08-06-2003, 02:22 AM | #1 |
Member#: 36349
Vehicle:2003 wrx wrblue |
proform shift light any good?
Ok i went to a shop today to get just the shift light. all they had was the ones that needs a chip. When totalling everything up....it got prety expensive. So i went on ebay and saw these proform adjustable shift lights that doesn't need a chip. it was pretty cheap too. Has neone used these and can tell me a little about them? They don't sound that bad so if you guys can tell me ne different i think i am gonna buy this one. look out after me guys. thanks
08-06-2003, 10:46 AM | #2 |
Member#: 15106
what's that "clip" you're talking about? do you mean pills?
my autometer one (large one) was about $100 total with shipping, etc. I think. I bought a bag of pills too. |
08-06-2003, 03:16 PM | #3 |
Add Lightness
Moderator Member#: 13699
NESIC
Vehicle:2021 Building It Better |
I have a proform shift light that I'm attempting to put into a Neon racecar. I say "attempt" because first shot got no output from the shift light. I installed a tach on the signal to see if it was where I thought it was. The tach works fine. I will be attempting to pull the signal right from the ECU tonight. The light is normally $39 from Summit Racing, by the way. I've heard that if you use the light that you can't use a tach too. Both won't work on the same line.
jack |
08-07-2003, 05:01 PM | #4 |
Member#: 41379
proform/any shiftlight help
My shop is attempting to install a proform adjustable shift light on an 02 WRX. We were told not to use a tach adapter and to hook the green wire to the green wire with the red stripe coming out of the back of the instrument cluster. It is blinking at ignition but not firing at the selected rpm range. Please help!!!!!!!!!!!!
Apex'i auto timer and Proform shift light FS | Lachlan | Private 'For Sale' Classifieds | 3 | 02-01-2005 12:42 AM |
Proform Shift Light | Lachlan | Electrical & Lighting | 10 | 02-01-2004 09:44 AM |
Using Instrument Cluster Light as Shift Light/Any Ideas? | jikhead | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 1 | 06-21-2003 09:08 PM |
Need help installing Proform Shift Light 67005c. | javier2971 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 4 | 01-29-2002 08:21 AM |
('93-'01) Are the factory fog lights any good in the fog? | driver | Impreza Forum | 1 | 07-14-2001 01:16 PM |
