Old 08-05-2003, 07:52 PM   #1
optimusprimerib
Member#: 23665
1997 Legacy GT
Red
Default Help me select tire size for stock '97 GT...please.
I know that the factory size is 205/55-16, but I was wondering if I could fit a wider tire. I am using stock GT wheels. I'd like to retain the stock sidewall height, in order to prevent false odometer/speedometer readings. Have any of you experimented with this?
optimusprimerib is offline   Reply With Quote
Old 08-05-2003, 08:22 PM   #2
gtwagon941
Member#: 16874
2008 2008 Audi RS 4
2014 Audi S Q5
you probably will get the best results for this question if you post on the tire/wheel forum. Luke at the tirerack moderates it and pretty much knows all, or at least it seems...
gtwagon941 is offline   Reply With Quote
Old 08-05-2003, 08:26 PM   #3
optimusprimerib
Member#: 23665
1997 Legacy GT
Red
Thanks, man.
Old 08-05-2003, 10:29 PM   #4
Charlie-III
Member#: 30669
1998 Legacy 2.5GT
Silver Sleeper Wagon
Try this for correct sizes.
Then go to Tire Rack to pick a tire.[
Old 08-05-2003, 11:11 PM   #5
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
A 225/50-16 will maintain the stock rolling size, but you really won't see any benefit. The 6.5" wheel just isn't wide enough to make full use of the added width of the tire. The sidewalls will be pulled in, which means you'll end up with a contact patch that's no bigger than it would be with "correct" size 205s on there.
Either invest in some wider wheels ('98-01 2.5RS wheels were 16x7"), or just stick with the stock tire size.
Pat Olsen
'97 Legacy 2.5GT sedan
Old 08-06-2003, 12:15 AM   #6
optimusprimerib
Member#: 23665
1997 Legacy GT
Red
Thanks, Pat. How about 215/55-16? Aer the 6.5" wheels sufficient for them? Will they fit w/out rubbing?
Old 08-06-2003, 12:55 PM   #7
parklax
Member#: 25178
97 Legacy 2.5
white
just curious, but why would u want more sidewall while maintaining the same width?
Phil
parklax is offline   Reply With Quote
Max tire size for stock tires? kylelikewhoa Tire & Wheel 4 09-21-2007 03:20 AM
Tire Size For Stock WRX Rims? InsaneAznKid Newbies & FAQs 13 05-26-2004 03:27 PM
Help me with tire sizing Zackbo Tire & Wheel 1 03-27-2004 08:46 PM
Please help me choose tire size... T-WREXX Tire & Wheel 1 03-09-2004 03:33 PM
Help me select tire size for stock '97 GT...please. optimusprimerib Tire & Wheel 8 08-06-2003 07:38 PM
