08-07-2003, 04:00 PM | #1 |
Member#: 33293
Vehicle:2011 4-door STi Plasma Blue |
Oil pressure sending unit install...HELP
I bought the oil gallery plug and its a different thread pattern then the sending unit. Whats the best method to go about installing it. Maybe they make some kind of adapter or something. Its the autometer oil pressure guage.
~Danny
08-07-2003, 04:11 PM | #2 |
Member#: 13634
NESIC
Vehicle:2002 WRX WRB |
you need a 1/8 BSPT male to 1/8 NPT female adapter. eGauges.com should have it. Make sure to put some sort of thread sealer on it.
08-07-2003, 04:12 PM | #3 |
Member#: 33293
Do you think I can get that at a local home depot or is that something that is a rare find and I have to get it off-line.
08-07-2003, 04:13 PM | #4 |
Member#: 2817
Vehicle:2001 Impreza 2.5RS BRP |
PepBoys carry those adapters as well.
08-07-2003, 04:16 PM | #5 |
Member#: 33293
I can't get to that site for some reason. Can you post a link. www.eguages.com is not in use.
08-07-2003, 04:17 PM | #6 |
Member#: 33293
Pep boys sounds like a plan. Hopefully they have it in stock.
08-07-2003, 04:18 PM | #7 | |
Member#: 13634
NESIC
http://www.egauges.com/vdo_acce.asp?...Bushings&Cart= It's listed as a VDO adapter but it's the correct theadings for your autometer also. The listed autometer part is almost $4 more expensive for the exact same thing. Wow pepboys carries that adapter? Must not be every pepboys. That's got to be rare but at least you could pick it up locally and not have to pay for shipping. |
oil pressure sending unit | imprezzakc | Normally Aspirated Powertrain | 6 | 03-25-2014 12:36 PM |
oil pressure sending unit/egt gauge installs | dgp2003wrx | Interior & Exterior Modification | 1 | 07-28-2004 02:08 AM |
How does the factory oil pressure sending unit work? | Jasno999 | Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) | 3 | 09-13-2002 02:16 PM |
Autometer elec. oil pressure sending unit tap location instructions | joostin420 | General Forum Archive | 1 | 02-08-2001 09:39 AM |
you don't have to bleed the hose that goes to the oil pressure sending unit....??? | rao | Normally Aspirated Powertrain | 1 | 10-25-2000 12:36 AM |
