Welcome to the North American Subaru Impreza Owners Club Thursday October 2, 2014
Old 08-07-2003, 09:54 AM   #1
David_Wallis
Member#: 22479
94 2.33 Garrett GT
Heads, Cams & AutronicSM2
Default Autronic SM2
Just thought I would post that Im now using an Autronic SM2 (1.94)
did initally run dwell boards, but this seemed faulty so Im now using MSD CDI as well..
anybody got their rev counter working with it?
Seems pretty good so far, apart from lack of knock correction
David
David_Wallis is offline   Reply With Quote
Old 08-10-2003, 02:58 AM   #2
TWRRACING
Vendor
Member#: 39325
I run the SM2 on a TT Supra, and i can't get the RPM guage to work Other than that, everything was awsome.
jerry
www.twrracing.com
TWRRACING is offline   Reply With Quote
Old 08-10-2003, 11:30 PM   #3
JoeT
Member#: 3956
2000 Turbo Legacy GT
Titanium
I run the SMC with version 2.00
My stock tachometer is still managed by the stock ECU, spliced into the stock Crank Position sensor with the Reluctor interface, so that the Crank position sensor ran in two directions.
If you want your rev meter to work with an SM2, you'll need a tach adapter. Post your question in www.autronic.com in their forums and you'll get a prompt reply as to what you need.
Hope this helps.
JoeT is offline   Reply With Quote
Old 08-11-2003, 05:21 AM   #4
David_Wallis
Member#: 22479
94 2.33 Garrett GT
im going to output the rev counter from the msd dis 2 instead I think.. 12v Sq. Wave at 20deg.
David
FS: CA Autronic SM2 ECU PNP WRX ECU, TURBOXS TUNER my02wrx Engine/Power/Exhaust 8 09-22-2008 11:33 PM
FS: CA Autronic SM2 ECU PNP WRX ECU, TURBOXS TUNA my02wrx Engine/Power/Exhaust 0 09-01-2008 11:54 AM
FS: CA Autronic SM2 ECU PNP WRX ECU, TURBOXS TUNA my02wrx Engine/Power/Exhaust 1 08-19-2008 07:08 PM
Autronic SM2 Plug and Play ECU for 2002+ WRX STEALTH-WRX Engine/Power/Exhaust 10 08-02-2007 12:34 PM
Autronic SM2 ECU PNP WRX ECU my02wrx Private 'For Sale' Classifieds 1 02-01-2004 09:02 PM
