Go Back   NASIOC > NASIOC Archives > NASIOC Archives > STi Forum Archive
Old 08-07-2003, 12:06 AM   #1
Zoso
Member#: 37962
2006 CGM STI
2000 Outback & 05 BMW M3
Default Anyone have difficulty with warm engine starts?
When I start my car and it's cold no problem, it fires right up. If the car sits for a few hours and then start it up it's fine. But if I park the car for 10 minutes and then start it, it will start up but then if feels like the engine is going to stall out for a few seconds and then it holds around 500 rpms. Anyone else notice this?
Zoso is offline
Old 08-07-2003, 12:17 AM   #2
majmun
Member#: 18298
2004 STi
Sounds like it's fatal. I'd be glad to trade you my 2002 WRX (only 36,000 miles) for your STi - free and clear. Just so you don't have to worry about those hard starting issues anymore. I know it's generous on my part, but I like helping those less fortunate than myself. I guess I'm a bit of a philanthropist at heart.
Glad I could help,
-Jealous Plebian Fool (who might just be a little buzzed)
majmun is offline
Old 08-07-2003, 12:33 AM   #3
maengelito
Member#: 35404
2005 Forester XT
Default Re: Anyone have difficulty with warm engine starts?
yes, the same happens to me. in fact this past weekend, i started the car, it stuttered then stalled. when i fired it up again, it stuttered then went to idle after i gave it a little bit of gas. it really worried me, but i'm glad i'm not the only one this happens to.
-brian
maengelito is offline
Old 08-07-2003, 12:48 AM   #4
G-shock
Member#: 36545
Maybe you don't push your cars hard enough!
G-shock is offline
Old 08-07-2003, 01:24 AM   #5
jmh
Member#: 28568
09 G8 GXP
silver/silver
I've got less than 300ml. on her but haven't had any problems as of yet.
jmh is offline
Old 08-07-2003, 02:14 AM   #6
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
One or two times from heat soak my car has been difficult to start when hot. The WRX has had problems with misfire due to the fuel rails getting too hot near #3. I think the STi layout is different but if the temps are high and you've been running hard it may happen.
Glenn
ANZAC_1915 is offline
Old 08-07-2003, 02:34 AM   #7
dsmperformance
Member#: 15059
2004 WRX STi
1991 TSi
Glenn
Sounds very logical to me. I noticed the same thing with mine, but its never actually stalled out or had a problem starting. The idle just seemed kinda low and choppy, but cleared out with a quick rev. I don't foresee any mechanical problems associated with it though.
dsmperformance is offline
Old 08-07-2003, 02:53 AM   #8
SportyBry
Visiting NASIOC Timeout
Member#: 40648
2004 STi
Blue, of course
..I noticed the same thing myself this week.....just didn't have a chance to write about it.
Anyone with the re-flash getting this (out of curiosity)...Subaru may fix more than 1 problem at a time with the reflash...
...Brian
SportyBry is offline
Old 08-07-2003, 02:57 AM   #9
dsmperformance
Member#: 15059
2004 WRX STi
1991 TSi
...Brian
I don't think a reflash will fix this symptom. I would not call it a problem.
Old 08-07-2003, 01:19 PM   #10
pleasenoSTIckershock
Member#: 34997
99 Miata
10AE
This has also happened to me a few times in the past week. I usually let the car idle for a minute or two before shutting it off in lieu of a turbo timer. Also, I've been running the same gas since day one and this problem just started as I approached 4000 miles.
pleasenoSTIckershock is offline
Old 08-07-2003, 01:28 PM   #11
drew510
Member#: 13319
2000 OBS stage MM
Sedona Red
This happens to my OBS as well. For me, it doesn't matter WHEN I start the car, it is HOW. If I let off the starter too soon, I get a super rough idle that I can eliminate with a restart or good helping of gas. I have no clue what causes this as no other car I have driven has ever done this.
So no help here, just similar exp. in a non turbo.
drew510 is offline
Old 08-07-2003, 02:24 PM   #12
dsmperformance
Member#: 15059
2004 WRX STi
1991 TSi
My bike does the same exact thing when I start it when its hot. I would not worry, its not a problem. My DSM did the same thing too...
Old 08-07-2003, 02:52 PM   #13
lstepnio
Member#: 10972
2004 STi (fuxor3d!!)
2004 Forester X
Weird, I had the same problem about 5 or 6 times with my WRX when it was new and it went away and never had the problem again.
lstepnio is offline
Old 08-07-2003, 03:40 PM   #14
Oldnslow
Member#: 4572
2015 WRX
You might try letting the fuel pump run a few seconds, then move the key to the start position--seems to help on a hot re-start with the WRX.
Oldnslow is offline
Stall after hot/warm engine start... Alan l. Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 02-25-2008 06:11 PM
OT: anyone have experience with an Acura C32A engine swap? mpaone South East Region Forum 4 09-24-2004 05:33 PM
Anyone Have Tour Dates For The Starting Line? N'CTRL Off-Topic 0 05-16-2004 10:09 PM
is anyone having trouble with search engines? AWDball Off-Topic 8 10-03-2003 05:33 PM
Anyone have a nice warm garage will to help me install a skidplate? snowbrdrfromnh New England Impreza Club Forum -- NESIC 1 02-01-2001 05:48 PM
