Old 05-15-2001, 11:42 AM   #1
IMPREZIV
Member#: 862
Question Has anyone installed a Ludespeed kit yet?
Hey guys and gals,
I am curious to see if anyone has installed a Ludespeed kit yet. I have not heard or seen anything yet, and since I had one of the kits that I ended up selling, I wanted to see how all was going for those who got em. Please let me know and post some pics if you got em!!
Thanks,
Pete
IMPREZIV is offline   Reply With Quote
Old 05-15-2001, 11:49 AM   #2
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
Not yet... still waiting on a few fittings (damn oil fittings... have to be ordered from Japan!!). Other then that, I should be getting my kit next week, and hopefully *crossing fingers* I'll have my flywheel soon and then I'll be able to disable my car for a weekend and install everything.
Old 05-15-2001, 01:25 PM   #3
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
blkwag - They're the fitting on the back topside of the engine that block an oil passageway that carries pressurized oil. Guess they don't have block parts in the states, just full block assemblies.
Old 05-15-2001, 02:54 PM   #4
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Post
Is this the one fitting that replaces the hex screw in the top of the block? Its use would be for an oil source to the turbo?
-Jon
Old 05-15-2001, 03:50 PM   #5
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
stimpy - Yup, that one.
Old 05-15-2001, 04:01 PM   #6
blaster88
Member#: 1109
1999 Suzuki Samurai
Blackish
Post
Is this the back of the block on the pass side? That's water, not oil. Unless you mean a different plug.
blaster88 is offline   Reply With Quote
Old 05-15-2001, 09:51 PM   #7
Boeleni
Top Scoob 003
Member#: 1812
1999 Impreza Try-R
Satin Black
Post
We have said plugs up here in Canada.. so if Japan doesn't come through next week maybe I can pick some up for you guys
Boeleni is offline   Reply With Quote
Old 05-16-2001, 12:18 AM   #8
NickSTi
Member#: 626
2001 Impreza 2.5 RS
Black Diamond Pearl
Wink
I keep asking 8 that question everyday
i think he told me someone close to him got one already.
NickSTi is offline   Reply With Quote
Old 05-16-2001, 12:24 AM   #9
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
Yeah, it was a stage 1 kit, but it didn't have the fittings either.
Nick, you're just scared that I'm gonna come down there and whoop ya when I get it installed.
Old 05-16-2001, 12:36 AM   #10
blkwag
Member#: 4838
2002 WRX Wagon
Black in Recovery...
Post
"fittings that have to be ordered from Japan"?
What type of fittings are these that you can't get over here? It's just a turbo kit and unless I'm missing something, it seems like BS to me.
blkwag is offline   Reply With Quote
Old 05-16-2001, 01:11 AM   #11
blkwag
Member#: 4838
2002 WRX Wagon
Post
Why doesn't he just run a T from the oil pressure sender?
If people opt to do this way instead, will they get their kit any faster? I doubt it.
Old 05-16-2001, 10:27 AM   #12
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
Well, instead of running it across the entire block, it only runs about 10". Plus he already made up the lines for the rear inlet.
I just sent him the plug off my spare block so he can get that one done for me. Lucky I've got that block lying around I guess. He said if they take much longer to get here from Japan, he's just going to take mine to his machinist and have him make up a bunch of them instead of waiting.
On the plus side, I believe my kit is going to go out on Friday.
Old 05-16-2001, 11:42 AM   #13
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Post
8Complex:
Could you give a precise description of where this fitting taps in to? I still have to route my oil lines, so any additional options would be great. I know iSR has a tee fitting that is used to source the oil. I am not sure where it taps in at... blaster88 would know though.
-Jon
Old 05-16-2001, 11:46 AM   #14
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
The top side of the block, on the passenger side, towards the back. There is a round headed plug with a 5/16" allen socket on it.
The more I think about it, the more paranoid I get that it's a coolant plug instead of a oil plug though. I have to look at the block when I get home to see if I can tell, but I think [email protected] made sure in the manuals already... hmmmm...
Old 05-16-2001, 11:46 AM   #15
blaster88
Member#: 1109
1999 Suzuki Samurai
Blackish
Post
It's the same place in Larry's install instructions for a turbo from a vendor in his homestate.
There is a plug right by where the PCV hose comes up from the crankcase - the iSR fitting fits in that end and has a banjo bolt fitting that is correct for an IHI turbo on the other end.
The fittings are Aeroquip type. I would bet if you called Pam or Ed they could tell you what piece you need to connect on the block side. What you need on the turbo side is anyone's guess.
Old 05-16-2001, 01:04 PM   #16
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
I already sent [email protected] the one from my spare block, so no waiting for me.
It was simple to take out on a bare block, but I can only imagine what it is buried under on a full engine.
PS - Post 9999.
Old 05-17-2001, 12:49 AM   #17
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
Coutesty of Larry Ganz's installation instructions :
<IMG SRC="http://8complex.mwsoc.org/oilfeedplug.jpg" border=0>
And yes, that is the one that I was thinking of. Whew.
Old 05-17-2001, 12:55 AM   #18
yebokmj
Member#: 2213
1995 Impreza w/EJ255
Brilliant Red
Post
I can tell you from personal experiance that putting that fitting in (especially on a MY98 that has an air control vavle in the way) is one of the most time consuming and pain in the but parts of the whole turbo project.
Joshua
Subaru Salesman
yebokmj is offline   Reply With Quote
Old 05-17-2001, 12:58 AM   #19
blaster88
Member#: 1109
1999 Suzuki Samurai
Blackish
Post
8 -
That is precisely where the iSR fitting goes. Seriously, give them a call, and you shouldn't have to wait for fittings from Japan.
Old 05-17-2001, 05:06 PM   #20
ludespeed
Vendor
Member#: 2734
Post
yebokmj,
You are right about the air valve being in the way on the 98. But fortunately, the 98 is the only year that has that thing. The plug was cake to install on the 2001 test car even with the intercooler already installed.
Since you have a turbo 98, I was wondering if you suffered from the dreaded stalling problem that many other 98s have had. If so, what was the fix?
Tom
ludespeed is offline   Reply With Quote
Old 05-18-2001, 06:27 AM   #21
latinskllz
Member#: 3461
1998 BMW M3 Coupe
Estoril Bleau
Post
Pardon my lack of turbo knowledge, but does this fitting replace the oil tap in the pan for the turbo??
Please explain as to what the function of this fitting does and if you need to use it in conjunction with the tap in the oil pan.
Thanks,
Kevin
latinskllz is offline   Reply With Quote
Old 05-18-2001, 08:06 AM   #22
jdchmiel
Member#: 926
Post
no, this fitting is the oil source. The oil pan will still be taped for the oil return line.
jdchmiel is offline   Reply With Quote
Old 05-18-2001, 08:47 AM   #23
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
Yeah, we get the oil from there, run it into the turbo, and then down back into the oil pan. I much prefer that source to the oil pressure switch up towards the front of the engine, running the lines that far make me nervous.
Old 05-18-2001, 09:26 AM   #24
stimpy
Homicidal Maniac
Member#: 1612
2008 STI
Post
How is the oil return being handled for this kit?
-Jon
Old 05-18-2001, 09:55 AM   #25
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Post
There is a tube welded into the pan with a thread on the end. On that thread and the one on the turbo, you screw in a brass fitting (IIRC, 1/2" MNPT x 1/2" hose barb). Then you just run a high-temp (something like a rubber or coolant hose) to each and seal with hose clamps.
has anyone installed the GTP Cwest kit on an 01 rs?! ruster Interior & Exterior Modification 7 01-07-2005 01:26 PM
Has Anyone Installed anHKS SSQBOV Kit on their WRX my WeRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 08-16-2002 11:03 PM
Has anyone installed the Vishnu turbo kit yet? Superveget Normally Aspirated with bolt-on Forced Induction Powertrain 9 06-11-2002 01:16 PM
Has anyone installed a US-WRX engine in a GC8 body yet? EddyRS Normally Aspirated with bolt-on Forced Induction Powertrain 0 11-08-2001 03:52 PM
