Welcome to the North American Subaru Impreza Owners Club Sunday December 11, 2016
Go Back   NASIOC > NASIOC Archives > NASIOC Archives > STi Forum Archive
Old 08-07-2003, 07:21 PM   #1
WRX 2002
Member#: 11211
2004 STi
Rally Blue
Default STI track day recommendations?.
Its time to purchase a new set of tires for track days and autox. Just wandering what others opinins are.
Something that has good grip and will not over heat so easily and start chunking like the RE070.
The OEM RE070's lasted 3,000 miles of which 150 were on tracks.
Thanks for any advice.
N.
WRX 2002 is offline
Old 08-07-2003, 08:10 PM   #2
Karter
Member#: 35838
2004 STi
Track only, or will you daily drive them as well?
Michael
Karter is offline
Old 08-07-2003, 08:18 PM   #3
re92
Member#: 4715
Big balls, no brain
falken azenis.
thank you
raj
re92 is offline
Old 08-07-2003, 08:31 PM   #4
WRX 2002
Member#: 11211
2004 STi
Rally Blue
Michael
Track/autoX only I have a set of S03's for daily driving.
WRX 2002 is offline
Old 08-07-2003, 08:48 PM   #5
Karter
Member#: 35838
2004 STi
If you want to stick to the stock size, (perhaps to stay in class in Autox) than for best grip I would go with Hoosier R3S03,but wear is rapid. And the cost is high.
Michelin Pilot Sport Cup's would be next in line for laptimes, again though $pendy.
For nearly equal grip, but slightly better wear, I would go with Pirelli P-Zero Corsa's, still $pendy.
These three options are big bucks, but they are amazing tires, as the saying goes, if you have the means I highly recomend you pick up a set.
Now for a slightly lower cost option, I would recomend thre Kuhmo Ecsta V700
Lastly there is the Yokohama A032,
it is a bit outclassed in this grouping, and it is not available in the stock tire size.
Hope this helps.
Michael
Karter is offline
Old 08-07-2003, 10:16 PM   #6
lstepnio
Member#: 10972
2004 STi (fuxor3d!!)
2004 Forester X
I would suggest against the use of the Falken Azenis for track they as they easily become untable and greasy once they get too hot and it doesn't take much. The Falkens are a great SoloII or aggressive street tire as they work really well without the need of getting them up to temperature.
For the track on a budget I would highly suggest the Kuhmo Ecsta V700. If you have the money you'll have a hard time beating the Hoosier R3S03. You'll want to seriously look into having two these tires shaved and heat cycled prior to use.
If you're looking for a high performance set of street tires on a budget I would look into the new Kuhmo MX or you consider the Falken Azenis. The MXs should offer better wet traction and a little less road noise.
lstepnio is offline
Carbotech XP8 & STi track days gregr01 Brakes, Steering & Suspension 0 09-27-2004 01:21 AM
STi + Track Day = Overheating Rear Diff. = Help lukerussell Motorsports 19 08-04-2004 02:37 PM
Attn: STi Track Day People lukerussell Motorsports 9 01-23-2004 06:31 PM
STi - Track Day Review fastwrx STi Forum Archive 20 07-29-2003 03:14 PM
Racing fuel for STi track days? fastwrx Motorsports 6 06-23-2003 02:49 AM
