Welcome to the North American Subaru Impreza Owners Club Wednesday May 6, 2015
Old 08-07-2003, 08:53 PM   #1
subachad
Member#: 8488
1993 Impreza GCStyle
Teal
Default Front Wheel Bearing Replacement
Hi all,
After only 197,000 miles the front wheel bearings are ready for replacement. My question... how do I separate the knuckle from the A-arm? I just have that one bolt going through the A-arm, but I can't seem to get it off. I'll most likely just take off the A-arm and bring the whole thing in to get pressed, but are there tricks? That little is a pain in my
Chad
93 1.8T
subachad is offline   Reply With Quote
Old 08-07-2003, 11:32 PM   #2
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
cdvma is offline   Reply With Quote
Old 08-08-2003, 12:22 AM   #3
subachad
Member#: 8488
Teal
Thanks for the info, but you wouldn't happen to have any info on the front would you? I'm having trouble separating the knuckle from the A-Arm.
Chad
93 1.8T
Old 08-08-2003, 10:26 AM   #4
cdvma
Member#: 21980
2002 PSM WRX (Sold)
2009 BMW X5
Doh, I thought it had front info, I guess I remembered wrong. Have you tried calling the service dept of a dealer and asking for a tip?
Old 08-08-2003, 03:10 PM   #5
ciper
Member#: 15543
90BJ Legacy LS ABS
AWD 946 Rio Red Jpn built
Pickle fork.
Old 08-08-2003, 04:19 PM   #6
Austin
Member#: 7089
Pickle forks are the right way to do it...
Or, in the absense of a good fork, place a block of wood on the a-arm and smack it with a hammer repeatedly. Even on the '91 I got them to come loose with less than 10 seconds of whacking.
Austin is offline   Reply With Quote
Old 08-08-2003, 07:52 PM   #7
subachad
Member#: 8488
Teal
I just brought in the whole a-arm assembly and the guy that's going to press the new wheel bearing managed to separate it with a BFH and his foot.
It was a lot easier with the A-Arm on the floor... more room to work.
Now the bolt has jacked up threads from hammering and if I cut the bolt then I can't get a safety pin in there.
Hopefully the car will be together tomarrow night, I have some more moving to do.
Chad
93 1.8T
Old 04-03-2005, 12:07 PM   #8
chudlo
Member#: 15505
2002 JDMV8 STI Wagon
Originally Posted by subachad
Hi all,
Chad
93 1.8T
I just want to share how the tech at my dealership removed the knuckle from the A-arm. I used this technique when doing my suspension swap.
When you are ready to separate the knuckle, i.e. you have loosened the bolt holding it tight, take a large flathead screwdriver and pry the gap. This will allow the ball joint to fall right out so be carefull.
Just wanted to add this for those doing searches. I am having wheel bearing problems right now.
Bad spellers of the worl untie!
chudlo is offline   Reply With Quote
Old 04-03-2005, 02:49 PM   #9
subachad
Member#: 8488
Teal
I have done this a few times since on a few cars. the real trick is to get a BFH and pound on a solid peice next to the bolt. The bolt then vibrates loose and it litterally just pops off.
Chad
Old 04-03-2005, 10:14 PM   #10
Tim Sanderson
Member#: 6486
00 Impreza 2.5 RS
Blue Ridge Pearl
Remove ball joint cotter pin and castle nut. unbolt and free the tie rod end. remove strut bolts. Put a nut on there with the same thread pitch so that the nut is flush with the end of the ball joint threads.
Now smack that nut with a hammer and you won't ruin the castle nut.
It should'nt take that much force. Check to see if you got it after each couple blows.
Tim Sanderson is offline   Reply With Quote
Help - front wheel bearing replacement gopsu Newbies & FAQs 6 08-30-2009 04:31 PM
Here are parts needed for front wheel bearing replacement for 02 WRX sedan gopsu Brakes, Steering & Suspension 3 08-27-2009 10:54 PM
05 STi replacement front wheel bearings ruski Transmission (AT/MT) & Driveline 0 05-21-2007 08:22 PM
Replacing 04 STI front wheel bearings need all info i can get WickedSTI Transmission (AT/MT) & Driveline 3 05-01-2007 05:30 PM
Front wheel bearing replacement? sliver911 Brakes, Steering & Suspension 5 02-08-2006 12:30 PM
