Welcome to the North American Subaru Impreza Owners Club Saturday August 29, 2015
Old 08-07-2003, 01:09 PM   #1
quietgiroth
Member#: 19375
Default Drum brake "puller thingie"
Hello,
Just wondering if anyone has any information on where I can get the drum brake puller. Or what size the two holes in the drum brakes are so I can make my own.
Cheers
Gareth
PS if anyone has any good advice on how to get the rear drum brake's off it would be apreciated.
quietgiroth is offline   Reply With Quote
Old 08-07-2003, 04:35 PM   #2
tmat3
Member#: 2817
2001 Impreza 2.5RS
BRP
I usually spray WD-40 on wheelstuds area, and gently tap the drums with a hammer (don't warp the drums). It eventually breaks loose for me.
tmat3 is offline   Reply With Quote
Old 08-07-2003, 05:33 PM   #3
quietgiroth
Member#: 19375
I've been trying that all day. All I have is a nice pile of rust under the drum. The thing will not come off.
Old 08-07-2003, 05:42 PM   #4
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
Haven't worked on a 97 'L before, but on pretty much every drum brake I have done, you have to retract the pads back using the adjuster or it's not going to come off (force it and you could damage things)
the bolts are usually 8mm
Old 08-07-2003, 06:43 PM   #5
tonytiger
Member#: 3844
1993 Legacy 1.8
Here are one instructions (pretty poor though) to remove the drums:http://www.cybrrpartspro.com/Chilton...97CH09_19.HTML .
Tony
EDIT: And here are couple of pictures (click them to enlarge) that might help you:http://www.cybrrpartspro.com/Chilton...97CH09_20.HTML
tonytiger is offline   Reply With Quote
Old 08-07-2003, 08:34 PM   #6
Precision Tuning
Member#: 38696
The bolts are usually 8 by a 1.25 thread pitch. Just make sure you run them in evenly.
Rich
Precision Tuning is offline   Reply With Quote
Old 08-08-2003, 07:24 PM   #7
quietgiroth
Member#: 19375
Cheers for all the pics and advice.
I finaly got it off, replaced the pads...went to the other side expecting it to be just as hard. It wasn't they came off with very little effort.
Old 08-13-2003, 05:29 PM   #8
DoinkMobb
Member#: 3787
2008 Gay
Car
quietgiroth - how'd you manage to change the pad that was attached to the e-brake cable (at least I think it's the e-brake cable). I managed to disconnect all the springs and crap, but I couldn't figure out how to get the attached pad off. It's attached to a metal flange with a rivet with a horseshoe shaped washer bent around it.
That was the only thing preventing me from replacing the pads. Any advice?
DoinkMobb is offline   Reply With Quote
Old 08-18-2003, 06:14 PM   #9
DoinkMobb
Member#: 3787
2008 Gay
Car
go up.
Old 08-20-2003, 06:15 PM   #10
ws6fiero
Member#: 33067
1998 Legacy Wagon
Spruce Pearl
Okay... from what I can gather you are talking about the e-brake lever that is attached to one of the brake shoes. I used screwdrivers to open up the C-clip that holds the pin in. I started with a small flat blade, pounded it into the gap, and did it with bigger and bigger screwdrivers to the point where I pulled it off with pliers. The pin iteself is press fit into the shoe... you have to remove it so you can put it on the new shoes. I set a socket underneath the shoe and pounded the pin out with the hammer. I basically did the same on the new shoe to pound it back in.
So was that your question?
ws6fiero is offline   Reply With Quote
Old 08-20-2003, 06:41 PM   #11
DoinkMobb
Member#: 3787
2008 Gay
Car
Ok yeah that's exactly what I need to know. Pry the C-clip off and then pound the pin out with a hammer...got it. I'll have to try that next time I have some time off.
Thanks.
Old 08-20-2003, 06:46 PM   #12
ws6fiero
Member#: 33067
1998 Legacy Wagon
Spruce Pearl
Yeah I figured it was what you meant. That's probably the hardest part of the whole job... not too bad after you do the first side, though.
Good luck
Old 08-26-2003, 09:01 AM   #13
quietgiroth
Member#: 19375
I should have taken pictures while I was doing it and done a write up. I still might, but its such a pain.
The part your talking, about I hammered out with...well...a hammer and a screw driver. Then reused it, I don't know if that was the best thing to do. At the time I didn't have much of an option. I just make sure that I didn't damage it too much.
Once again cheers everyone for their help.
Old 08-28-2003, 08:09 PM   #14
ws6fiero
Member#: 33067
1998 Legacy Wagon
Spruce Pearl
Yeah, you should be able to get a hardware kit for relatively low $$$ that would include the clip and springs and retainers. The parts store I got my stuff from said it wasn't available, though. I'm sure a dealership would have it, but then it would probably be a sizeable investment.
Anyway... I ended up reusing mine too.
Old 09-03-2003, 08:23 PM   #15
DoinkMobb
Member#: 3787
2008 Gay
Car
I started to mangle the C-clip when I was trying to pry it off. I'd rather use a new one, but I don't want to order a "kit" through the dealer. Think a hardware store would have what I'm looking for?
Drum brakes to disc brakes..what's easiest? euroteknic Subaru Conversions 11 07-14-2006 06:53 PM
Rear Drum brakes to Disc brake conversion ryking69 Brakes, Steering & Suspension 3 05-08-2005 09:16 AM
Rear Drum brake to Disc Brake Conversion scoobyimprza Brakes, Steering & Suspension 7 03-23-2003 07:07 PM
about rear drum brake to rear disk brake SYMSWRX Brakes, Steering & Suspension 2 01-13-2001 03:13 PM
Rear drum brake to disc brake conversion eicbal18 Technical Forum Archive 5 08-16-2000 11:23 AM
