Old 08-05-2003, 05:45 PM   #1
spiralsmurf
Member#: 16085
2005 STi
Default Clunking when starting
About half the time i start my car, it makes this loud clunk the second it starts. Have anyone experienced this?
spiralsmurf is offline   Reply With Quote
Old 08-05-2003, 08:46 PM   #2
tekfoc
Member#: 21392
2014 45 AMG MB
WHITE /MB C300 4MATIC
its a loose motor mount or transmision mount have it checked or check it your self good luck
tekfoc is offline   Reply With Quote
Old 08-05-2003, 11:55 PM   #3
mike270
Member#: 12863
2002 2.5RS
Do you have an intake?
If you do it could be the tubing around the fender hole. I have a ganzflow and it made the exact same noise on start up sometimes and i found that the tubing had fallen out and the metal was hitting metal when the engine turned over.
mike270 is offline   Reply With Quote
Clunking noise when starting in 1st MAD REX Transmission (AT/MT) & Driveline 16 02-06-2009 01:14 PM
Weird clunk and then nothing when starting... MT_WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 05-04-2005 10:19 PM
1st Gear Clunk and Slipping Out of Gear When Starting? Killian Maynard Transmission (AT/MT) & Driveline 5 01-31-2005 08:20 PM
Help, a clunk when i start and shift DangeRS Transmission (AT/MT) & Driveline 2 02-20-2002 02:47 PM
Clunk clunk! when braking inzomniac General Forum Archive 2 02-24-2001 06:38 PM
