#1 |
Member#: 35350
Vehicle:2004 Impreza WRX STi Java Black Pearl/Gunmetal |
I noticed that when my car is on.
When I roll down my windows and listen closely. When I release the clutch at a certain speed, I can hear it engaging...like a slight catching noise. I'm in neutral when i hear this. Is this normal??? The sound goes away if the car is off.
#2 |
Member#: 3683
Vehicle:2007 Impreza WRX Shagginwagon |
My car (2001 RS) also makes a little noise in nuetral when the clutch is engaged, but I usually only notice during the cold months.
#3 |
Member#: 35350
When I meant speed, I meant the speed of me releasing the clutch.
I'm not rolling when I hear this noise. |
#4 |
Member#: 39191
Vehicle:2004 WRX STi WRB Red 1990 Spec Miata |
In every manual transmission car I've ever owned, I've been able to hear the clutch fork make contact with the throwout bearing when you very lightly touch the clutch pedal at rest/idle.
Also, it's fairly easy to hear the throwout bearing touch the fingers of the pressure plate. You will hear a little rattling sound and often a touch of 'whir' as the bearing touches the pressure place and spins up. |
#5 |
Member#: 35350
Thanks.
I guess I was just getting worried for nothing. |
#6 |
Member#: 37962
Vehicle:2006 CGM STI 2000 Outback & 05 BMW M3 |
My car does the same thing. It should be normal.
| Thread Tools | |
| Display Modes | |
| Engine ticking noise when car is off & on? | Azxster | Normally Aspirated Powertrain | 13 | 06-12-2009 11:05 AM |
| Consistant buzzing noise when car is off??? | jpvtec1 | Service & Maintenance | 26 | 12-20-2008 05:56 PM |
| Headlights cause noise when sterio is on? | FlyingFishSandwich | Service & Maintenance | 2 | 02-07-2004 12:30 AM |
| initial uppipe noise when car is cold. | ellinopedo182 | Factory 2.0L Turbo Powertrain | 2 | 02-17-2003 01:49 PM |
| weird noise when heater is on | mofoporn | General Community | 3 | 03-08-2002 10:56 PM |
