Old 08-07-2003, 11:50 PM   #1
Stilletto
Member#: 21866
2002 WRX Silver
13.82 1/4 Almost Stock
Default Switching Back From Synthetic?
Anybody heard of any kind of "no going back once you cross over" rule or anything?
Need to do an oil change but can't afford the mobil 1 syn this time...ok to go with a blend or dyno for a break?
Stilletto is offline   Reply With Quote
Old 08-08-2003, 12:04 AM   #2
WRX_02_227
Member#: 12434
2002 WRX #332
2011 BMW 135i
From what I have heard once you go synthetic you cant switch back. I dont know why but thats what they say.
WRX_02_227 is offline   Reply With Quote
Old 08-08-2003, 12:28 AM   #3
PaulRex
Member#: 12454
10 Toyota Taco
K8 SV650SF
That sounds like nonsense to me honestly.. use the regular, change your oil/filter at 3k miles like usual, and you will be fine
PaulRex is offline   Reply With Quote
Old 08-08-2003, 01:40 AM   #4
quynce
Member#: 15409
FWIW, I switched back after two oil changes with synthetic and had no issues.
josh
quynce is offline   Reply With Quote
Old 08-08-2003, 02:05 AM   #5
samowrx
Member#: 8403
dealer offered me a free oil change but i told them that i was bringing my own oil. they used dino oil and there was no leaks. i'm back to synthetic again.
samowrx is offline   Reply With Quote
Old 08-08-2003, 02:16 AM   #6
drees
Member#: 25905
2003 Silver Wagon
Tuned with Enginuity
No issues switching back and forth between synthetic and non-synthetic, it's an old wives' tale.
drees is offline   Reply With Quote
Old 08-08-2003, 02:50 AM   #7
CirrusWRX
Member#: 17439
2002 x2 Silver WRX
Sedan, White WRX Wagon
I've heard similar.
And sorry to get OT, but why is it that these old wives spread so many darned rumors?! I swear - these married women get old and have nothing better to do than make up the MOST BIZARRE tales and pass em around.
CirrusWRX is offline   Reply With Quote
Old 08-08-2003, 12:49 PM   #8
soso3
Member#: 36794
89 T I T A N
I wouldn't completely rule it out as an "old wives' tale"...have you ever heard of a procedure to switch from regular to synth? I don't remember at this time where I read that, but I would assume it works both ways.....but maybe not?
soso3 is offline   Reply With Quote
Old 08-08-2003, 01:19 PM   #9
Yungimoto
Member#: 14940
You can switch back and forth. You can even mix Mobil 1 with conventional oils.
Yungimoto is offline   Reply With Quote
Old 08-08-2003, 01:38 PM   #10
HollyPiston
Member#: 36190
03 WRX
Many years ago you couldn't switch back but todays synthetics you can. It's not an old wives tale, just not valid anymore.
HollyPiston is offline   Reply With Quote
Old 08-08-2003, 02:05 PM   #11
Wrxtasy
Member#: 4649
'88 323 GTX
The thinking was that the gaskets swelled more with dino oil. When you switched from dino to synth the gasket whould shrink causing oil leeks.
I do not think is the case anymore ( or every was?)
Wrxtasy is offline   Reply With Quote
Old 08-08-2003, 04:05 PM   #12
ascott
Member#: 6545
Rally Blue Pearl
Read the back of the bottle of any synthetic, it should say somewhere "fully compatible with all SAE oils" or something like that.
If they weren't compatible and they caused problems, we would have heard about the lawsuit by now. In all honesty, your biggest issue will be possible paraffin and sulfur content in whatever conventional oil you switch to, not the small amount of synthetic that would be left in the motor after a change. Even then, it takes pretty hard use, neglect, and time to get that to be a problem.
ascott is offline   Reply With Quote
Old 08-08-2003, 04:36 PM   #13
Kwyjibo
Member#: 17851
2003 WRX
R.I.P. 7.27.2005
i switched to synthetic at 1400 miles and am now at 13K i was thinking of going back to dino oil to make sure my rings are seated properly.....maybe i'll try that at my next change and run on dino oil for another 1000 miles or so...
Kwyjibo is offline   Reply With Quote
Old 08-08-2003, 05:04 PM   #14
drees
Member#: 25905
2003 Silver Wagon
Are you burning much oil? If not, I would not worry about it.
Either way, one interval of dino will not hurt, either.
-Dave
Old 08-08-2003, 06:17 PM   #15
Jimbo
Member#: 28809
2003 WRX Wagon
Platinum Silver Metallic
The only document issue is switching from dino to synth on a high-mileage engine. The additional detergents in synth will clean out a lot of the impurities that have built up over time and possibly cause leaks. I switched from dino to synth on my GSR with 80K miles and had to replace a cam seal after it started leaking.
Any issues switching from synth to dino are wives tales and folk lore as others have stated.
Jimbo
Jimbo is offline   Reply With Quote
Old 08-08-2003, 06:48 PM   #16
Kwyjibo
Member#: 17851
2003 WRX
R.I.P. 7.27.2005
-Dave
i burn about a quart between oil changes, but i drive the car hard so maybe that's why....
Old 08-08-2003, 10:08 PM   #17
drees
Member#: 25905
2003 Silver Wagon
How many miles between changes? If you drive hard, and got on it a bit during the first 1k miles, the engine is likely are broken in as it's going to get...
Old 08-08-2003, 10:12 PM   #18
mlambert
Member#: 13831
nah, around 10k or so
mlambert is offline   Reply With Quote
Old 08-08-2003, 10:16 PM   #19
drees
Member#: 25905
2003 Silver Wagon
Really takes that long for the EJ20 to fully break in?
Old 08-08-2003, 10:18 PM   #20
mlambert
Member#: 13831
Yea give or take a few K. Mine was rode hard and put away wet and fuel economy still increased around 10k.
Old 08-09-2003, 12:39 AM   #21
Stilletto
Member#: 21866
2002 WRX Silver
Man, you guys have been great....i am feeling no fear about switching to dyno now....just between paychecks and it's time for a change...then back to synth probably for good....Good info...
This is what this board is about!
Old 08-09-2003, 04:47 AM   #22
WRX03
Member#: 20744
05 Baja Regal Blue
03 WRX Little Red Wagon
Old versions of synthetics use to ball up in old versions petroleum clogging passages. Some 2-cycle oils and caster still do this.
WRX03 is offline   Reply With Quote
Switching back from OLF to CLF bunot Engine Management & Tuning 19 01-10-2005 06:59 PM
need a pros opinion on switching from synthetic oil back to dino. blackie Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 10-28-2004 04:07 PM
Anyone here ever switched BACK from a Mac? chyisan Off-Topic 50 07-19-2004 09:49 PM
Possible to switch from synthetic back to dino oil? jotarou1 Bay Area Impreza Club Forum -- BAIC 3 10-10-2002 04:37 PM
Switching back from synthetic to regular oil mibobe Newbies & FAQs 9 07-16-2002 04:52 PM
