Old 08-07-2003, 08:46 AM   #1
KnightWRXRider_
Member#: 30496
2004 STi
Default FWD to AWD help
How difficult would it be to convert a 94 1.8 Impreza FWD to AWD? Also what parts am I looking at? Gas tank, tranny etc.
KnightWRXRider_ is offline   Reply With Quote
Old 08-08-2003, 09:31 AM   #2
RSimport
Member#: 24718
05 impreza RS
white
do a search for all the parts I think my friend looked at it and said the whole swap would be around 1000. But don't go on my word for that price. You could maybe find some parts on here.
RSimport is offline   Reply With Quote
Old 08-08-2003, 10:43 AM   #3
beachbum
Member#: 457
---- Smells like
weed and rampage
It can be done. Not hard at all, but you need to have the tools, time, and ensure you have all the parts you'll need. I've done it, but don't recommend it unless you happen to have all the parts you need available for a really cheap price. You'll need tranny, driveshaft and associated brackets, gas tank, exhaust, rear crossmember with diff, axles, hubs, suspension arms (I think), struts, and strut tops. Pretty much every moving part from the flywheel back. Like this :
Josh
beachbum is offline   Reply With Quote
Old 08-08-2003, 11:46 AM   #4
tbd
Member#: 15322
1995 gf wagon
Blue Green Metallic 340
josh posted some really good pics of this on an earlier thread. and ditto, what he said. i believe the critical matching pieces you want are a tranny and diff that match each other. easiest if both from the same donor car. (i have a rear diff only for awd sus & disc brakes, no trans yet)
suggestion: if you can get access to a lift, it certainly is easier to work on. very little torqing leverage lying under the car.
i think my check list was:
rear suspension, all (struts, control arms lateral links)
knuckles disc or drum assembly
differential carrier (it looks like a giant T)
prop shaft,
transmission.
axle-back exhaust (needs to clear rear axle)
shift linkage?
gas tank?
i found all (+extras) but the tranny, tank & shifter for 400)
the "?" is because some cars have the awd fuel tank and the proper linkage already.
tony.
p.s. if you can pull the parts yourself, its better as you can take all the hardware & then some.
tbd is offline   Reply With Quote
FWD to AWD??? I NEED HELP STIINTHEMAKING Transmission (AT/MT) & Driveline 7 01-11-2006 11:42 AM
Want to do FWD to AWD? Drum to Disk? I have the parts keirnna Private 'For Sale' Classifieds 7 08-16-2005 04:39 PM
Anybody in S.D. or local that has a facility to swap my FWD to AWD STi-Nismo Dood Southern California Impreza Club Forum -- SCIC 10 04-09-2003 01:26 AM
FWD to AWD parts question Cliff Brakes, Steering & Suspension 5 06-13-2001 08:13 PM
FWD to AWD swap N/A Technical Forum Archive 2 07-04-2000 11:32 PM
