#1 |
Member#: 38867
Vehicle:11 Mazda |
Ok... So I just got the money for fuel management. So I chose F.A.S.T. (formerly SpeedPro). In order for me to use F.A.S.T., I need to know what kind of ignition trigger we have. Magnetic, Optical, halleffect, or is it just off of the cam position sensor? Any info is greatly appreciated.
Also, what are the valvetrain components made out of. I.E. cams, valves, spring, retainers. Thanks in advance, Adam
#2 |
Member#: 38867
Vehicle:11 Mazda |
Doesnt anyone know?!?!?!
#3 |
Member#: 38867
Vehicle:11 Mazda |
NO ONE KNOWS???
What kind of subaru enthusiasts are y'all??? ![]() |
#4 |
Member#: 2992
NESIC
Vehicle:02 WRX Sedan Silver |
Actually, the answer is that this system will not work with Subaru components and, therefore, nobody uses it.
#5 |
Member#: 39597
Vehicle:2004 WRX STI Black 2003 F150 Lightning Black |
If you are looking at using a speed pro I have a bank to bank unit that i do not need any more
#6 |
Member#: 28161
Why not just take off the sensor and look at it?
#7 |
Member#: 38867
Vehicle:11 Mazda |
ShapeGSX: Where exactly is the sensor?
D-Truck: I need a sequential but thanks anyway. |
#8 |
Member#: 28161
How will the F.A.S.T. work with the drive by wire? Will you have to replace the DBW with a throttle cable?
I don't know where the sensor is on an STI. But it is probably the sort of thing you should find out if you are installing an aftermarket computer. ![]() |
#9 |
Member#: 38867
Vehicle:11 Mazda |
I'm not personally installing it. My mechanic is. Still doing research on the whole "which 'Stand-alone' will work" thing and havent gotten to the Drive by Wire issue... Thanks for bringing that up. Might have to look into MoTeC.
Thanks, Adam |
| Thread Tools | |
| Display Modes | |
| Your setup and ignition adv. @ peak torque and redline | wittmer25 | Built Motor Discussion | 15 | 07-11-2008 07:40 PM |
| wtb: door locks, trunk lock, and ignition slot with keys and remote system for 02 wrx | M.R.blue | Private 'Wanted' Classifieds | 2 | 03-30-2007 11:41 PM |
| Turbo kit and ignition wires for sale!!! | Homemade WRX | Private 'For Sale' Classifieds | 188 | 05-09-2004 12:24 AM |
| simultaneous clutch, brake, tranny, throttle, and ignition failure! | micah | Off-Topic | 56 | 02-03-2004 02:04 PM |
| Power chips and Ignition? | AudioFan | Normally Aspirated Powertrain | 3 | 07-12-2002 04:08 PM |
