Old 08-06-2003, 05:45 PM   #1
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
Default wastegate problem
So I was misinformed about my VF34, it apparently has around an 8psi wastegate spring, not the 4psi i was told it had. I really don't wanna run that much boost, especially while i'm still working all the install kinks and everything out. What are my options here? An external wastegate or something?
lotusTT is offline   Reply With Quote
Old 08-07-2003, 12:22 AM   #2
bill harvey
Member#: 10
2005 Legacy Gt wagon
Garnet red pearl
how do you know it has an 8psi spring? you would think you would listen to the guy who used the turbo?
bill harvey is offline   Reply With Quote
Old 08-07-2003, 08:38 AM   #3
ChicksDigWagons
Member#: 20508
1998 Red Wagon
New Turbo Project...
If you back off the adjustment on the actuator arm, you can jerry rig it to run less boost. Otherwise your only other options are getting a different actuator or running an external wastegate. Might want to check if a WRX wastegate actuator will work, it would be easier and cheaper than going with a divorced wastegate.
-Brad Weingartner
ChicksDigWagons is offline   Reply With Quote
Old 08-07-2003, 10:14 AM   #4
lotusTT
Member#: 23359
2002 BMW M Coupe
Steel Gray
being the turbo n00b that I am, I do actually have the lower wastegate that I need. I got a little worried over nothing.
Old 08-07-2003, 09:08 PM   #5
ChicksDigWagons
Member#: 20508
1998 Red Wagon
We all have our moments!
-Brad
Old 08-07-2003, 09:35 PM   #6
Delicious Tuning
Member#: 1990
I would suggest, taking the "C" clip off and undo the actuator arm from the wastegate flap. That way you will run no boost until you are completely satisfied with everything working properly.
My $0.02
Delicious Tuning is online now   Reply With Quote
wastegate problems james_gt Legacy Forum 9 10-19-2003 09:54 PM
Wastegate problems james_gt Subaru Conversions 0 10-17-2003 07:53 PM
HKS wastegate problem Avenger Normally Aspirated with bolt-on Forced Induction Powertrain 7 11-20-2002 12:44 AM
Need help with HKS wastegate problem rhdude Normally Aspirated with bolt-on Forced Induction Powertrain 5 06-22-2002 12:34 PM
Wastegate problems awd1320 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 05-02-2002 08:45 AM
