Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 08-06-2003, 01:36 PM   #1
mikeybikey
Member#: 40871
2000 Impreza RS
Unhappy Dealer pulling my leg??
I brought in my car for service because it was running poorly.. My idle shot up to 4000 rpm (CEL flashing) ..then is now fluctuating between 1400 to 2000 rpm in netral (rs is a 5spd manual). The dealer said I need a new throttle body/assembly and is gonna cost $600 plus $200 to install @$90/hour labor. Why would I need a new throttle body?? HHmmmm.. This particular dealer is Salerno-Duane Subaru in Jersey City, New Jersey.. Anyone have an idea??
mikeybikey is offline   Reply With Quote
Old 08-06-2003, 02:08 PM   #2
Legacy777
Member#: 4800
1990 Legacy & 97 OBS
AWD 6MT EJ22T AWIC Swap
Unless you have a leak in one of the seals, or damage to it......you don't need the whole thing. It's possible your IAC valve may not be working, or may need to be cleaned, but that can be replaced separately, if not cleaned up.
Check out this thread http://forums.nasioc.com/forums/show...hreadid=394404
BTW, I can change the TB in my car in like 15-20 min. On your car, shouldn't take over an hour at the most.
I'd go to autozone, have them pull codes, it will probably be for the idle air control valve. Clean that puppy up, and reset the ECU.
Legacy777 is offline   Reply With Quote
HELP ME BABY JESUS!!! I just pulled a tick off my leg!~!!~!!111 Asinine Off-Topic 46 08-03-2006 10:40 AM
I just pulled a Tick out of my leg. DJ 9iron Off-Topic 31 06-05-2003 04:59 PM
Dealer pulled a fast one sonicsuby03 STi Forum Archive 5 06-03-2003 11:08 PM
The dealer pulled this code today.......help Aaron'z 2.5RS Normally Aspirated Powertrain 23 11-22-2001 09:39 PM
Is Someone Pulling My Leg??? BigElm General Forum Archive 7 01-25-2001 01:11 AM
