Old 08-06-2003, 02:57 PM   #1
AustinSTi
Member#: 9386
2000 2.5rs sedan
silverthorn
Default Where to buy a new o2 sensor??
Anybody know of a place online where I can purchase a o2 sensor for a 2000 rs, particularly the one just before/in front of the cat? I tried drivewire.com, but they dont have any. I was told bosch is the way to go, so thats why I really dont want to shell out 80 bucks on the OEM one the dealer has and have it f-up again because its in a random tech cat. I went to Bosch.com, and they have a list of distributors, but I went to all the ones in my area, and none of them have them yet alone can they order them. Any help would be appreciated,Thanks
AustinSTi is offline   Reply With Quote
Old 08-06-2003, 06:39 PM   #2
Albert
Member#: 3288
1998 Impreza 2.5RS
Rally Blue Pearl
Albert is offline   Reply With Quote
Old 08-06-2003, 06:50 PM   #3
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
www.oxygensensors.com
If you want to be really trick, order the 1998 ford f series unit (with v8).
Its a four wire sensor, so you can run a dedicated ground for the signal wire (the stock one grounds through the exhaust).
Old 08-07-2003, 12:49 AM   #4
AustinSTi
Member#: 9386
2000 2.5rs sedan
silverthorn
thank you for your quick responses, but I went to every link, and not one of them had a o2 sensor for a 2000 RS??? am i missing something?
Old 08-07-2003, 12:55 AM   #5
Albert
Member#: 3288
1998 Impreza 2.5RS
Rally Blue Pearl
type in keyword: "sensor"
If you can get an oe for $80 I would buy oe. The front oe sensor is usually a bit over $100.
Old 08-07-2003, 09:37 AM   #6
Opie
Floresbian
Member#: 470
2016 Legacy 3.6R
'15 FXT, '16 Crosstrek
Why do you think the Random Tech cat is destroying these sensors?
I've had a RT Cat for 6 months with no O2 sensor failures. Got a PO420 when I first installed it but the Pony Express MIL eliminator cured that.
Opie is offline   Reply With Quote
Old 08-07-2003, 02:51 PM   #7
Albert
Member#: 3288
1998 Impreza 2.5RS
Rally Blue Pearl
And also since it's the sensor in front of the cat that's bad it's likely NOT the cat that's causing the problem.
The problem most likely lies somewhere between the air filter and the O2 sensor.
Old 08-08-2003, 06:33 AM   #8
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
Front O2 sensors can eventually burn out. I had mine replaced by the dealer a few years ago. They said that many customers came to them for a replacement front O2 sensor. They also said that they couldn't figure out why O2 sensors (especially in MY00/01 Legacy and Imprezas) were burning out.
tmat3 is offline   Reply With Quote
where to get a rear O2 Sensor? RX Renesis Vancouver Impreza Club Forum -- VIC 4 11-27-2006 03:57 AM
Where to get replacemtn rear O2 sensor? mordy_2v Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 11-14-2006 02:33 PM
Where to buy front/rear O2 sensors? Honkey3k Service & Maintenance 3 09-14-2005 12:05 AM
Where to buy a wideband o2 sensor/guage? farrell Engine Management & Tuning 4 06-24-2005 08:01 PM
Where to buy a wideband o2 sensor/guage? farrell Private 'Wanted' Classifieds 5 06-24-2005 03:41 PM
