Old 05-01-2001, 11:26 AM   #1
wop
Member#: 1931
2000 00 impreza 2.2l
wagon
Post what causes fire out of the exhaust?
on a turbo charged car, I see (vids), hear and read about the flame out of the exhaust. what causes this? is it excess fuel (running too rich), that gets heated and ignites as it goes thru the exhaust track, or what?
thanks,
-wop
wop is offline   Reply With Quote
Old 05-01-2001, 02:09 PM   #2
DLC
out back
Member#: 1964
05 OB XT LTD
Silver/Gray
Post
An excessive amount of stickers on the car keeps the paint from breathing and it has to vent via the exhaust pipe.
Also, too much rice-alcohol causes major engine problems and indigestion.
Or, unburnt fuel and anti-lag systems can do it too.
DLC is offline   Reply With Quote
Old 05-01-2001, 04:04 PM   #3
UCI_Scott
Member#: 5088
Post
<center> </center>
UCI_Scott is offline   Reply With Quote
Old 05-01-2001, 04:08 PM   #4
SuperFreq
Member#: 3909
2002 Impreza WRX
Platnum Silver Metallic
Post
I thought that the flames out the tail pipe were from the system they use to prevent turbo lag. Don't they inject fuel and ignite it before(or after, not sure) the turbo to keep it spinning? I could be wrong.
SuperFreq is offline   Reply With Quote
Old 05-01-2001, 04:42 PM   #5
bsquare
Member#: 1911
2000 Impreza 2.5RS
Silverthorn Metallic
Post
Most cars that do that little fire breathing trick don't have anti-lags (how much use do anti-lags see outside of rallying?). They are just spewing so much unburnt fuel and the exhaust is so hot that it ignites when it finally hits the oxygen-rich air.
bsquare is offline   Reply With Quote
Old 05-01-2001, 10:45 PM   #6
pretz
Member#: 4434
Post
that should be the mis-firing system on the WRC cars... if not mistaken
pretz is offline   Reply With Quote
Old 05-01-2001, 11:07 PM   #7
bsquare
Member#: 1911
2000 Impreza 2.5RS
Post
It's not misfiring, it is the anti-lag as described above (unburnt fuel intentionally injected into the exhaust before the turbo through various means, then ignited to keep the turbo spinning).
Old 05-02-2001, 12:07 AM   #8
SuicidalLabRat
Member#: 4096
noun [ ve·hi·cle ]
a carrier,as of infection
Post
the old bandanna in the tail pipe trick!?
SLR-
SuicidalLabRat is offline   Reply With Quote
Old 05-02-2001, 12:26 AM   #9
Narcisse91
Member#: 3931
WRX, Ninja, RX-7
Legacy, Fiat 850
Post
Basically, running too rich is required, and if the cats are doing the job, you shouldn't be able to do it, so you can't have a (functional) cat in there. On top of that, you need to either have very little backpressure, or a lot of pressure from the engine to get the flame that far down the pipe, or something in the tailpipe to ignite the unburnt fuel.
Narcisse91 is offline   Reply With Quote
Old 05-02-2001, 12:48 AM   #10
Thug
Choke Artist
Member#: 603
Post
Do a search. there was a long thread about this not too long ago. But yes, it does involve unburnt fuel.
Thug is offline   Reply With Quote
Old 05-02-2001, 12:55 AM   #11
MY99 2.5GT
Member#: 5030
1999 Legacy 2.5GT
12 Legacy GT 13 Armada
Post
You could wire a spark plug into your exhaust pipe that would ignite the exhaust fumes. That good for a nice fireball.
Sorry I jsut thought I'd add that. My friend did this on an old Chevelle. It was really funny to see this fireball burst from his exhaust pipe.
MY99 2.5GT is offline   Reply With Quote
Old 05-02-2001, 04:13 PM   #12
thebusiness999
Member#: 3767
2008 BMW 135i !!!
Jet Black
Post
Strange explanations you are all coming up with...I always thought it was done by disgruntled gnomes that live in the tailpipes. They live back there and have an endless supply of Bacardi 151 (it's all they have to live off of). Every once in a while they just can't take down the 151 and spit it out...since 151 is flammable and it's hot in the exhaust, you get flames out the tailpipes. I hear them, I swear...but maybe that could just be my imagination.
thebusiness999 is offline   Reply With Quote
Old 05-02-2001, 04:27 PM   #13
bsquare
Member#: 1911
2000 Impreza 2.5RS
Post
We won't stop until we've got underpants!
Old 05-02-2001, 04:35 PM   #14
Wreckleford
Member#: 887
Post
On anti-lag systems they do not inject fuel into the exhaust, they retard the timing and/or skip sparks so that unbrunt fuel flows through the cylnder and out the exhaust valve. When it touches the hot manifold it ignites creating a pressue wave which keeps the turbine spinning.
Wreckleford is offline   Reply With Quote
Old 05-02-2001, 06:11 PM   #15
SubaFast1
Member#: 5787
Wink
hehehe, my car shoots flames very often!
Hmmm should I fix it?
or keep it?
SubaFast1 is offline   Reply With Quote
The Official White Smoke out of the exhaust thread mxpunk Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-24-2008 01:38 PM
blowing oil out of the exhaust domestic_abuser Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 05-17-2007 07:07 PM
White smoke out of the exhaust? stryfewrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 07-18-2005 05:01 AM
leaking oil out of the exhaust? akcel Normally Aspirated with bolt-on Forced Induction Powertrain 16 03-21-2004 05:26 PM
What is sticking out of the hood of this rally car? ImprezaL Newbies & FAQs 6 10-27-2000 12:54 AM
