Go Back   NASIOC > NASIOC Archives > NASIOC Archives > STi Forum Archive
Old 08-06-2003, 11:17 PM   #1
RallyCSX
Member#: 4281
2010 2.5i, 2000 STI,
Ae86, CSX Rally Car
Default Bad bearings at 1200mi
After all of the problems that I had with my 2000 RS I know the symptoms of bad wheel bearings
1. a whoop whoop whoop sound
2. heavy brake dust deposits on the wheels
3. When you grab the top of the tire and move it side to side you can feel play in the bearing....
My new STI has all three
the dealer says that Im nuts and the dust is the brake pads seating but I have worked on world challenge M3s and I didnt see this much dust after several laps at limerock...
Needless to say Im pissed, anyone elsehave this problem?
RallyCSX is offline
Old 08-06-2003, 11:27 PM   #2
WRSport
Member#: 2060
00 2.5RS Coupe
01 black boxster hardtop
Default Re: Bad bearings at 1200mi
1. Could just be the very very noisy R compound level tires.
2. Could just be the brakes which will dust significantly.
3. Sure sounds like a wheel bearing issue though given #3.
Have you had the dealer physically look at it ?
WRSport is offline
Old 08-07-2003, 12:08 AM   #3
jmh
Member#: 28568
09 G8 GXP
silver/silver
with only 230ml. on the clock I have heard the "whoop whoop whoop"but only on certain road surfaces.I havent hit the binders hard but there is brake dust.As for the wheel play mine are rock solid.
jmh is offline
Old 08-07-2003, 12:22 AM   #4
dsmperformance
Member#: 15059
2004 WRX STi
1991 TSi
Why don't you have the dealer check it out before you say you have bad bearings?
dsmperformance is offline
Old 08-07-2003, 01:11 AM   #5
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
I'm sure the deposits are brake dust. These pads shed it in a major way. Are you seeing it on all four wheels? What are the chances of four wheel bearings failing at the same time?
When do you hear the whoop whoop?
ANZAC_1915 is offline
Old 08-07-2003, 08:00 AM   #6
STIffy
Member#: 39224
04 STI
Lots of brake dust here as well. I just clean the wheels a lot, I guess it is the price your have to pay for having one of the best set of brakes offered in a car this price.
As far as wheel bearings go, Ihad both front wheel bearings replaced at 1500 miles. The problem was noticed during my 300 mile drive home from the dealer. I initially thought that it may be a bad tire, but after swapping the spare on it was still there. They are the same bearing as the WRX so the dealer should have parts and tools in stock to take care of it. Hodges Subaru in Ferndale MI did both of mine and washed my car twice in an afternoon(Go Hondaslayer).
George
STIffy is offline
Old 08-07-2003, 08:44 AM   #7
'04 STi
Member#: 4863
The reason these pads dust so badly is that they are made by Jurid in Germany. The TUV (German DOT) requires graphite in the brake pads.
Bill
'04 STi is offline
Old 08-07-2003, 11:03 AM   #8
SGOSWRX
Member#: 10921
04 04 STi
12.8 @ 105 mph
Bill
Diddo, the STi break pads do produce a lot of dust. Nothing to worry about. Its normal
SGOSWRX is offline
Old 08-07-2003, 12:48 PM   #9
Thorn
Member#: 40213
2004 WRX STi
Yeah, the brake dust is a pain, I'm constantly cleaning my wheels. I'm at 1000 mi, I don't hear any noises that you describe and there was no wheel play.
Thorn is offline
Old 08-07-2003, 03:00 PM   #10
WRSport
Member#: 2060
00 2.5RS Coupe
George
Wow, if STIffy had two wheel bearing replaced already, maybe RallyCSX really does have mulitple wheel bearing going out.
I cant imagine how wheel bearings could go bad so quick, unless they were bad from the start.
Maybe there really is another bad batch of wheel bearrings out there that were used on the STi's?
WRSport is offline
Old 08-07-2003, 03:06 PM   #11
WRSport
Member#: 2060
00 2.5RS Coupe
STIffy had both fronts replaced at 1500 miles. That really does leave the possibility some other bad bearrings were used in a "few" other STI's.
I would think a given bearing would have to be defective from the start to fail that quickly.
Hopefully its just some fluke that only happened to STIffy and looks likely RallyCSX as well.
WRSport is offline
Old 08-07-2003, 03:19 PM   #12
STIffy
Member#: 39224
04 STI
I know a few guys that picked up their STI's from the same dealership as mine(Beechmont Subaru of Cincinatti) and none of them have problems. One of my bearings was definitely bad probably from the get go. The other one was probably replaced because Hodges service department is proactive. They said that after replacing the passenger bearing they still heard alittle noise, so they replaced the other just in case.
George
STIffy is offline
Old 08-07-2003, 03:20 PM   #13
WRSport
Member#: 2060
00 2.5RS Coupe
George
Interesting. Thanks for posting this info STIffy, I'm sure RallyCSX appreciates it even more.
WRSport is offline
Old 08-07-2003, 06:27 PM   #14
RallyCSX
Member#: 4281
Ae86, CSX Rally Car
Confirmation,
The dealer confirmed that the front right wheel bearing is bad!
thanks STIffy, sounds like we had the same problem.
I am going to try and have at least both fronts replaced.
As far as the brake dust I understand that the brakes give off significant dust but mine was so bad that it was spread up the side of my car
Thanks for the responses!
John
RallyCSX is offline
Old 08-07-2003, 07:43 PM   #15
spool1536
Member#: 39724
04 WRX STI
I have heard some noises in the front that sounded like bad bearings, but I thought "couldn't be.....maybe its the tires.....DCCD....". This makes me think more. I'll definitely get it on a lift this weekend and check it out but let me ask you guys who had this problem a quick question: Did either of you notice a strange vibration that started at 90 mph and disappeared around 100-105 mph? Definitely not the same vibration as the one you feel in the steering wheel when the tires are out of balance. Also, did you notice a slight grinding when going 5-10 mph and turning tight?
spool1536 is offline
Old 08-07-2003, 10:53 PM   #16
Hondaslayer
Interpretively Paraphrasing
Member#: 4562
1995 Legacy LSi
2005 Chrysler Town & ****
George
So what kinda exhaust did ya get? I see it almost everyday but I'm a loser and stay in the slow lane and hop-off at campbell hilton instead of woodward to avoid traffic So I can't get close enough to see (or hear for that matter!)
Ben,
Hondaslayer is offline
Old 08-08-2003, 12:10 AM   #17
STIffy
Member#: 39224
04 STI
Ben, I have an APEXi GT Spec catback right now. I also installed an APEXi intake(short ram style) with an APEXi aluminum induction box(A really trick looking heat shield). Soon I will have a downpipe with an O2 bung in so I can play a little on the dyno. I'm also working on my own molded gauge pod for my APEXi ELII gauges. I think that the DEFI pod is a little too Batman-like and the subaru pod is a bit boring.......
George
STIffy is offline
Old 08-08-2003, 10:07 AM   #18
Randog77
Member#: 37272
2004 WRX STi
WR Blue
SPool1536 -
Yeah, I hear a funny vibration right around 100 Mph. Thats how I know I'm going 100 Mph. (without looking that is) I'm not sure what it is, I keep thinking it's the wing in the rear, but I really have no Idea. It goes away after I'm over 100 Mph.
BTW: my wheels go "waap waap" also, but I'm pretty sure it's just the noisy tires.
Randog77 is offline
Old 08-15-2003, 11:31 PM   #19
cby1
Member#: 37324
Hmmmm...so the tire noise I describe as a "wuh-wuh-wuh-wuh" oscillation-type noise (45 mph - 65 mph; it becomes much more like a high-pitched, bad shopping cart wheel noise at higher speeds) could be the bearings?
History - heard a "scrunchy" brake-like noise when applying brakes early on. Dealer replaced (defective) *hub*. 2nd trip, alignment screwy, dealer aligned (wheel now cocked to right, bottom seam to left, instead of vice-versa), varies depending on turns.
Wuh wuh wuh noise remains. I take it back a 3rd time, dealer finds nothing wrong, we take out another STi on the lot, it does it too, in fact worse. Service manager says this proves it's a characteristic of the car, since both do it. I'm not buying it, but what can I do? One wonders if the bearings weren't also defective (not just the hub). Sound seems to come from the same wheel. Service manager's solution? "Turn up the radio, ha ha".
cby1 is offline
Old 08-16-2003, 11:14 AM   #20
hokiewrx
Member#: 18505
2004 STi
All STi's make the "wuh-wuh-wuh" sound. The tires are 140AA, you can expect anything this soft to make a lot of noise.
hokiewrx is offline
Old 08-16-2003, 11:29 AM   #21
ha-evolution
Member#: 31556
15 STI WRB ordered
09 Accord Coupe V6 mt
Originally posted by Randog77
SPool1536 -
Mine does that too! It happens at exactly 100 mph. What the heck is that noise anyway?
ha-evolution is offline
Old 08-16-2003, 11:42 AM   #22
Gansan
Member#: 32045
2004 S4
Mine does the same as well!!!! For some reason I didn't think that it did it when i first picked it up but it could be that I never went that fast. Wonder what it is?
Gansan is offline
Old 08-16-2003, 04:52 PM   #23
LESLIEx317537
Member#: 35350
2004 Impreza WRX STi
Java Black Pearl/Gunmetal
Mine sounds like it has a bad wheel bearing also.
It is prominant at lower speeds... 15mph +
I think I'm going to have it looked at soon, along with the alignment.
LESLIEx317537 is offline
Old 08-16-2003, 08:43 PM   #24
sr20det91
Member#: 26508
MY05 EVO VIII
Wicked White- 03RR Sold
Welcome to the world of crappy Subaru bearings.
I had my WRX in 3 different times for bearing failure. I've heard from more than one person that the grease Subaru uses to pack the bearings is horrible(read the project WRX article in this month of SCC).
I finally ended up buying the bearings myself, cleaning all the grease outta them, repacked them with the good stuff and have not had a problem since.
sr20det91 is offline
Any interest in a 2.5 RS 5mt with bad bearings? serious Private 'For Sale' Classifieds 4 01-11-2005 06:31 PM
bad bearing... am I right? Chuck Transmission (AT/MT) & Driveline 3 07-14-2004 08:14 PM
HVAC blower: bad bearing? snowone Legacy Forum 7 06-17-2004 09:41 AM
Is this a bad bearing? sszyma Tire & Wheel 10 04-07-2004 12:25 PM
Bad bearings? TubeDriver Brakes, Steering & Suspension 4 04-02-2004 10:10 AM
