Go Back   NASIOC > NASIOC Archives > NASIOC Archives > STi Forum Archive
Old 08-06-2003, 09:55 AM   #1
Karter
Member#: 35838
2004 STi
Default Dealer wont align car to my specifications....
Hello-
Just wondering if anyone has run into this problem. I am trying to buy and STI, and have requested that they align the car to my specifications when they deliver it. I have agreed to pay for the alignment, I have no problem with that.
They are saying that I have requested something that will "void the Subaru warranty" which is my favorite line in the world.
I have asked that they align the car as follows:
As much negative camber in front as they can get, equal on each side. I said I expected they could get somewhere around -1 to -1.3 degrees. And to also do the same in the rear, somewhere are -1 to -1.4. Lastly I asked for zero toe front and rear.
Am I out of line here? Has anyone else faced this? Does anyone have the service manual which shows the factoried specified range?
Michael
Karter is offline
Old 08-06-2003, 10:04 AM   #2
Silver-Bolt
Member#: 40189
2004 STi
Silver/Silver
Dealer is just covering their butt. If you should happen to have an accident or even just tire wear problem they are afraid you would go after them. Most dealers do not do in house alignments so just take it to an alignment shop and have it done. That way the dealer doesn't get to drive your car to the alignment shop for you.
Silver-Bolt is offline
Old 08-06-2003, 10:09 AM   #3
Karter
Member#: 35838
2004 STi
They are an Audi dealer as well, so they have a great alignment rack, so that is not an issue. Seems unreasonable to me, because last I checked I am the one paying for the car.....
Michael
Karter is offline
Old 08-06-2003, 11:10 AM   #4
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
Just go somewhere else; also the rear camber is not adjustable.
ANZAC_1915 is offline
Old 08-06-2003, 12:11 PM   #5
ll PaSt ll
Member#: 24623
2007 Impreza
I haven't really looked but I think both front and rear camber aren't adjustable, unless you get upper pillows for both front and rear.
Just drop the car and hope the camber goes to that negative spec.
ll PaSt ll is offline
Old 08-06-2003, 12:39 PM   #6
afpdl
Member#: 26361
My shenanigans are
cheeky and fun
front camber is adjustable.
afpdl is offline
Old 08-06-2003, 12:49 PM   #7
Austin
Member#: 7089
2016 STi
Front camber is adjustable by an eccentric (crash) bolt, rear camber isn't technically adjustable, but you could probably get a range of 2/10 or 3/10 degrees by pushing/pulling.
The dealer you're going to has an actual laser alignment rack? I've never seen that before...
Austin is offline
Old 08-06-2003, 01:31 PM   #8
G-shock
Member#: 36545
Whats new!!! !
Dealers can only set the car to whatever specs they specify from the factory. Not only that, but as long as the values are within the "range" they won't even touch it...and that "range" covers a lot of territory. Most alignment shops won't go out of factory spec either!
You have to call around!!
My alignment was even out of factory spec and I still didn't go to the dealer, cause I knew I'd just have to go to a shop afterwards to get my custom specs.
G-shock is offline
Old 08-06-2003, 01:39 PM   #9
Karter
Member#: 35838
2004 STi
We came to a quasi compromise. They agreed to adjust to the most "radical" allowed by the factory. Looks like that is -.75 on each side in front.....
Sometimes you really have to wonder.
Thanks everyone.
Michael
Karter is offline
Old 08-06-2003, 05:14 PM   #10
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
Why not just go somewhere else if they won't do what you want?
Old 08-06-2003, 05:27 PM   #11
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
funny thing is that the "spec" is a range and the values you quoted are within that range .. take it some where else
Jaxx is offline
Old 08-06-2003, 08:28 PM   #12
Karter
Member#: 35838
2004 STi
Jaxx-
The dealer claimed that the allowable range, per their service manual was -.3 + or - .45...this being for the front of course. Thus they "allowed" me to have it set at -.75degrees. They would not fax me the page from the service manual so I could see it.
Anyway, I will see how this feels for now, and look for a better shop to help me out. We have limited resources in Vermont.
Michael
Karter is offline
Old 08-06-2003, 11:05 PM   #13
Austin
Member#: 7089
2016 STi
There's a scan from the service manual for Impreza alignment specs.
Austin is offline
Old 08-06-2003, 11:07 PM   #14
Austin
Member#: 7089
2016 STi
That's a scan from the owner's manual for Impreza alignment specs.
Austin is offline
Old 08-06-2003, 11:15 PM   #15
Austin
Member#: 7089
2016 STi
Those were both MY04 documents, by the way.
The FSM gives rear camber as -0.67 degrees. The owner's manual gives rear camber as -1.67 degrees. Obviously one is a misprint... I would be inclined to say that the service manual is a misprint & that the owner's manual has the correct (intended) camber alignment spec.
Both sources give front camber as -0.5 degrees. Spec range is given as +/- 0.75 degrees.
So, your dealer should have no problem giving you -1.25 degrees front camber.
Austin is offline
Old 08-07-2003, 01:16 AM   #16
Red Rocket
Member#: 10507
'04 Ex STi Owner
'97 4Runner
I've eyeballed an sti's stock alignment, and I would guess it's the -.67 in the rear, not noticeably more than the front.
Kevin
Red Rocket is offline
giving the car to my brother - title questions sen7inel Tri-State Area Forum 5 02-27-2010 01:01 PM
the hell...15bucks more to add a 2nd car to my insurance... lionken07 Off-Topic 20 01-15-2008 10:57 PM
So a crack dealer crashed his car into my uncle's house last night... scaryfastskier Off-Topic 21 06-19-2006 05:38 PM
going to somerset, whats the chance i wont wake up to my... tool1128 Tri-State Area Forum 13 05-03-2006 02:31 PM
rust on my car after one yr. dealer wont help. what do i do? djcttb Texas Impreza Club Forum -- TXIC 9 08-17-2004 01:09 PM
