Old 06-15-2001, 04:41 PM   #1
harrydog
Member#: 3773
2002 WRX Sedan
2006 Outback 3.0R
Post 180 deg. thermostat
I know it is common practice to switch to a lower temp. thermostat for performance reasons and while I know many of the German and American car owners do it I don't recall hearing it mentioned in these forums.
Is there a reason why I shouldn't do it? Who sells them?
harrydog is offline   Reply With Quote
Old 06-15-2001, 05:33 PM   #2
LVSUBARU
Member#: 4520
93 STi V.4 RA
www.flat4lv.com
Post
If your car runs cold you can build up carbon deposits in your combustion chambers alot quicker, and you will defineitly loose gas milage.......your tail pipe emissions will suffer too.
LVSUBARU is offline   Reply With Quote
Old 06-15-2001, 05:52 PM   #3
Jan Shim
Member#: 6366
1998 WRX Wagon (Ret)
Post
If the US spec WRX shares the same thermostat as Japanese/Euro/Aus spec WRX, the thermostat opens at 76C (169F). When temps reach 96C (205F) fan kicks when vehicle speed exceeds 19kph/12mph.
A 82C(180F) thermostat will delay the opening 6c later which is no big deal really. I have an ARC (Abbey Road Company) 68C (154F) thermostat that I am going to fit as soon as I get my hands on a bottle of RedLine WaterWetter and 7 litres of distilled water.
Jan Shim is offline   Reply With Quote
Old 06-18-2001, 07:52 PM   #4
harrydog
Member#: 3773
2002 WRX Sedan
2006 Outback 3.0R
I guess the theory is that if the coolant is running cooler (180 deg rather than 210 deg, or whatever) then the head temps would be slightly lower and should result in less chance of detonation.
Old 06-19-2001, 07:29 AM   #5
AndyHidley
Member#: 1031
Default Is it true?
OK here is what has happened here in the states with "other" cars... The ECU monitors engine temp. when its not up to "operating temp" the ECU assums that the engine has just started and is warming up, thus running a richer mixture. People here have put in a coolder thermostat and caused poor running, clogged catts/O2 sensors, poor milage, etc... Keep an eye on this "possible" problem. Please post if you have a problem with running cooler temps........................
AndyHidley is offline   Reply With Quote
Help: Mocal 20mm Oil Sandwich plate with built in 180 thermostat not fitting chrisarella Built Motor Discussion 23 03-30-2010 04:05 PM
Zerosports 180 Degree Thermostat Drink Engine/Power/Exhaust 5 02-19-2007 12:41 AM
Chi NW burbs... 180 Degree Zerosport Thermostat Wrx/STi Drink MWSOC Private Classifieds 1 02-08-2007 11:28 PM
rotating coolant manifold 180 deg. SamTheMan Subaru Conversions 9 01-18-2006 10:09 PM
Thermostat Question - Can I replace a analog thermostat with a digital one? Cjchaps Off-Topic 5 12-16-2005 12:16 PM
