Go Back   NASIOC > NASIOC Archives > NASIOC Archives > STi Forum Archive
Old 08-07-2003, 12:58 PM   #1
bcristea
Member#: 11343
2008 STi
Default STi brake pad clunking noise?
Does anyone get a clunking noise from their brake pads when slowly moving forward/backwards from park?
It almost sounds like the pads are shifting forward or backwads a few millimeters? Maybe the tolerances are off?
Any ideas or comments?
Brian
bcristea is offline
Old 08-07-2003, 01:11 PM   #2
RichQY
Member#: 31948
2004 STi
i get screeching noise when approaching 5-15 mph ish
RichQY is offline
Old 08-07-2003, 01:26 PM   #3
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
The clunk is normal.
ANZAC_1915 is offline
Old 08-07-2003, 02:38 PM   #4
bcristea
Member#: 11343
2008 STi
RichQY,
Its not a screech its a clunk.
Glenn, what do you mean by normal and what is the cause?
Thanks,
Brian
bcristea is offline
Old 08-07-2003, 02:52 PM   #5
JDMTEG98
Member#: 38671
2004 WRX STi
World Rally Blue w/ Gold
Mine Screech Occasionally in Reverse ONLY
Sounds like a little girl screaming " eeehhhhhhhhhhhhhhhhhh"
JDMTEG98 is offline
Old 08-07-2003, 03:00 PM   #6
ANZAC_1915
Member#: 456
2008 Forester XT
Steel Gray Metallic
Originally posted by bcristea
RichQY,
Thanks,
Brian
By normal I mean all the cars do it, it doesn't cause any problems and is nothing to worry about. There has to be a little slop for the pads fitting the calipers so they can actually slide. On some cars it is louder than others.
Glenn
Old 08-07-2003, 03:18 PM   #7
Silver-Bolt
Member#: 40189
2004 STi
Silver/Silver
Normal sound with floating rotors.
Silver-Bolt is offline
Old 08-07-2003, 03:22 PM   #8
bcristea
Member#: 11343
2008 STi
Glenn,
So it is the brake pads and calipers initally contacting upon movement of the rotor?
I didn't know this was normal?
Does your STi do it?
bcristea is offline
Old 08-07-2003, 03:24 PM   #9
CreoWRX
Member#: 19024
2016 F80 M3
Alpine White
I usually get a pronounced clunk after I wash the car, and drive it for the first time and quickly let off the brakes/get on the gas... But I'm sure it's normal with these brakes.
-Mike-
CreoWRX is offline
Old 08-07-2003, 03:58 PM   #10
STI_FFY
Member#: 37519
2004 STi JBP/Gold
Helix DP, SMC, Cobb AP
Glenn,
I noticed it when driving in stop/go traffic in a hilly stretch on route 355 yesterday. I think this helped me to define how/when it will be noticed. Try this -
Go to a hill that has littl/no traffic on it. While driving slowly uphill, apply the brakes and allow the car to come to a full stop and "relax". Now release the brakes and travel over the crest of the hill at low speed. When you get over the top, apply the brakes and you will hear it - "clunk". Repeated applications of brake on the downhill will *not* reproduce the clunk.
I think what's happening is that the pads settle to the rear limit of clearance when clamped to the rotor and the car "relaxes" at full stop on the uphill. When released they stay pretty much at this full rearward clearance position. The next application of the brakes will cause the pads to grip the spinning rotor and travel quickly to the forward limit of clearance.
You are just hearing the impact of the sudden stop of thjs few millimeters of travel.
it might also do the "clink" if you simply back up and apply the brakes, but I did not try this.
STI_FFY is offline
Old 08-07-2003, 04:03 PM   #11
Silver-Bolt
Member#: 40189
2004 STi
Silver/Silver
No STi yet, should be here in the next 1-2 weeks. However the Brembo F50's on my Ford Lightning and on my BMW 330i do the same thing.
brake pad grinding noise? maddhatteroo7 Brakes, Steering & Suspension 5 03-19-2010 01:23 AM
07 STI HAWK HPS Brake Pads Making Noise youthebest Brakes, Steering & Suspension 7 02-27-2010 02:25 PM
Replaced brake pad= Clunk???? yahoolagan Brakes, Steering & Suspension 2 05-07-2009 10:15 PM
Uneven brake pads/grinding noise sjscooby Brakes, Steering & Suspension 4 11-11-2005 03:40 PM
Left driver side brakes make clunk noise setiawani Brakes, Steering & Suspension 1 03-11-2003 08:04 PM
