Old 08-06-2003, 02:40 PM   #1
widesuby
Member#: 41284
Default Thicker headgasket for NA EJ25
Does anyone know where I can find a thicker head gasket for an NA EJ 25?????
widesuby is offline   Reply With Quote
Old 08-06-2003, 03:02 PM   #2
Dr Ken
Member#: 5885
2000 RS (GME)
SilvAr
Just out of curiosity, what are you up to, if you dont mind me asking ???
Dr Ken is offline   Reply With Quote
Old 08-06-2003, 03:49 PM   #3
widesuby
Member#: 41284
The vehicle is getting turbo'd and I need to lower the compression
Old 08-06-2003, 04:59 PM   #4
mprezuhguy
Member#: 39921
'00 RS Sedan
STM
so what you need is, a thicker head gasket for a Turbo 2.5.
mprezuhguy is offline   Reply With Quote
Old 08-06-2003, 05:37 PM   #5
jeffg
Member#: 2958
2001 WRX (GC8)
This option has been explored in the past, and it proposes a couple of problems.
First off, you dont say what year RS you are turbo'ing, but I will assume it is SOHC version.
The thicker headgasket will indeed lower the compression a little, but it will also change the cam timing on each bank of cylinders. This would normally be corrected by some adjustable cam gears, but unfortunatly no one makes any for the SOHC subaru.
Leaving the timing off may not be that serious a problem, but with the rotation of the engine and cam design it would advance one bank of cylinders and retard the other. This is a problem.
So I hate to be the bearer of bad news but a thicker headgasket will probably not work for you, unless you want to make more modifications to the cam system.
J
jeffg is offline   Reply With Quote
Old 08-06-2003, 05:55 PM   #6
widesuby
Member#: 41284
Thanks for the info!!!!!!!!!!!!
Old 08-06-2003, 06:19 PM   #7
Supapooh
Member#: 4461
02 2.slow
J
well said.
Supapooh is offline   Reply With Quote
Hybrid compression / timing with thicker headgasket? LiquidForce Built Motor Discussion 3 03-29-2007 09:45 PM
NA EJ20 to NA EJ25 dpjef Subaru Conversions 6 05-25-2006 04:56 PM
headgaskets for Phase I EJ25 afterbangin Normally Aspirated Powertrain 7 03-01-2006 08:16 PM
ignition map for NA ej25 jdchmiel Engine Management & Tuning 2 01-24-2005 11:52 AM
need copper headgasket for ej25 sideways slut Normally Aspirated with bolt-on Forced Induction Powertrain 11 08-14-2004 06:19 PM
