-2011 08:45 AM
FS: Stock 04 WRX exhaust jouka NESIC Private Classifieds 24 06-22-2010 10:54 AM
What bolts/Nuts for Up pipe? subaru_steve Newbies & FAQs 0 06-01-2010 11:17 AM
ej22t, vf10, legacy up pipe $200 heelhooker Engine/Power/Exhaust 5 11-11-2006 03:56 PM
Will an ej20/ ej25 up-pipe fit my ej22t? lotus2843 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 12-17-2004 05:16 PM
