Welcome to the North American Subaru Impreza Owners Club Thursday May 28, 2015
Old 08-07-2003, 04:42 PM   #1
tdxflex
Member Sales Rating: (16)
Member#: 13634
Default swaybars, Hotchkis vs Cusco
I've had a chance to use both. There's been enough discussion about handling and honestly a swaybar is a swaybar, really the only concern is the fitment. There are also a lot of reviews on the cusco bars, so I'll try to focus more on the hotchkis ones.
First off, they are hollow and much bigger in diameter for a huge strength-to-weight ratio. The front bar also has spot welded "stops" on the outer edge of the bushing to prevent the bar from walking.
Zero fitment issues, but one thing that I found that was now very annoying that probably hasn't been brought up.. Because the swaybar is much bigger than the stock or cusco bars, it now covers any access to the engine mount bolts. When I had to change out my uppipe, I also had to remove the swaybar. If I knew this beforehand, I probably would have just done the install from up top and unbolt the turbo.
In the rear, the bar bolts up to the outside of the links vs the inside like all the other swaybars, so fitment issues may occur with spherical endlinks (perrin, helix, hairpin). On the stiffest setting (25.1mm IIRC), there are also other issues with the kartboy endlinks because they are shorter than all other endlinks. I have the MRT alloy endlinks and have no fitment issues.
I have zero rattling issues and my exhaust setups have been stock and TurboXS stealthback with cat, using the stock exhaust hangers.
Weight factor. I was not able to get accurate readings because my scale is way off, but it is an obvious difference. In order of heaviest -> lightest, cusco -> stock -> hotchkis. According to my scale, the cusco vs hotchkis set (front and rear combined), there is a 6-7lb difference. By itself the weight won't make a noticeable difference, but it sounds nice on paper.
Final thoughts, the Hotchkis swaybars will have no fitment issues for the majority of typical suspension setups. I got my set of swaybars for $250 shipped which IMO is a very reasonable price for swaybars. Often people complain about how expensive the cusco bars are and buy the whitelines instead, well here's another alternative.
tdxflex is offline   Reply With Quote
Old 08-23-2003, 03:50 AM   #2
tdxflex
Member#: 13634
After a few more months to test things out, I've noticed that the sway bar and the endlink have slight rubbing when set at the stiffest setting, no wonder the hotchkis endlinks have a different slope to them. So the mrt alloy endlinks have a slight fitment issue, I would think the whiteline noodle looking endlinks would have zero fitment issues since they are much narrower. Just scraped away a little bit of paint, I set it to the middle setting and actually feels much better than it did at the stiffest, no further endlink rubbing.
Old 08-26-2003, 06:48 PM   #3
android
Member#: 11155
2002 impreza wrx
midnight black pearl
I also have the Hotchkis setup with kartboy drop links. I don't have the rear set to the stiffest setting, but I have to say there are no complaints here. The fitment is perfect as far as I'm concerned, though the rear seems like it could be putting some stress on the linkage due to the unconventional placement (outside the droplinks). Time will tell. Hotchkis has been in business for a long time as far as domestic applications go, and they are tried and tested. Did I mention my car feels rock solid?
android is offline   Reply With Quote
Old 08-31-2003, 01:34 AM   #4
neverendingmods
Member Sales Rating: (1)
Member#: 23796
2006 STi
white
I've had the Hotchkis/Mrt combo and noticed rubbing(rear right away. I couldn't use stiffest setting(rear only) til I dremeled the endlinks. No biggie. Nobody sees it cause of how swaybar is on ouside of endlink. But, dremeling soft aluminum is no cake job. Kept coating the dremmel grinder.
Stiffer is better. Til. the snow comes.
neverendingmods is offline   Reply With Quote
Old 09-16-2003, 12:33 PM   #5
WRXtreme02
Member#: 12680
2010 GTi
Hey tdxflex... where did you get them for $250 shipped??
THANKS!!
WRXtreme02 is offline   Reply With Quote
Old 09-16-2003, 12:38 PM   #6
tdxflex
Member#: 13634
I got them from SubaruStore when they had a special on them. There's also a different package that includes the upgraded mounts (not links) I think they call a sport swaybar package. I just got the bars without the mount.
http://forums.nasioc.com/forums/show...light=hotchkis
Old 10-27-2003, 07:16 PM   #7
JDMSubaru
Visiting NASIOC Timeout
Member#: 40546
So which was better in handling? There doesn't seem to be any other commentary other than that about weight and fitment...
JDMSubaru is offline   Reply With Quote
Old 10-27-2003, 08:54 PM   #8
tdxflex
Member#: 13634
There isn't that big of a difference between handling, not just from the Cusco and Hotchkis. All of the aftermarket bars are a certain percentage stiffer than stock, don't have the exact numbers but all of the adjustable bars usually will give you a setting you will like. I say just go for whichever one you can get a deal on.
Old 10-28-2003, 02:28 AM   #9
JDMSubaru
Member#: 40546
but isnt the front cusco bar comparably less stiff than the hotchkis front bar???
Cusco Coilovers, Cobb Swaybars and Mounts, Cusco Strutbar cyrexpl Suspension/Brakes/Handling 22 11-18-2007 01:16 PM
Coilovers: Whiteline G4 vs. Cusco zero2E vs. Kw 3v vs. HKS hm2 AutoScott Brakes, Steering & Suspension 1 06-03-2006 07:04 PM
FS: Hotchkis & Cusco sway bars, FT: TXS standard exhaust scoobie1 Private 'For Sale' Classifieds 7 08-11-2005 10:49 PM
Cobb/Hotchkis or Cuscos Sway bars for STI roybfr Brakes, Steering & Suspension 9 12-07-2004 09:50 PM
Hotchkis vs. Cobb Swaybar sets. jason2004STI Brakes, Steering & Suspension 5 05-12-2004 12:02 PM
