Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 08-05-2003, 11:22 PM   #1
subawang
Member#: 17515
2007 Legacy GT
Brilliant Silver Metallic
Default creaking noise upon start-up and shut-off
ok, here's the problem. . .upon starting up the engine and shutting off the engine there is a creaking sound coming from the passenger side of the engine bay. it only occurs when I start or shut off the engine. bad motor mount?? any and all suggestions or opinions would be appreciated.
I'm figuring to just have my subie dealer look at it. its gonna be in the shop anyways this friday for front brake pads, rear pads and rotors. has anyone else worn through their rear rotors yet? I don't autox by the way. thanks guys
Rob
subawang is offline   Reply With Quote
Old 08-05-2003, 11:57 PM   #2
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Does it continue for a short amount of time after the car is off?
Old 08-06-2003, 12:00 AM   #3
subawang
Member#: 17515
2007 Legacy GT
maybe 0.5 to 1 second max. so it pretty much settles as soon as the engine settles. am I making sense? anyway, thanks for any help guys
Old 08-06-2003, 12:22 AM   #4
obyone
Member#: 16523
this anymore???
Any mods to the engine or engine bay?
obyone is offline   Reply With Quote
Old 08-06-2003, 12:26 AM   #5
subawang
Member#: 17515
2007 Legacy GT
only cobb intake, but its definitely not that, I've had it on for about a year now.
Old 08-06-2003, 12:48 AM   #6
mike270
Member#: 12863
2002 2.5RS
Donno about the cobb but my ganzflow made the exact same sound. Found out it was the tubing around the fender hole had fallen out.
Like I said I don't know if the cobb uses this as well but if it does its a good place to start.
mike270 is offline   Reply With Quote
Old 08-06-2003, 12:56 AM   #7
subawang
Member#: 17515
2007 Legacy GT
please don't shoot me. . .I went to check out the engine bay to see if I could see what was causing the noise. . .it turns out that the silicon protector that covers the intake around the fender hole had slid out of place. adjusted the silicon protector and no more noise. thanks for the help guys. I feel like such a moron~~
Old 08-06-2003, 02:46 PM   #8
mike270
Member#: 12863
2002 2.5RS
Don't worry....Just glad we could help you get it fixed
I know the feeling too. I have done it myself way too many times
Old 08-06-2003, 08:14 PM   #9
obyone
Member#: 16523
this anymore???
That's what I was about to say. The same thing happens to me. Try cleaning the inner part of the rubber and the exterior of the aluminum pipe to keep it from sliding around again. It slides around because of the dirt in between them.
After a long drive and shut off for 10 minutes, wouldn't start afterwards... elitescouter Newbies & FAQs 4 03-14-2010 01:24 AM
TGV codes and misfire code upon start up eliezerrosario Service & Maintenance 3 07-03-2009 06:27 PM
Loud engine noise after start up kalex Newbies & FAQs 10 09-13-2002 01:48 PM
Noise on start up in the morning... Karl New England Impreza Club Forum -- NESIC 5 07-23-2002 11:16 PM
Valve(?) noise at start-up keiper Legacy Forum 1 06-23-2000 10:39 PM
